Samsung 50" Slim Depth LED Engine Widescreen DLP HDTV In Black
4.5
based on 21 reviews
Ratings Distribution
5 star
12
4 star
8
3 star
0
2 star
1
1 star
0
Category Average
4.5
More Images
Pros
  • Attractive design (16)
  • Great picture quality (16)
  • Fast setup (13)
  • Simple controls (9)
  • Clear picture (2)
  • Easy setup (2)
  • Durable (1)
  • Good value (1)
  • Great sound quality (1)
  • High quality (1)
See less See more
Cons
  • Hd broadcast is awesome (1)
  • Limited pip function (1)
  • Poor sound quality (1)
Best Uses
  • Movies (17)
  • Home (16)
  • Video (5)
  • Large rooms (1)
  • Med to large room (1)
Provided by Beach Audio
Thanks to a new, long-lasting LED light engine, the Full HD (1920 x 1080p) picture of the HLT5089S DLP HDTV will last as long as the set. An ultra-thin, piano-black bezel around the 50" xscreen lets you enjoy more screen and less frame. Its slim depth, light weight and hidden speaker system allow the set to fit where others won't. Samsung's Cinema Smooth light engine delivers the widest range of brilliant colors, while a 10,000:1 dynamic contrast ratio renders every picture in perfect detail, from the darkest darks to brightest whites, and every tone in between. SRS TruSurround XT delivers sound that is clear and full. Enjoy watching two shows at the same time using the one-tuner Picture-in-Picture (PIP) feature. Three HDMI inputs in version 1.3 render your digital movies, photos and more with greater color depth, while a USB 2.0 port and other inputs allow high-speed connectivity. CEC capability lets you control other peripherals using one remote; the set can also interface with other devices via Bluetooth technology. Game Mode optimizes performance, so avid gamers will marvel at the lifelike action. And even with all these advanced features, the HLT5089S is remarkably energy-efficient.
Specification Description
Model HL-S5087W, HL-S5088W, HL-T5075S, HL-T5089S
UPC 036725228498
Actual Screen Size 50"
Aspect Ratio 16:9
Brand Name Samsung
Compatible Technology HDTV
Contrast Ratio 2500:1
Dimensions 31.8" Height x 45.2" Width x 12.8" Depth
Green Compliance Yes
Green Compliance Certificate/Authority Energy Star
Manufacturer Samsung
Manufacturer Website Address www.samsungusa.com
Maximum Resolution 1920 x 1080
Ports 1 x S-Video Side
Ports 1 x HDMI Digital Audio/Video In Side
Ports 2 x Composite Audio/Video
Ports 2 x HDMI Digital Audio/Video In Rear
Ports USB
Product Type Projection TV
Projection Technology DLP
Screen Size 50"
Screen Size 50" Diagonal
Select DLP Units
Standard Warranty 1 Year Limited
Video System ATSC
Video System NTSC
Samsung 50" Slim Depth LED Engine Widescreen DLP HDTV In Black Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 50" Slim Depth LED Engine Widescreen DLP HDTV In Black
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 5, 2009
Samsung 50" Slim Depth LED Engine Widescreen DLP HDTV In Black Reviews
Most helpful positive review
[15 of 17 customers found this review helpful]
Most helpful negative review
5.0
Right On !!!
"I waited through 2005 for the new 2006 units to come out with the new tech and options and this one was worth the wait!!! This unit meets and exceeds it specs and my expectations, which are high at this price. A little extra on the cost to get to this unit is well worth it...plus Lion King and Monsters Inc. ROCK in 16:9 with full home thea...." Read Full Review »
Jun 23, 2006 by Don S.
See more positive Samsung 50" Slim Depth LED Engine Widescreen DLP HDTV In Black reviews
2.0
i owned it but returned it, DLP cons
"i owned the HLT5075S for about 2 weeks, but i ended up returning it. there are some things you should know about HDTV projection technology before deciding on a DLP set. this TV was too bright and the settings did not remedy this. alsdo DLP technology has a bad "screendoor effect" to it. i recommend checking out other options.i wrote a review of HDTV projection technology, i recommend reading this: [...]..." Read Full Review »
Dec 09, 2007 by egoprofit
See more negative Samsung 50" Slim Depth LED Engine Widescreen DLP HDTV In Black reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
Right On !!!
5.0
    Pros
  • Attractive Design
  • Clear Picture
  • Easy Controls
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Med to large room
  • Movies
A little extra on the cost to get to this unit is well worth it...plus Lion King …"  Read Full Review »
Was this Rear Projection TV review on the Samsung 50" Slim Depth LED Engine Widescreen DLP HDTV In Black helpful to you?
 Report Abuse  (15)  (2)  0 comments
Jun 23 2006
Don S.
Barrington, IL
Reviewed at:
HDTV At it's best
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Movies
  • Video
"I had ventured into the High def DVD world having gotten a HD DVD add on for my Xbox 360 and a Playstation 3. The blu-ray and HD-DVD titles I tried looked certainly better on my 44" Panasonic projection 720p LCD but I found myself comparing them to the standard DVD versions. I decided that I needed …"  Read Full Review »
Jun 4 2007
Sonic
S.E. Texas
I am:
  • Gearhead
Reviewed at:
Great HDTV Except for the PIP Feature
4.0
    Pros
  • Attractive Design
  • Great Picture
    Cons
  • Limited PIP Function
    Best Uses
  • Home
"The source for the "Picture in Picture" (PIP) feature of the Samsung HLT5089S is limited to the TV's own internal analog tuner and is available only when the main picture is coming from an external source connected to the TV's HDMI, component (not composite), or PC input. Because the PIP source is l …"  Read Full Review »
Jul 28 2007
Soothsayer
Columbus, OH
I am:
  • Tech Savvy
Reviewed at:
Love this TV
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"Love this TV. Was a little leary about buying a high $ item off the internet, but was pleasantly surprised. ABT was awesome - still havent seen a lower price months later, [...]. Picture quality is awesome in HD, SD is OK. (Recently looked at LCD's and Plasmas a second time in the store - the DLP pi …"  Read Full Review »
Feb 5 2009
DLP all the way
Layton, UT
I am:
  • Casual User
Reviewed at:
[1 of 1 customers found this review helpful]
Totally Happy
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"A friend of mine purchased the 56 inch model and I was very impressed. I did quite a bit of research on my own and it seems to me that this should get the “best in it’s class” award. I highly recommend this model. I have had it for 3 weeks and everyone who see’s it is impressed by the quality of the …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 30 2006
Jim
Chicago, IL
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
