Samsung 5 Disc Home Theater Surround Sound System
3.8
based on 12 reviews
Ratings Distribution
5 star
5
4 star
3
3 star
2
2 star
1
1 star
1
Category Average
4.1
More Images
Pros
  • Great sound quality (10)
  • Easy setup (8)
  • Thundering bass (8)
  • Confusing / difficult controls (4)
  • Interfaces well with tv (4)
  • Attractive design (1)
  • Great system (1)
  • Sounds good (1)
  • Wireless (1)
  • Wireless rear (1)
See less See more
Cons
  • Poor interface (3)
  • Difficult to set up (2)
  • Poor load design (1)
  • Poor sound quality (1)
  • Sound drops out randomly (1)
Best Uses
  • Surround sound solution (8)
  • Movies (6)
  • Living room (5)
  • Large rooms (4)
  • Smaller rooms / apartments (2)
  • Television shows (2)
Provided by OneCall
5-disc Capability
Sit and relax. Watch your fill of movies and videos without having to constantly change discs. SAMSUNG's new lineup of 5 disc changer home theater systems makes life just a little bit easier.
USB Host Play
You don't need to burn CDs or DVDs to enjoy music, video clips or photos on your home theater system - just plug a portable digital device into the USB port for instant entertainment.
iPod Dock
Not in the mood to watch a movie? Now you can enjoy music from your iPod on your home theater system. The HT-TZ515T comes with an iPod dock - just plug it in and listen to your favorite songs.
Powerful Sound!
Experience the ultimate in sound: 1200 watts of RMS power, plus high fidelity audio. SAMSUNG`s 5.1 channel (center channel and four speakers) home theater system is also enhanced with Dolby Digital(R), Dolby Pro Logic(R) and DTS system, so you hear every detail clearly.
DivX Playback
DivX technology provides excellent compression and visual quality. You can now insert DVDs and CDs that have DivX movies downloaded from your computer and watch them on your TV with this SAMSUNG home theater system.
Anynet+
Remote controls cluttering your coffee table? Simplify your home entertainment experience. Control all of your High Definition Multimedia Interface(TM) (HDMI) connected devices with one-touch control in a single universal remote.
Specification Description
Model HT-TZ515, HT-TZ515T, HTTZ515T, HTZ-515
UPC 036725616790
Analog Audio Rear Input
Antenna FM
Antenna Rear Input
Built-in DVD Player Yes
Color Black
Compatible Formats CD
Compatible Formats CD-R
Compatible Formats CD-RW
Compatible Formats DVD
Compatible Formats DVD Audio
Compatible Formats DVD+R
Compatible Formats DVD+RW
Compatible Formats DVD-R
Compatible Formats DVD-RW
Compatible Formats DiVX
Compatible Formats JPEG
Compatible Formats MP3
Compatible Formats WMA
Compatible Formats WMV
Component Video Rear Output
Composite Video Rear Input
Multi Disc Capacity 5
Optical Rear Input
Progressive Scan Yes
Remote Control Included
Satellite Radio XM Radio
USB Port Front Input
Samsung 5 Disc Home Theater Surround Sound System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 5 Disc Home Theater Surround Sound System
See all eBay results
  at eBay.com
Product Reviews
Last update: Apr 14, 2009
Samsung 5 Disc Home Theater Surround Sound System Reviews
Most helpful positive review
Most helpful negative review
5.0
BEST FOR THE PRICE AND SOUNDS GREAT
"Took a little while to setup up how I liked, but nothing was hard about the setup just took some time. If you want to watch TV and use these you will need to buy an optical cable even if you have an HDMI cable also. Wireless speakers connect to the router and technically have wires, but are still great, and really what do you expect, they need wires to work, so this is as wireless as it gets. great surround soun..." Read Full Review »
Jan 03, 2009 by AB
See more positive Samsung 5 Disc Home Theater Surround Sound System reviews
2.0
not bad.... oh wait, yes it is.
"for movies this home theater rocks! however once you try to play an ipod or the radio through the system you will find yourself greatly disappointed in the sound quality, and the slow, tacky, and bland interface. it says it plays 720p, but i find that hard to believe based on what i saw. i have a 1080p tv that i was playing it through and the picture was grainy and.... mushy, i guess. halfway through a movie the..." Read Full Review »
Dec 13, 2008 by Garrett, the disappointed customer
See more negative Samsung 5 Disc Home Theater Surround Sound System reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
2.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Thundering Bass
    Cons
  • Poor Interface
  • Poor Sound Quality
    Best Uses
  • Movies
  • Surround Sound Solution
"for movies this home theater rocks! however once you try to play an ipod or the radio through the system you will find yourself greatly disappointed in the sound quality, and the slow, tacky, and bland interface. it says it plays 720p, but i find that hard to believe based on what i saw. i have a 10 …"  Read Full Review »
Was this Home Theater review on the Samsung 5 Disc Home Theater Surround Sound System helpful to you?
Dec 13 2008
Pewaukee, WI
I am:
  • Audiophile
  • Musically Inclined
  • Professional
Reviewed at:
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Intuitive Controls
  • Thundering Bass
    Cons
  • None
    Best Uses
  • Movies
  • Smaller Rooms
  • Television Shows
"Took a little while to setup up how I liked, but nothing was hard about the setup just took some time. If you want to watch TV and use these you will need to buy an optical cable even if you have an HDMI cable also. Wireless speakers connect to the router and technically have wires, but are still gr …"  Read Full Review »
Jan 3 2009
AB
NJ
I am:
  • Tech Savvy
Reviewed at:
Pretty sweet surround
3.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Smaller Rooms
"Bought this setup for the bedroom TV. The bedroom isn't too big - about 13x17. But our nightstands are small and since we wanted surround, the towers were the way to go. Sound is good (we don't crank it or anything but it sounds fine at moderat volume) and you gotta love surround sound. One thing to …"  Read Full Review »
Dec 26 2008
big steveo
washington state
I am:
  • Practical
Reviewed at:
[1 of 1 customers found this review helpful]
Great Choice!
4.0
    Pros
  • Attractive Design
  • Clear Sound
  • Thundering Bass
  • Wireless
    Cons
  • Difficult To Setup
  • Poor Interface
    Best Uses
  • Living Room
  • Movies
"This our first surround sound system and we are happy with it. We love that it's wireless and has great sound. Problems we've had include occasionally the picture disappears during a dvd and we have to mess with the connection to get it to come back. Also we haven't figured out how to get the TV …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 26 2008
Matt and Lacie
Bloomington, IL
I am:
  • Tech Savvy
Reviewed at:
Good sound, a few bugs
3.0
    Pros
  • Clear Sound
  • Wireless rear
    Cons
  • Poor Interface
    Best Uses
  • Larger Rooms
"This system sounds good and it's a good value when it's working. The main problem I'm having is the receiver flashes an error message that reads "rear speakers", and the sound cuts out completely for about two seconds. It doesn't happen all the time, but it's super annoying when it does happen. Cons …"  Read Full Review »
Sep 1 2008
Saint Jerome
Knoxville, TN
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
