Samsung 47" 1080p LCD Flat Panel HDTV
#332
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$1,600.99 at Super Warehouse
Find it at Amazon
Find it at Ebay
$1,600.99
from 1 store
More Images
Best Uses
  • Home (1)
Provided by Super Warehouse
Audiovox Electronics FPE4707HR is an affordable choice for your home theater. This 47-inch "Ultra" high resolution HD flat panel LCD TV saves space with its detachable and a removable tilting base- which enables you to mount the set to a wall with optional VESA-compatible hardware. This set has a dual ATSC tuner over-the-air HD reception. The FPE4707HR features 1080P resolution and Faroudja's Emmy award-winning DCDi (Directional Correlational Deinterlacing) technology- which helps to eliminate the jagginess found in non-HD video content. Faroudjas unique DCDi algorithm identifies all the moving edges in a scene and adjusts the angle of interpolation at each pixel so that the interpolation always follows the edge instead of crossing it- eliminating staircasing or jagged edge artifacts. You can also view high-definition programming (1080i/720p/480p/480i) when connected to an optional receiver or cable/satellite set-top box via the component video inputs. This set also performs automatic 3:3/2:2 pulldown detection--a handy feature for watching progressive-scan movie programs in their native 24-frame format. To adapt 24 frames-per-second movies to 30 fps video- frames in the original movie must be duplicated; 3:2 pulldown digitally corrects this duplication by removing the redundant information to display a frame-accurate picture.This set has a VGA input for use with PC monitor. Other features include Dual HDMI input- DVI with HDCP input- PIP (picture in picture)- closed captioning- V-chip parental controls- progressive scan and Q surround sound. Remote control included.
  • Viewable Image Size: 47"
  • Resolution: 1024 x 768
  • Contrast Ratio: 1000:1
  • Connectivity: VGA (HD-15)- HDMI- Component
  • Cabinet Color: Black
  • Environments: PC Compatible
  • Warranty: One Year Limited
Specification Description
Model 1839459, AVXFPE4707HR, FPE4707HR
UPC 044476040146
Color Black Cabinet
Country Of Origin China
Ports 1 x Audio Line Out Rear
Screen Size 47"
Technology HDTV
Samsung 47" 1080p LCD Flat Panel HDTV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 12, 2007
Samsung 47" 1080p LCD Flat Panel HDTV Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
The best TV I have ever owned!
5.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • At Home
"Great for football season! Great for cartoons! Looks amazing and the picture is perfect! "
Was this LCD TV review on the Samsung 47" 1080p LCD Flat Panel HDTV helpful to you?
Sep 12 2007
Bambie
Las Vegas
I am:
  • Casual Viewer
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
