Samsung 46" Series 8 LCD Flat Panel HDTV - LN46A860
4.7
based on 35 reviews
Ratings Distribution
5 star
27
4 star
7
3 star
1
2 star
0
1 star
0
Category Average
4.4
$999.00 at 6th Ave Electronics
Find it at Amazon
Find it at Ebay
$999.00
from 1 store
More Images
Pros
  • High resolution (32)
  • Attractive design (31)
  • Great picture quality (31)
  • Fast setup (30)
  • Good connection options (30)
  • Simple controls (20)
  • Wide viewing angle (20)
  • Durable (1)
  • Good value (1)
  • High quality (1)
See less See more
Cons
  • Poor sound quality (6)
  • Average sound (1)
  • Bad interface (1)
  • Dark pictures in manual (1)
  • Difficult to set up (1)
  • Sound is just adquate (1)
Best Uses
  • Home (21)
  • Movies (19)
  • Home theater (17)
  • Wall mounting (12)
  • Bedroom (11)
  • Mounted on wall (1)
Provided by OneCall
Instant access to news and more
With just a push of a button you can access news, weather, sports and stock information. The InfoLink™ RSS feature gathers up-to-the-minute content from USA Today and displays it on your screen. Now you can always stay connected while watching TV anywhere in your home.
Pre-loaded Content Library™
Enjoy pre-loaded high definition content, such as cooking recipes, fitness exercises, educational games for children and even a photo gallery.
ENERGY STAR compliant
By being ENERGY STAR compliant you are assured that your SAMSUNG model is helping the environment by using less energy while saving you money. ENERGY STAR is a joint program of the U.S. Environmental Protection Agency and the U.S. Department of Energy promoting energy efficiency.
The LCD that's slimmer than its remote
With its stunning lines and bold color, SAMSUNG takes a daring step in the world of HDTV design with the 860 LCD HDTV. The super-slim cabinet is a convenient 1.9 inches deep – slimmer than its own remote control! The slender frame means there’s more screen to enjoy all your favorite events and highlights. slim depth, narrow bezel. Beautiful from every angle, you’ll save space. And with a narrow bezel you’ll enjoy a bigger picture. Showcase it anywhere - the possibilities are endless.
Auto Motion Plus 120Hz™
Your action-packed sports and movies have never looked this real. Auto Motion Plus 120Hz technology virtually eliminates any motion blur and creates smooth transitions between frames. What’s the secret? Auto Motion Plus calculates the image between frames and inserts it, creating a non-repetitive transition from one to the next. The result is a clearer picture you have to see to believe.
Ultra Clear Panel™
With SAMSUNG’s Ultra Clear Panel™ colors are more vibrant than ever before. The brighter, clearer picture will definitely amaze you. Tired of annoying glare getting in the way of your movie-watching? Our ultra clear panel technology enhances contrast and reduces reflection so you can enjoy an overall outstanding viewing experience.
Specification Description
Model LN46A860
UPC 036725228849
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video Side Input
Aspect Ratio 16:9
Component Video (2) Rear Input
Contrast Ratio 50,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 11.1
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 1080p
Headphone Jack Side Output
Height (Inches) 29.3
Optical Rear Output
PC Audio Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
Response Time 4ms
RJ45 Ethernet Rear Input
S-Video Rear Input
Screen Size (inches) 46
Speakers 10 Watts x 2
Speakers Built-in
Stand Included
Stand Swivel
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Side Input
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Weight (Pounds) 55.1
Width (Inches) 44.1
Samsung 46" Series 8 LCD Flat Panel HDTV - LN46A860 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 24, 2009
Samsung 46" Series 8 LCD Flat Panel HDTV - LN46A860 Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Gorgeous picture
"Worth the Price. Blue trim is easier on the eye than the red version. Playing movies and pics from your usb is a nice touch. Please note: cable box users with scientific atlantic 8300 HD, may have trouble operaing their remote. Separate box from TV as much as possible, and enjoy the incredible picture...." Read Full Review »
Dec 24, 2008 by TV Junkie
See more positive Samsung 46" Series 8 LCD Flat Panel HDTV - LN46A860 reviews
3.0
Great looking TV but lousy software
"The TV looks great. The blue touch of color is very hard to see and should not be advertised. I contacted Samsung who confirmed it's merely a blue tint to the plastic and is not electrically illuminated in any way. The software (firmware) in the TV is horrible. The menu navigation is too complex and confusing. There are way too many settings and they are grouped all over the place. It made me think of Micr..." Read Full Review »
Jan 31, 2009 by NL
See more negative Samsung 46" Series 8 LCD Flat Panel HDTV - LN46A860 reviews
Displaying 1 - 5 of 35 Reviews
Show
Sort by
3.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Bad Interface
    Best Uses
  • Home
  • Home Theater
  • Movies
The software (firmware) in the TV is horrible. The menu navigation is too compl …"  Read Full Review »
Was this LCD TV review on the Samsung 46" Series 8 LCD Flat Panel HDTV - LN46A860 helpful to you?
Jan 31 2009
NL
Chicago, IL
I am:
  • Power User
Gorgeous picture
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
TV as much as possible, and enjoy the incredible …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 24 2008
TV Junkie
Boca Raton, Fl
I am:
  • Enthusiast
Reviewed at:
Highly Reccomended
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Wall Mounting
"We wall mounted this unit over our fireplace in our living room. Just another excellent Samsung LCD tv we have. Extremly thin, fantastic design!! The image is extremely bright, vivid and sharp. I think better than the sony XBR units. The sound is very tunable for different types of programming and …"  Read Full Review »
Mar 15 2009
BigDukeFan
Canton, MA
I am:
  • Enthusiast
Reviewed at:
[1 of 1 customers found this review helpful]
Great product[...]
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Mounted on wall
  • Movies
"Picture quality is excellent with a variety of connection options. Very thin form factor makes it easy to mount on wall. Viewing photos via USB drive is simple and an excellent viewing experience with friends. Only drawback has been some interference during the warm up of the TV that renders the …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Nov 30 2008
HMBviewer
Half Moon Bay, CA
I am:
  • Enthusiast
Reviewed at:
Fantastic TV!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
  • Home Theater
  • Movies
  • Wall Mounting
"I use this TV for my bedroom. The TV was easy to set up and the picture is superb! It has deep blacks and vivid color. For the price, you can't beat this TV. The only thing lacking was the sound but who cares. Just hook it up to some external speakers and you're good to go. "
May 4 2009
Danimal
WI
I am:
  • Power User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
