Samsung 46-inch DLP Rear Projection HDTV - HL-T4675S
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.5
More Images
Pros
  • Attractive design (2)
  • Easy to move (2)
  • Easy assembly (1)
  • Easy to wire (1)
  • Great performance and val (1)
  • Holds all components (1)
See less See more
Best Uses
  • Hide in armoire (1)
Provided by OneCall
Integrated HDTV Tuner
with the addition of a suitable UHF/VHF antenna delivers the world of free off-air DTV and HDTV local broadcast channels. An additional QAM tuner decodes unscrambled digital cable signals.
Cinema Smooth Light Engine
Samsung is the worldwide leader in creating light engines that harness DLP HDTV technology from Texas Instruments. Samsung's Cinema Smooth light engine brings together the right optics, electronic circuitry and replaceable light source to create a brilliant picture that's more lifelike and much closer to film. Now in its sixth year of evolution, Samsung's Cinema Smooth light engine delivers crisp, 720p High Definition resolution with high contrast and brightness, defined edges and sharp detail.
Cinema Smooth 720p Light Engine
Samsung's Cinema Smooth 720p light engine is the culmination of years of industryleading research and development. It releases the maximum power of the new generation of DMD microdisplays for the most film-like picture. It creates an image with no visible pixel structure and accurate shading and better low-light detail.
Next Generation DLP Chips from Texas Instruments
Samsung employs a Texas Instruments DLP chip that is comprised of millions of microscopic mirrors. The DLP chip is faster than any other HDTV technology, with the mirrors switching on & off 15,000 times a second to deliver a razor-sharp picture for fast moving images. When combined with Samsung's new Cinema Smooth light engine, the result is a crisp, bright picture with deep, rich colors that's closer to film.
Faster 5 Segment Color Wheel for High Contrast and Brightness
Samsung's 2.2 color wheel spins at 14,400 rpm for smooth fast-motion video, and has five color segments for more accurate colors. Comprised of five colors, Red, Green, and Blue, plus Cyan and Yellow, it achieves film-like transitions and eliminates the pixel breakup found in slower color wheel designs and slower-switching LCD microdisplays. The Cinema Smooth light engine uses a whisper quiet air bearing design.
Samsung's DNIe – Digital Natural Image Engine
Samsung's exclusive Digital Natural Image engine makes the sharpest and clearest images possible, regardless of the profile of input signals. Five image processors and a six-times density enhancer ensure the best picture from any source. Now in its fifth generation (since 2002), DNIe guarantees the truest colors and highest contrast, while virtually eliminating digital artifacts.
My Color Control
You can get the pink tones, the green of the grass and the blue of the sky just you like, without affecting the other colors on the screen. The three primary colors adjusted to perfectly fit your taste. Self expression meets display perfection.
Cinema Mode
Samsung's Cinema Mode lets you see colors the way the director intended, by matching them more closely to production standards. This creates more accurate colors and natural skin tones when viewing Hollywood movies on your TV—the perfect setting when enjoying movies with the lights off.
Cinema Smooth Film Mode 3:2 Pull Down
Powered by Samsung's Cinema Smooth technology, 3:2 Pull Down corrects for the artificial frames created when films are converted to DVDs. The result is a clearer image without the subtle motion artifacts caused by 24-to-30 frames per second video conversion.
Picture Format Size Adjustment
Enjoy all your 4:3 aspect-ratio programming in smooth, wide-screen without black bars. Four pre-set aspect ratio modes—Normal, Wide, Zoom 1 and Zoom 2—stretch your image to fill the screen naturally.
Energy Efficient
Samsung DLP TVs are more energy efficient than many flat panel TVs, resulting in significant utility savings over the life of the TV.
Color Temperature Adjustments
Cool1, Cool2, Normal, Warm1, Warm2 selectable with on-screen display.
3D Comb Filter
Dramatically reduces edge image artifacts while improving transition detail.
Previous Channel
Returns to the previously viewed channel at the push of a button.
Game Mode
Enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality optimized for the special needs of gaming systems at the touch of a button.
Closed Caption
Displays dialog that can be read along with encoded broadcast TV programs and pre-recorded videos.
Non Volatile Memory
Preserves audio, video and menu settings during power outages. Auto Volume Leveler keeps audio volume consistent during channel changing to minimize static sound bursts.
Discrete IR Codes
This set is equipped with discrete IR codes for use with an optional macro/programmable remote (see owners manual for details).
Universal Remote Control
Permits control of the TV, DVD, VCR and a Tuner/Receiver.
HDMI (High-Definition Multimedia Interface)
Addresses both pure digital audio and video performance and simplifies connections from the new generation set-top boxes, HD game consoles, HD Blu-ray and DVD players by reducing cable connections to one cable and plug.
DTV and DVD
Compatible Connect your DVD and DTV sources with two smart component video (Y/Pb/Pr) inputs that accept 480p/720p/1080i signals.
PC Connectivity
A Samsung HDTV using DLP technology can also function as a high-quality XGA PC monitor.
3D HD ready. The HLT generation of Samsung DLP HDTVs are capable of displaying future 3D games, movies, and other programming via 3D compatible glasses and hardware.
SRS TruSurround XT. TruSurround is a patented SRS technology that solves the problem of playing 5.1 multichannel content over two speakers. TruSurround delivers a compelling, virtual surround sound experience through any twospeaker playback system, including internal television speakers and headphones. It is fully compatible with all multichannel formats up to 6.1 channels.
Brilliant Color II provides brightness increase in non-primary colors and boosts overall color intensity
V-Chip enables parental control for channel and program blocking of TV programs that incorporate the rating code signal.
Specification Description
Model HL-T4675S, HLT4675, HLT4675S
UPC 036725246751
Analog Audio / Video (1) Rear Output
Analog Audio / Video (1) Side Input
Analog Audio / Video (2) Rear Input
Aspect Ratio 16:9
Contrast Ratio 2,500:1
Depth (Inches) 11.1
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Native Resolution 720p
Height (Inches) 29.2
Projection Type DLP Rear Projector
Remote Control Included
Resolution 1280 x 720
RF (2) Rear Input
RGB (1) Rear Input
S-Video (2) Rear Input
Screen Size 46" Diagonal
Screen Size (inches) 46
Select DLP Units
Tuner ATSC
Tuner NTSC
Tuner QAM
Weight (Pounds) 47
Width (Inches) 41.3
Samsung 46-inch DLP Rear Projection HDTV - HL-T4675S Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 46-inch DLP Rear Projection HDTV - HL-T4675S
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 10, 2008
Samsung 46-inch DLP Rear Projection HDTV - HL-T4675S Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Great Picture for the Money!
5.0
    Pros
  • Attractive Design
  • Easy To Move
  • Great Performance and Val
    Cons
  • None
    Best Uses
  • Hide in Armoire
"I did not want a flat panel for the bedroom as it would not fit the decor. This DLP fit perfect in an armoire, tucks away behind doors when not in use. This is my second Samsung DLP. The the price and performance of DLP can't be beat! "
Was this Rear Projection TV review on the Samsung 46-inch DLP Rear Projection HDTV - HL-T4675S helpful to you?
Mar 7 2008
kengel5459
Hickory Creek TX
I am:
  • Practical
Reviewed at:
Luv my Samsung
5.0
    Pros
  • Attractive Design
  • Easy to Assemble/Wire
  • Easy To Move
  • Easy to Wire
  • Holds All Components
    Cons
  • None
    Best Uses
  • None
"Excellent picture. Paired with my Blue Ray Disc Player, it doesn't get any better than this. "
Mar 10 2008
Zee
Chicago, IL
I am:
  • High-End Shopper
  • Stylish
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
