Samsung 40 in. (Diagonal) Class LCD Full HD (1080p) Television
4.7
based on 190 reviews
from $1,199.00
Ratings Distribution
5 star
155
4 star
21
3 star
9
2 star
0
1 star
5
Category Average
4.4
$1,199.00 at Beach Camera
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Great picture quality (83)
  • High resolution (80)
  • Attractive design (79)
  • Good connection options (75)
  • Fast setup (71)
  • Wide viewing angle (56)
  • Simple controls (55)
  • Half the thickprevious (1)
  • Highest of resolutions (1)
  • I worked for syvania (1)
See less See more
Cons
  • Poor sound quality (5)
  • Confusing / bad remote control (3)
  • Difficult to set up (2)
  • Bad interface (1)
  • Cable tv issue (1)
  • Changing modes and inputs (1)
  • Confusing / difficult controls (1)
  • Glare could be a problem (1)
  • Like everything (1)
Best Uses
  • Home (67)
  • Movies (47)
  • Bedroom (20)
  • Home theater (19)
  • Wall mounting (19)
  • Video (9)
  • Office (4)
  • Computer monitor (1)
  • Everything (1)
  • Game room (1)
Provided by OneCall
Auto Motion Plus 120Hz(TM)
Your action-packed sports and movies have never looked this real. Auto Motion Plus 120 Hz technology virtually eliminates any motion blur and creates smooth transitions between frames. What`s the secret? Auto Motion Plus calculates the image between frames and inserts it, creating a non-repetitive transition from one to the next. The result is a clearer picture you have to see to believe.
4 ms Response Time
An important feature for an LCD panel is the pixel response time. Response time refers to the amount of time it takes a pixel to refresh itself-to go from being active to being inactive, (ready to be re-activated). The lower the milliseconds, the faster the response time. A very fast 4 ms response time virtually eliminates any blurring and gives you smooth-motion action scenes.
Ultra Clear Panel
With SAMSUNG`s ultra clear panel colors are more vibrant than ever before. The brighter, clearer picture will definitely amaze you. Tired of annoying glare getting in the way of your movie-watching? Our ultra clear panel technology enhances contrast and rreduces reflection so you can enjoy an overall outstanding viewing experience.
Instant Access to News and More...
With just a push of a button you can access news, weather, sports and stock information. The InfoLink(TM) RSS feature gathers up-to-the-minute content from USA Today and displays it on your screen. Now you can always stay connected while watching TV anywhere in your home.
50,000:1 Contrast Ratio
Contrast and brightness levels achieve new heights in this LCD TV. Watch movies and shows come to life with enhanced details in very dark or bright scenes. Enjoy a more realistic, sharper picture quality that`s sure to catch your eye.
Wiselink(R) USB Connection
Easily hook up your MP3 player or digital camera to your TV with the USB 2.0 connection. A simple user interface lets you scroll through and view play lists and pictures. You can zoom, rotate or play photo slide shows and even add music.
Specification Description
Model LN40A650, SAMLN40A650
UPC 036725228207
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video (1) Side Input
Aspect Ratio 16:9
color null
Command / Control EX-LINK
Compatible Formats 1080p
Component Video (2) Rear Input
Contrast Ratio (Dynamic) 50,000:1
DB15 (PC Video) Rear Input
Depth (Inches) 11.8
Dynamic Contrast Ratio 50000:1
HDMI (3) Rear Input
HDMI Side Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Height (Inches) 27.5
Optical Rear Output
PC Audio Rear Input
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
RJ45 Ethernet Rear Input
S-Video Side Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 30" to 40"
Screen Size (inches) 40
Screen Size (Inches/Diagonal) 40
Select LCD Units
size null
sku 132642
skuprice 1399.9900
skuprice 1939.9900
Speakers 10 Watts x 2
Speakers Built-in
Stand Included
Stereo Modes SRS TruSurround XT
style SAMLN40A650
Surround Modes SRS TruSurround XT
taxable Y
Tuner ATSC
Tuner NTSC
Tuner QAM
USB Port Side Input
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 44.5
Width (Inches) 39.3
Samsung 40 in. (Diagonal) Class LCD Full HD (1080p) Television Questions
Questions and Answers
Where to Buy
$1,199.00
BizRate Rating Outstanding 9.2
Product Reviews
Last update: May 8, 2009
Samsung 40 in. (Diagonal) Class LCD Full HD (1080p) Television Reviews
Most helpful positive review
[4 of 5 customers found this review helpful]
Most helpful negative review
[3 of 5 customers found this review helpful]
5.0
Great TV, Excellent picture
"Still early in the ownership and use, but the design, user interface, and picture are excellent. The sound is not as I would prefer without turning on a surround system, have not heard the 750 with the woofer included, but would be interested to see if that makes a difference. Other than that, very happy with the product. HD channels are crisp and vibrant, has the ability if you know what you are doing to adjus..." Read Full Review »
Jul 18, 2008 by West Coast Drew
See more positive Samsung 40 in. (Diagonal) Class LCD Full HD (1080p) Television reviews
3.0
Amazing Picture but BEWARE
"The picture and image is amazing on this TV. It really is the best TV out there when it comes to picture quality. However, I have been having alot of connection problems. I just ordered this TV and had my Time Warner cable installed. I connected the cable with HDMI not component. I had a ton of problems with the cable box and had time warner come to replace it. Still had problems so I called Samsung. They told m..." Read Full Review »
Jul 17, 2008 by RaeAnne
See more negative Samsung 40 in. (Diagonal) Class LCD Full HD (1080p) Television reviews
Displaying 1 - 5 of 190 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Sound Intensity
    Best Uses
  • Computer monitor
  • Home
  • Movies
  • Video
"Still early in the ownership and use, but the design, user interface, and picture are excellent. The sound is not as I would prefer without turning on a surround system, have not heard the 750 with the woofer included, but would be interested to see if that makes a difference. Other than that, very …"  Read Full Review »
Was this LCD TV review on the Samsung 40 in. (Diagonal) Class LCD Full HD (1080p) Television helpful to you?
 Report Abuse  (4)  (1)  0 comments
Jul 18 2008
West Coast Drew
San Francisco
I am:
  • Design Focused
  • Practical
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
Recommended buy
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • Controls not so simple
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"I waited about 3 weeks before writing this review so that I had enough information to give you as I wanted to share my research.I've been searching for a nice sized LCD HDTV for my bedroom and it was down to the Sony 40" Bravia Series and the Samsung 40" 550-750 series. I went to the stores to see …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 16 2009
Ricky
New York, NY
I am:
  • Casual User
Reviewed at:
[2 of 2 customers found this review helpful]
Beatutiful picture, excellent value!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"This TV is absolutely brilliant, the quality is fault-less, and the menu options are about as close to perfect as it gets. The 120hz option may not be perfect for watching movies or cable TV, but it is absolutely incredible for playing video games. Gears of War 2 and Forza 2 benefit greatly from th …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 9 2008
Svitty
Honolulu, HI
I am:
  • Enthusiast
Reviewed at:
Great television !
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • Simple Controls
    Cons
  • None really so far
    Best Uses
  • Home
  • Movies
  • Video
"The only "negative" is that the super bright and sharp image took some getting used to, compared to the 720p HD CRT Toshiba set it replaced. The Toshiba was a good set, but the LN40A650 blows it away on picture quality. This was a CR top-scoring set on a recent review, which is why I purchased. I …"  Read Full Review »
Dec 2 2008
Gator Jim
Gainesville, FL
I am:
  • Casual User
Reviewed at:
THE BEST LCD OUT !
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Great resolution
    Cons
  • Remote isn't universal
    Best Uses
  • Movies
"I had spent a lot of time reading reviews and going to stores doing side by side comparisons before we bought this TV. This TV has a great picture and the best Blu-ray picture I have ever seen. However, you may need to download a firmware update for an auto shut off problem some people have reported …"  Read Full Review »
Apr 23 2008
SK8R21
Chicago,IL
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
