Samsung 40" 1080p LCD HDTV - LN40A530
4.7
based on 151 reviews
Ratings Distribution
5 star
120
4 star
25
3 star
1
2 star
2
1 star
3
Category Average
4.4
Pros
  • Attractive design (6)
  • Bright image (5)
  • Good connection options (5)
  • High resolution (5)
  • Simple controls (5)
  • Fast setup (4)
  • Reduced glare (4)
  • Blue ray - stellar pict (1)
  • Easy use for non techies (1)
  • Excellent sound amplifica (1)
See less See more
Cons
  • Bad interface (1)
  • Low resolution (1)
Best Uses
  • Home (6)
  • Home theater (3)
  • Movies (3)
  • Sports (1)
  • Video (1)
  • Wall mounting (1)
Provided by WolfCamera.com
Picture quality to be rivaled with
Watching TV and movies has never been this engaging. With a 40" screen, 1080p resolution, and a 20,000:1 dynamic contrast ratio, you'll get the total high-definition experience you've been waiting for. Plus, you'll be amazed at the razor-sharp picture and crisp, crystal-clear sound. Need to connect your MP3 player or camcorder? Three HDMI inputs make it easy. Turning your high-definition dreams into a reality has never been easier with the SAMSUNG LN40A530 LCD TV.
12000:1 Dynamic Contrast Ratio
Contrast and brightness levels achieve new heights in this LCD TV. Watch movies and shows come to life with enhanced details in very dark or bright scenes. Enjoy a more realistic, sharper picture quality that's sure to catch your eye.
SRS TruSurround XT
SAMSUNG TVs are equipped with the best that technology can offer in sound quality. Our 2 speakers always deliver an enhanced, virtual surround-sound listening experience that brings your HDTV experience to another level.
Wide Color Enhancer
Whereas blue and green shaded areas of the picture are washed out on conventional screens, wide color enhancer lets you experience more brilliant colors. Simply imagine a wider range of colors than you ever thought possible.
5ms Response Time
One of the most important features for an LCD panel is the pixel response time. Response time refers to the amount of time it takes a pixel to "refresh" itself-to go from being active to being inactive, (ready to be re-activated). The lower the milliseconds, the faster the response time. A very fast 5ms response time virtually eliminates any blurring and gives you smooth-motion action scenes.
ENERGY STAR Compliant
By being ENERGY STAR compliant you are assured that your SAMSUNG model is helping the environment by using less energy while saving you money. ENERGY STAR is a joint program of the U.S. Environmental Protection Agency and the U.S. Department of Energy promoting energy efficiency.
Samsung 40" 1080p LCD HDTV - LN40A530 Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 40" 1080p LCD HDTV - LN40A530
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 7, 2009
Samsung 40" 1080p LCD HDTV - LN40A530 Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[41 of 47 customers found this review helpful]
5.0
Just in time...
"Contemplating whether size matters; the size of our wallets or the size of the television? This decision did not come easy. It was after 6 months of research before we ended up buying the smaller television which was this one, instead of the 46 inch, because it was cheaper and it fitted perfectly into my 02 Celica. After unboxing it, we plugged in the power cord and the cable and it took about 10 minutes to scan..." Read Full Review »
Feb 02, 2009 by gklowell
See more positive Samsung 40" 1080p LCD HDTV - LN40A530 reviews
1.0
Excellent if "S" but watch out for "C" and "A"
"After doing quite a bit of research to try and figure out why my picture was not up to snuff I came across some interesting information regarding Samsung LCD panels. It turns out that not all Samsungs are made by Samsung! There are "S", "A", and "C" version codes (located on the side of your panel between the Model# and Serial#). The "S" version is the highest quality and the panel is made by Samsung themselves,..." Read Full Review »
Dec 27, 2008 by kxshook
See more negative Samsung 40" 1080p LCD HDTV - LN40A530 reviews
Displaying 1 - 5 of 151 Reviews
Show
Sort by
1.0
"After doing quite a bit of research to try and figure out why my picture was not up to snuff I came across some interesting information regarding Samsung LCD panels. It turns out that not all Samsungs are made by Samsung! There are "S", "A", and "C" version codes (located on the side of your panel b …"  Read Full Review »
Was this LCD TV review on the Samsung 40" 1080p LCD HDTV - LN40A530 helpful to you?
 Report Abuse  (41)  (6)  0 comments
Dec 27 2008
kxshook
Undisclosed
Reviewed at:
Just in time...
5.0
"Contemplating whether size matters; the size of our wallets or the size of the television? This decision did not come easy. It was after 6 months of research before we ended up buying the smaller television which was this one, instead of the 46 inch, because it was cheaper and it fitted perfectly in …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 2 2009
gklowell
Lowell, MA
Reviewed at:
Mostly Satisfied
4.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"The picture quality of the ln40a530 is excellent but I have one small gripe. In a sunlit room the black bars at the top and bottom of a film appear almost as black as the frame around the screen. However, in a dark room the black bars are noticeably lighter than the true black of the frame. This may …"  Read Full Review »
Nov 27 2008
sean_t_perry
NH
I am:
  • Casual User
[3 of 3 customers found this review helpful]
Great buy for the money
5.0
"I've been doing a lot of research on the series 5 and 6 LCD's from samsung. First, samsung is a brand that has nearly all of its hardware in most LCD's and brands anyway. They were groundbreaking in monitors and made their TV's just as groundbreaking.
Here's where you get your money's worth with thi …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Sep 29 2008
judee
Santa Rosa, CA
Reviewed at:
[2 of 3 customers found this review helpful]
Good TV but some Flaws
4.0
"This TV has a lot of good features. I have a 50" Panny Plasma which has a picture that is a lot better than this Samsung. I got this because I want to play video games and was worried about the burn in with the plasma. You can notice the delay in picture response compared to a plasma tv. I notice it …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Jun 4 2008
Badger1
Charlotte, NC
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
