Samsung 40" 1080p 120Hz Flat-Panel LCD HDTV - LN40A750
#28
4.8
based on 71 reviews
Ratings Distribution
5 star
61
4 star
9
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$1,087.50 at OneCall
 Trusted:
$1,279.99 at pcRUSH
Find it at Amazon
$1,087.50 - $1,279.99
from 2 stores
Pros
  • Attractive design (51)
  • High resolution (50)
  • Great picture quality (48)
  • Good connection options (46)
  • Fast setup (44)
  • Simple controls (36)
  • Wide viewing angle (32)
  • Great sound quality (2)
  • Best when wall mounted (1)
  • Newswxstocks via wifi (1)
See less See more
Cons
  • Poor sound quality (4)
  • Difficult to set up (2)
  • Bad interface (1)
  • Contents library uploads (1)
  • Frame too large (1)
  • Invisible manual controls (1)
  • No rf feed through (1)
  • Poor instructions / manual (1)
  • Speakers (1)
Best Uses
  • Home (39)
  • Movies (27)
  • Bedroom (22)
  • Home theater (18)
  • Wall mounting (15)
  • Video (7)
  • Bedroom or small den (1)
  • Kitchen (1)
  • Office (1)
  • Professional (1)
Provided by OneCall
Auto Motion Plus 120Hz™
Your action-packed sports and movies have never looked this real. Auto Motion Plus 120Hz technology virtually eliminates any motion blur and creates smooth transitions between frames. What`s the secret? Auto Motion Plus calculates the image between frames and inserts it, creating a non-repetitive transition from one to the next. The result is a clearer picture you have to see to believe.
Ultra Clear Panel™
With SAMSUNG`s Ultra Clear Panel™ colors are more vibrant than ever before. The brighter, clearer picture will definitely amaze you. Tired of annoying glare getting in the way of your movie-watching? Our ultra clear panel technology enhances contrast and reduces reflection so you can enjoy an overall outstanding viewing experience.
ENERGY STAR compliant
By being ENERGY STAR compliant you are assured that your SAMSUNG model is helping the environment by using less energy while saving you money. ENERGY STAR is a joint program of the U.S. Environmental Protection Agency and the U.S. Department of Energy promoting energy efficiency.
Instant Access to News and More
With just a push of a button you can access news, weather, sports and stock information. The InfoLink™ RSS feature gathers up-to-the-minute content from USA Today and displays it on your screen. Now you can always stay connected while watching TV anywhere in your home.
Pre-loaded Content
Enjoy pre-loaded high definition content, such as cooking recipes, fitness exercises, educational games for children and even a photo gallery.
Ultimate Picture Quality
Full HD (1080p) contains 1.5 times more scanning lines than conventional HD TVs. That means more pixels, more details and a better picture. A resolution that is approximately twice as much as conventional HD TVs, creates the most perfect picture imaginable.
Specification Description
Model LN40A750
UPC 036725228450
Aspect Ratio 16:9
Command / Control Anynet +
Compatible Formats 1080p
Component Video (2) Rear Input
Composite Video Rear Input
Composite Video Side Output
Contrast Ratio 50,000:1
Contrast Ratio 50000:1
DB15 (PC Video) Rear Input
Depth (Inches) 10.7
Dynamic Contrast Ratio 50000:1
Energy Star Compliant Yes
HDMI (1) Side Input
HDMI (3) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 1080p
Headphone Jack Side Output
Height (Inches) 27.0
Refresh Frequency 120 Hz
Remote Control Included
Resolution 1920 x 1080
S-Video Side Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 30" to 40"
Screen Size 40"
Screen Size (inches) 40
Screen Size (Inches/Diagonal) 40
Select LCD Units
Speakers 10 Watts x 2
Speakers Built-in
Tuner AM
Tuner NTSC
Tuner QAM
Viewing Angle 178 degrees Horizontal
Viewing Angle 178 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 42.8
Width (Inches) 40.9
Samsung 40" 1080p 120Hz Flat-Panel LCD HDTV - LN40A750 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 27, 2009
Samsung 40" 1080p 120Hz Flat-Panel LCD HDTV - LN40A750 Reviews
Most helpful positive review
Most helpful negative review
5.0
Best TV on the market
"Easy Setup, Great Picture and several conveniences with uselink and ethernet port..." Read Full Review »
Jan 04, 2009 by Jon B
See more positive Samsung 40" 1080p 120Hz Flat-Panel LCD HDTV - LN40A750 reviews
1.0
Faulty Set - Poor service from Samsung
"See Service... Product worked 1 day after waiting for a week for repair...now broken again...." Read Full Review »
Feb 24, 2009 by Nessie
See more negative Samsung 40" 1080p 120Hz Flat-Panel LCD HDTV - LN40A750 reviews
Displaying 1 - 5 of 71 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
"Easy Setup, Great Picture and several conveniences with uselink and ethernet port "
  • Picture of Product
Was this LCD TV review on the Samsung 40" 1080p 120Hz Flat-Panel LCD HDTV - LN40A750 helpful to you?
Jan 4 2009
Jon B
St. Louis, MO
I am:
  • Casual User
Reviewed at:
Price: $1,087.50
[4 of 4 customers found this review helpful]
We LOVE the new 40 LCD Samsung,
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Video
"Can't say enough good things about being a proud, new owner of our LN 40A750 LCD Samsung. It is like having a new baby in the house, everyone wants to see it. We play a lot of Wii games on it. It is perfect for that. Has GREAT color and clarity, beautiful sound. I did a lot of research before buyi …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Nov 12 2008
Hard to please JEAN
Swartz Creek MI
I am:
  • Enthusiast
Reviewed at:
[4 of 5 customers found this review helpful]
Outstanding HD LCD
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Good Resolution
  • Reduced Glare
    Cons
  • Contents Library Uploads
  • Speakers
    Best Uses
  • Home
"This LCD is great! The picture while wathcing HD is outstanding. You won't believe your eyes when wathcing full 1080p programs. The only really disappointing feature I have found thus far is the fact that you can't upload additional content to the library, such as recipes, games, children's progr …"  Read Full Review »
 Report Abuse  (4)  (1)  0 comments
Jul 6 2008
TB
New York, NY
Reviewed at:
[2 of 2 customers found this review helpful]
A Masterpiece
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
"I use this TV in my college dorm, and first thing people realized was WOW this is a sweet TV, the red attracts attention and the black makes the TV look bigger, I would of gone 46inches, but I kinda didn't have that much space. Best feature is the color, it is amazing, the 120 Hz is very good, but …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 10 2009
ItsThatGuy
Boston MA
I am:
  • Casual User
Reviewed at:
[3 of 3 customers found this review helpful]
This is one awesome HDTV.
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
  • Office
  • Professional
  • Video
"This HDTV is packed with more features than any
other ones that I looked at in this price range.
It has Picture in Picture, 120 MHz auto motion,
Infolink (recieves news, weather, and stock quotes via the internet), Wise Link Pro which allows you to connect a memory stick and view media turning yo …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jul 29 2008
PM
Rhode Island
I am:
  • Professional
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
