Samsung 32" Series 3 Flat Panel LCD HDTV (Model #LN32B360)
#578
4.2
based on 101 reviews
Ratings Distribution
5 star
69
4 star
10
3 star
4
2 star
8
1 star
10
Category Average
4.4
$444.00 - $549.99
from 16 stores
More Images
Pros
  • Attractive design (14)
  • Bright image (14)
  • Fast setup (14)
  • High resolution (14)
  • Good connection options (11)
  • Simple controls (11)
  • Reduced glare (10)
See less See more
Cons
  • Poor sound quality (2)
  • Low resolution (1)
  • Volume control (1)
Best Uses
  • Bedroom (10)
  • Home (7)
  • Wall mounting (5)
  • Home theater (3)
  • Movies (3)
  • Living room (1)
  • Medium sized rooms (1)
Provided by Sears
720p Pixel Resolution - 1366 x 768 pixel resolution provides you with a whole new level of detail. Wide Color Enhancer 2 - This feature optimizes a given color's hue, resulting in more natural rendering of colors. 30,000:1 Dynamic Contrast Ratio - Experience an unprecedented level of detail. Lightning-Fast Response - A fast 8ms response time minimizes blurring of fast motion in sports programs and action movies. Game Mode - This mode enhances dark areas, sharpens the picture, speeds up the image processing response and enhances the sounds of your games. Picture and sound quality are optimized for the special needs of gaming system with the touch of a button. SRS TruSurround HD - Creates an immersive, feature-rich surround sound experience from two speakers, complete with rich bass, high frequency detail and clear dialogue. Amazing Audio - You'll be blown away by the unit's bottom speakers with 6 Watt (3W x 2) stereo audio power. Built-In Tuner - A built-in digital tuner (ATSC/Clear QAM) enables you to find your favorite programming, right out of the box. Connections - HDMI (2), Component Video, Composite, PC, RS232C, Headphone Jack, Optical Audio Out.
Specification Description
Model LN32B360, LN32B360C5D, SAMLN32B360B
UPC 036725229860
16:9 Mode Yes
Battery Type Remote
Benefits 31.5" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1366x768 resolutionHDMI™, component, composite an
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.7 million
Compliant Standards UL Listed, FCC/DHHS certified
Connections HDMI™ in (2)Component in (1)RCA composite in (1)VGA (1)S-video in (1)RCA analog audio (1)
Country Of Origin Mexico
Description Header Upgrade any space.
Display Catalog Number 16-899
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 31.5 inches
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box Samsung LN32A330 32" LCD HDTV with detachable standRemote control"AAA" batteries (2)User's guide
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model LN32B360
New Date Sun Aug 16 00:00:00 CDT 2009
Operating Temperature UOM ° F
Output Power / Total 20 watts
Parental controls Yes
Pixel Response Time 8 ms
Product Depth 9.9
Product Dimensions UOM inches
Product Height 22.7
Product Type Flat-panel TVs
Product Weight 25.1
Product Width 31.4
Reception System NTSC/ATSC/QAM
Screen Size Range 31-40"
Secondary Audio Program (SAP) Yes
Size AAA
Sound Output Mode Stereo
Speaker(s) Built-in, 10W + 10W
Speakers Included 2 Speakers
Supported Languages English, Spanish, French
Surround Sound Effects SRS TruSurround
Technology IR
TV Diagonal Size 31.5 inches
TV Image Contrast Ratio 30000:1
TV Resolution 1366x768
TV Technology LCD
Type LCD
V-Chip Control Yes
Voltage Required 120V AC +/- 10%, 60Hz +/- 0.5%
Widescreen Modes 480i, 480p, 720p
Samsung 32" Series 3 Flat Panel LCD HDTV (Model #LN32B360) Questions
Questions and Answers
Where to Buy
$499.99
$534.99
BizRate Rating Outstanding 9.4
$444.00
No Tax Outside NY
BizRate Rating Outstanding 9.7
Show all 16 stores
Product Reviews
Last update: Nov 9, 2009
Samsung 32" Series 3 Flat Panel LCD HDTV (Model #LN32B360) Reviews
Most helpful positive review
[12 of 12 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Great Value
"Image quality is bright and vivid, with tremendous detail and excellent color. Deep blacks are rendered quite well, and those who like to tweak the image will be very pleased--there are a multitude of adjustments available, some of which would have only been found on the rear service panel (or hidden service menu) of older CRT sets. Channel changes are fairly quick--most welcome compared to a recently purchased..." Read Full Review »
Jun 28, 2009 by william5916
See more positive Samsung 32" Series 3 Flat Panel LCD HDTV (Model #LN32B360) reviews
2.0
It was like anyother ...
"It was like anyother day...much like today. You start feeling the pressure of not having the latest technology like your neighbors and friends. Most of my technology was updated except for my tv. So i though hey what the heck i think im going to invest in an HDTV. Plus iv'e been wanting to experience my ps3 and MGS4 the way it was meant to be viewed through HD. So i did some price research and went into my local..." Read Full Review »
Jul 30, 2009 by METALGEARRULZ
See more negative Samsung 32" Series 3 Flat Panel LCD HDTV (Model #LN32B360) reviews
Displaying 1 - 5 of 101 Reviews
Show
Sort by
Great Value
5.0
"Image quality is bright and vivid, with tremendous detail and excellent color. Deep blacks are rendered quite well, and those who like to tweak the image will be very pleased--there are a multitude of adjustments available, some of which would have only been found on the rear service panel (or hidde …"  Read Full Review »
Was this LCD TV review on the Samsung 32" Series 3 Flat Panel LCD HDTV (Model #LN32B360) helpful to you?
 Report Abuse  (12)  (0)  0 comments
Jun 28 2009
william5916
Newport News, VA
Reviewed at:
Price: $499.99
[28 of 29 customers found this review helpful]
Great TV & brand for the price!!
5.0
"I have this TV in my family room, and it is very easy to use, set up, and has a great picture! I am going to upgrade to a larger size and move this into the bedroom. I would recommend this to anyone looking to buy a 32". "
 Report Abuse  (28)  (1)  0 comments
Apr 27 2009
KLM
Minnetonka, MN, USA
Reviewed at:
Price: $549.99
[7 of 7 customers found this review helpful]
Excellent purchase
5.0
"After a little over two months of researching and looking at many different 32" LCD HDTV's, we definitely settled on Samsung as the brand. Then after the price searching and seeing what was out there for the different models, Samsung's LN32B360 was exactly what we wanted. This TV purchase is for our …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Jul 2 2009
AZDee
Phoenix, AZ
Reviewed at:
Price: $499.99
Excellent quality, budget HDTV
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • Poor Resolution
  • Poor Sound
    Best Uses
  • Bedroom
  • Home
  • Home Theater
  • Movies
  • Wall Mounting
"If your looking for a budget HDTV that's a decent size for your bedroom, guest room, dorm room, child's room or even your living room, then look no further. This is the best 32" 720p HDTV you can possibly buy. Because this is 720p high definition, the resolution is not that high. But this is fine fo …"  Read Full Review »
Sep 1 2009
Louis
Queens, NY
I am:
  • Power User
Reviewed at:
Price: $534.99
[1 of 4 customers found this review helpful]
Tv Not Turning On
1.0
    Pros
  • None
    Cons
  • Poor Sound
    Best Uses
  • Bedroom
  • Wall Mounting
"I bought this Tv about a year ago and all of the sudden it's just not turning on. There were no signed leading up to this. I'm just glad I bought the protection plan for it. I had just had a Westinghouse House Tv that just stopped working too, and didn't have the plan for that, so I made sure I b …"  Read Full Review »
 Report Abuse  (1)  (3)  0 comments
Oct 28 2009
Buy the Protection Plan!!
Vermont
I am:
  • Power User
Reviewed at:
Price: $499.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
