Samsung 26" Widescreen LCD HDTV - LN26A450
#221
4.6
based on 69 reviews
from $639.00
Ratings Distribution
5 star
50
4 star
15
3 star
2
2 star
2
1 star
0
Category Average
4.4
$639.00 at Rainbow Appliance
Find it at Amazon
Find it at Ebay
Pros
  • Attractive design (26)
  • Great picture quality (25)
  • High resolution (25)
  • Fast setup (23)
  • Simple controls (22)
  • Good connection options (21)
  • Wide viewing angle (17)
See less See more
Cons
  • Poor sound quality (5)
  • Bad interface (1)
  • Difficult to set up (1)
  • Poor connection options (1)
  • Poor pic unless head on (1)
Best Uses
  • Home (13)
  • Bedroom (12)
  • Movies (8)
  • Kitchen (3)
  • Office (3)
  • Video (2)
  • Wall mounting (2)
  • Dorm room (1)
  • Gaming (1)
  • Motor home (1)
Provided by RitzCamera.com
Enjoy the clarity of HD, in a stunningly modern design. True 720p resolution offers amazing LCD image detail, complemented by a 5,000:1 dynamic contrast ratio for vivid colors and bold blacks. Three HDMI inputs let you connect quickly and easily to your peripherals. Call up a variety of menu options and preferences - right on the 26-inch screen - via a smart user interface. Speaking of smart, the intelligently hidden speakers ensure a sleek, clean look that fits in almost any surroundings.
HD-Grade 1366 (H) x 768 (V) pixel resolution: High resolution pixel density with built-in image scaler to handle inputs from a variety of digital and analog audio/video sources.
Widescreen aspect ratio
CCFL- Cold Cathode Fluorescent Lamp: Provides colors in your picture that were not available before.
5,000:1 contrast ratio/450nit brightness: As two of the most important determining factors in overall picture quality, contrast and brightness levels achieve new heights in this latest generation LCD panel. Samsung's new LCD TVs give the most stunning realistic picture quality ever from a flat panel set.
Built-in digital tuner: (ATSC/Clear QAM)
Response time: Fast 8ms response time minimizes blurring of moving video.
160 degree x 150 degree (H/V) viewing angle
DNIe The Samsung Digital Natural Image engine: This exclusive Samsung technology dramatically improves the picture by enhancing the contrast, detail, white balance and reduces noise.
Entertainment Mode: allows customized picture settings, optimized for different content (e.g., sports, movies, gaming).
Hidden bottom speakers with 5 Watts x 2 audio power
SRS TruSurround XT: TruSurround is a patented SRS technology that solves the problem of playing 5.1 multichannel content over two speakers. TruSurround delivers a compelling, virtual surround sound experience through any twospeaker playback system, including internal television speakers and headphones. It is fully compatible with all multichannel formats up to 5.1 channels.
Stereo broadcast reception: (MTS & SAP) with 181-channel capacity.
V-Chip system: allows blocking of rated TV and movie programs determined by the parent to contain objectionable content.
Trilingual on-screen displays in English, Spanish or French.
Variable sleep timer to turn the TV off in varying time intervals.
HDMI-CEC allows peripheral devices such as a DVD player to be controlled by TV remote control.
Specification Description
Model LN26A450, SAMLN26A450
UPC 036725228115
Analog Audio (1) Rear Output
Analog Audio (1) Side Input
Analog Audio (3) Rear Input
Analog Audio / Video (1) Rear Output
Analog Audio / Video (1) Side Input
Analog Audio / Video (3) Rear Input
Aspect Ratio 16:9
Brightness 300nit
color null
Command / Control EX-LINK
Compatible Formats 720p
Component Video (2) Rear Input
Composite Video Side Input
Contrast Ratio 5,000:1
Contrast Ratio 5000:1
DB15 (PC Video) Rear Input
Depth (Inches) 8.5
Dynamic Contrast Ratio 5000:1
HDMI (1) Side Input
HDMI (2) Rear Input
HDTV HDTV Tuner Built In
HDTV Capable HD Tuner is included
HDTV Native Resolution 720p
Headphone Jack Side Output
Height (Inches) 19.7
Optical Rear Output
PC Audio Rear Input
Refresh Frequency 60 Hz
Remote Control Included
Resolution 1366 x 768
S-Video Side Input
Screen Format 16:9 Widescreen TV Imaging
Screen Size 21" to 29"
Screen Size 26"
Screen Size (inches) 26
Screen Size (Inches/Diagonal) 26
Select LCD Units
size null
sku 132636
skuprice 549.9900
Speakers 5 Watts x 2
Speakers Built-in
Stand Included
style SAMLN26A450
taxable Y
Viewing Angle 150 degrees Horizontal
Viewing Angle 160 degrees Vertical
Wall Mountable Yes
Weight (Pounds) 21.4
Width (Inches) 26.37
Samsung 26" Widescreen LCD HDTV - LN26A450 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 26, 2009
Samsung 26" Widescreen LCD HDTV - LN26A450 Reviews
Most helpful positive review
Most helpful negative review
5.0
Just what I had hoped for
"I bought this TV for my office. I had purchased a different brand before this one and the picture was not good. I kept looking at this one in stores and the picture looked awesome. So, I ordered it. I have not been disappointed. It has an awesome picture, easy to set up and good looking. I would highly recommend this product...." Read Full Review »
Feb 26, 2009 by SB Realtor
See more positive Samsung 26" Widescreen LCD HDTV - LN26A450 reviews
2.0
Basic LCD TV at best
"This is a basic LCD TV at best. I previously had a Samsung LN-T2653 (Samsung's last years high-end 26" model). After a couple of weeks of owning it something went wrong with the LCD screen and it was replaced under warranty with this model. The tuner in this model does not pick up as many HDTV channels as the previous model did in my local market. The previous model had a multi-function remote that I could contr..." Read Full Review »
May 06, 2008 by Imprezd
See more negative Samsung 26" Widescreen LCD HDTV - LN26A450 reviews
Displaying 1 - 5 of 69 Reviews
Show
Sort by
2.0
The tuner in this model does not pick up as many HDTV chann …"  Read Full Review »
Was this LCD TV review on the Samsung 26" Widescreen LCD HDTV - LN26A450 helpful to you?
May 6 2008
Imprezd
New Berlin, WI
Reviewed at:
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
  • Home
  • Movies
"I bought this TV for my office. I had purchased a different brand before this one and the picture was not good. I kept looking at this one in stores and the picture looked awesome. So, I ordered it. I have not been disappointed. It has an awesome picture, easy to set up and good looking. I woul …"  Read Full Review »
Feb 26 2009
SB Realtor
Pensacola, FL
I am:
  • Casual User
Reviewed at:
Phenomenal Product
5.0
"WOW! This HDTV is simply incredible. I researched and read review after review for months, and I am so glad that I landed on this one. Hi-Definition television is the sort of thing that one ought to buy it once and buy it right. I am so glad that I decided to do so with this product. It was just abo …"  Read Full Review »
Jul 7 2008
austinm0326
Katy, TX
Reviewed at:
Great Picture
4.0
"If not for the down firing speakers that sound terrible I would rate this TV a 5 .
Picture is very , very good . Tv is slim ,nice looking and has lots of various connections , including 3 HDMI's .
Out of the box it took me about 45 minutes to hook it up to my HD cable box and a Yamaha Dolby receiver …"  Read Full Review »
Jul 2 2008
OceanMan
Undisclosed
Reviewed at:
Great LCD
4.0
"I purchased this television a couple of days ago and truly love it. At the moment I have it hooked up a DVR box through my local cable provider. I used a HDMI cable to connect the 2 sources and ran into a bit of a snag...I was getting no sound! After running a few tests I realized it was a problem w …"  Read Full Review »
Oct 13 2008
mattsh33
Rossford, OH
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
