Samsung 26 in. (Diagonal) Class LCD Integrated HDTV (720p)
#375
4.3
based on 27 reviews
Ratings Distribution
5 star
17
4 star
6
3 star
0
2 star
3
1 star
1
Category Average
4.4
$629.00 at Rainbow Appliance
Find it at Amazon
Find it at Ebay
$629.00
from 1 store
More Images
Pros
  • Attractive design (1)
  • Bright image (1)
  • Fast setup (1)
  • Good connection options (1)
  • High quality (1)
  • High resolution (1)
  • Its a sleek look (1)
  • Reduced glare (1)
  • Simple controls (1)
See less See more
Cons
  • I need to buy cables (1)
  • Pricey (1)
Best Uses
  • Home (1)
  • Watching tv in my bedroom (1)
Provided by B&H Photo Video
The LN26A330 26" 720p LCD HDTV (Black) from Samsung is ideal wherever space is tight. This slim, stylish screen has an integrated NTSC/ATSC/QAM tuner, which receives digital terrestrial and cable signals. The HDMI input allows for a one-cable digital connection with your HD gear. The LN26A330 has a 26" display, which features sharp, realistic imagery combined with SRS TruSurround XT to bring your movies and HD programming to life. The PC input allows this display to double as a computer monitor when space saving is essential.
Specification Description
Model LN26A330, LN26A330J1DXZA
UPC 036725228245
Screen Size 21" to 29"
Select LCD Units
Samsung 26 in. (Diagonal) Class LCD Integrated HDTV (720p) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Mar 3, 2009
Samsung 26 in. (Diagonal) Class LCD Integrated HDTV (720p) Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
A great little big screen
"This was my first purchase of a flat panel TV; it will replace a TV/VCR combo in my bedroom. After a bit of research and reading the excellent reviews I bought the LN26A330 ...the A450 version runs about $100 more and you get some extras but for my needs the 330 fit the bill. Set up is easy; the LCD panel is easily handled by one person. If you are using this set as a bedroom or secondary TV, there are ample hig..." Read Full Review »
Aug 30, 2008 by mikado463
See more positive Samsung 26 in. (Diagonal) Class LCD Integrated HDTV (720p) reviews
2.0
Third Samsung TV, not the quality I expected.
"I purchased the first HDTV of the house in 2006, a nice little Samsung 23" 720p model. Unfortunately I recently discovered it lacked a built in digital (ATSC) tuner for receiving Over The Air HD programming(Or any programming for that matter come February 17). I figured it was time for an upgrade, and after doing a lot of homework, I settled on this LN26A330 over the A450 model because of it's cheaper price, and..." Read Full Review »
Jan 27, 2009 by Anonymous
See more negative Samsung 26 in. (Diagonal) Class LCD Integrated HDTV (720p) reviews
Displaying 1 - 5 of 27 Reviews
Show
Sort by
4.0
"This was my first purchase of a flat panel TV; it will replace a TV/VCR combo in my bedroom. After a bit of research and reading the excellent reviews I bought the LN26A330 ...the A450 version runs about $100 more and you get some extras but for my needs the 330 fit the bill. Set up is easy; the LCD …"  Read Full Review »
Was this LCD TV review on the Samsung 26 in. (Diagonal) Class LCD Integrated HDTV (720p) helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 30 2008
mikado463
Georgia
Reviewed at:
[6 of 7 customers found this review helpful]
Excellent Tv
5.0
"This TV is excellent with its picture quality. The HD literally jumps out at you. There is a significant amount of hookups so you can hook up that blu-ray player, dvd player, receiver, cable box, and xbox/ps3 all at once. Only downside is that its not 1080p and its only 60hz, causing that 3:2 pull d …"  Read Full Review »
 Report Abuse  (6)  (1)  0 comments
Apr 28 2008
dpmd6161
MD
Reviewed at:
[3 of 3 customers found this review helpful]
So far so good...
4.0
    Pros
  • High Quality
  • Its a sleek look
    Cons
  • Expensive
    Best Uses
  • watching tv in my bedroom
"The picture and sound quality seem great so far. I am having trouble with lines in the TV and feedback noise, but I'm told that's because I need a HDMI cable to connect to the cable box. I plan on purchasing that this week, so hopefully that should alleviate my problem with feedback and noise. "
 Report Abuse  (3)  (0)  0 comments
Jun 9 2008
Nicky
Hoboken, NJ
Reviewed at:
2.0
"I purchased the first HDTV of the house in 2006, a nice little Samsung 23" 720p model. Unfortunately I recently discovered it lacked a built in digital (ATSC) tuner for receiving Over The Air HD programming(Or any programming for that matter come February 17). I figured it was time for an upgrade, a …"  Read Full Review »
Jan 27 2009
Hampton Roads, VA
Reviewed at:
Best 26" available, imo.
5.0
"This is my second Samsung HDTV and it well definitely not be my last! This 26" is truly amazing as Samsung delivers great quality again.
I bought this yesterday and when I got home I immediately hooked up my Wii and Xbox 360 and they look fantastic! Even though the Wii only supports up to 480p it s …"  Read Full Review »
Jun 7 2008
TriggerEffect
WI
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
