Samsung 245BW 24" Widescreen LCD Monitor
3.8
based on 18 reviews
Ratings Distribution
5 star
7
4 star
5
3 star
4
2 star
2
1 star
1
Category Average
4.4
More Images
Pros
  • Adjustable (4)
  • Great picture quality (4)
  • Vivid colors (3)
  • Versatile (2)
  • Bright (1)
See less See more
Cons
  • Dead pixels (1)
  • Narrow viewing angle (1)
  • No support mount back (1)
  • No usb hub (1)
  • Viewing angles (1)
Best Uses
  • Gaming (2)
  • Multimedia (2)
  • Photo editing (2)
  • All around use (1)
  • Desktop (1)
  • Hooked to a laptop (1)
  • Word processing (1)
Provided by Overstock.com
24" wide digital LCD monitor offers a 160 degree/160 degree viewing angle, DVI with HDCP interface, 1920 x 1200 resolution, 16.7 million display colors, 5 millisecond response time, a 16:10 aspect ratio and a 400 cd/m squared brightness. MagicBright provides optimal combination setting for the various contents. With one click, you can control OSD easily. Dynamic contrast ratio of 3000:1 delivers crisp easy-to-view images. MagicColor improves hue and saturation of colors, and adjusts mid-level colors to shades that the human eye accepts as natural. Height adjustable LCD monitor has a narrow bezel.*Manufacturer: Samsung *Manufacturer Part Number: 245BW *Manufacturer Website Address: www.samsungusa.com *Product Name: SyncMaster 245BW Widescreen LCD Monitor *Product Type: LCD Monitor *Actual Screen Size: 24", 24" *Widescreen: Yes *Viewable Screen Size: 24" *Pixel Pitch: 0.27mm, 0.27mm *Dot Pitch: 0.27mm *Response Time: 5 ms *Viewing Angle: 160° Horizontal / 160° Vertical *Maximum Response Time: 5ms, 5ms *Aspect Ratio: 16:10 *Horizontal Viewing Angle: 160°, 160 *Vertical Viewing Angle: 160°, 160 *Maximum Resolution: 1920 x 1200, 1920 x 1200 *Aspect Ratio: 16:10 *Brightness: 400 Nit *Aspect Ratio: 16:10 *Contrast Ratio: 1000:1 *Brightness: 400 Nit *Ports: DVI-HDCP *Color: Black *Green Compliance: Yes *Green Compliance Certificate/Authority: EPEAT Silver *Country of Origin: Mexico
Specification Description
Model 245BW, 245BWTAA
UPC 729507801032
Select Flat Panel LCD
Viewable Size 24"
Samsung 245BW 24" Widescreen LCD Monitor Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 245BW 24" Widescreen LCD Monitor
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 4, 2009
Samsung 245BW 24" Widescreen LCD Monitor Reviews
Most helpful positive review
[6 of 7 customers found this review helpful]
Most helpful negative review
[13 of 14 customers found this review helpful]
4.0
Works on my older Dimension 8300
"Pros Great price. Swivel stand is very adjustable. More than $200 cheaper than the Dell 2407. No dead pixels. Crisp vivid colors. When I first turned on the monitor with the Grand Canyon as my Windows background, I really felt like I was going to fall in. Cons I agree with corgi1's assessments. I do see his point as far as the color change when shifting more than 30 on a horizontal plane. If you stare dead on a..." Read Full Review »
Aug 01, 2007 by ctowndave
See more positive Samsung 245BW 24" Widescreen LCD Monitor reviews
3.0
Just got one today, used it about 3 hours
"Pros Nice display, good price. Sharp text. Ran a display calibration and test program and the monitor passed every test beautifully, the imaging is impressive if you don't move your head up or down (see below). Nice menu and controls. Monitor syncs up to the video signal in about 1 second, which is 5 times faster than my old Samsung 19". The stand elevation range is excellent and the swivel works well. Cons Thi..." Read Full Review »
Jul 23, 2007 by allenc3
See more negative Samsung 245BW 24" Widescreen LCD Monitor reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
3.0
"Pros
Monitor syncs up to the video signal in about 1 second, which is …"  Read Full Review »
Was this LCD Monitor review on the Samsung 245BW 24" Widescreen LCD Monitor helpful to you?
 Report Abuse  (13)  (1)  0 comments
Jul 23 2007
allenc3
Richmond, VA
Reviewed at:
[14 of 15 customers found this review helpful]
Disappointing
2.0
"Pros
Nice mechanical design. Height adjustment is easy and smooth. Glossy frame was not a distraction to me. Controls are straightforward.
Cons
Horrible variation in brightness when moving head up and down. Only 20 degrees useful angle. Slouching after sitting straight causes OBVIOUS darkening of t …"  Read Full Review »
 Report Abuse  (14)  (1)  0 comments
Sep 3 2007
WVCVCA
CA
Reviewed at:
4.0
"Pros
Cons
I agree with corgi1's assessments. I d …"  Read Full Review »
 Report Abuse  (6)  (1)  0 comments
Aug 1 2007
ctowndave
Undisclosed
Reviewed at:
[24 of 26 customers found this review helpful]
Just got it.
5.0
"Pros
Has great contrast ratio and has better color on the screen than my dell 2405
Cons
None so far
Review
Good no frills 24" monitor with great performance. "
 Report Abuse  (24)  (2)  0 comments
Jun 25 2007
a2techie
Ann Arbor, MI
Reviewed at:
[1 of 1 customers found this review helpful]
Great Value
4.0
    Pros
  • Adjustable
  • Sharp Image
  • Versatile
  • Vivid Colors
    Cons
    Best Uses
  • All around use
  • Photo Editing
"Used For-Professional photo editing Remote Support Email / WebThis is a great monitor IMO. It can be found for [$] now. It does not have a cheap feel or look in my view. The colors are spot on, even after having calibrated with a Spyder there was very little change. The viewing angle was fine, altho …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Mar 22 2008
Dan
Philadelphia, PA
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
