Samigon V-H Flip Bracket System Deluxe
3.0
based on 3 reviews
Ratings Distribution
5 star
0
4 star
0
3 star
3
2 star
0
1 star
0
Category Average
4.1
Pros
  • Improves performance (1)
  • Softens light (1)
  • Well built / quality construction (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Poor interface (1)
  • Unreliable storage (1)
Best Uses
  • Fill flash (1)
  • Lighting (1)
  • Night photography (1)
  • Photography (1)
  • Photojournalism (1)
  • Shooting indoors (1)
  • Shooting outdoors (1)
  • Sports photography (1)
Provided by B&H Photo Video
The Samigon V H Flip Bracket Deluxe is designed for both digital and traditional 35mm SLR cameras. It allows photographers to flip their camera from Vertical to Horizontal without changing flash position. This flip motion is smooth and does not require any locking or unlocking enabling the photographer to go from vertical to horizontal as quickly as the action dictates.The flash is mounted on a plate attached to two telescoping sections extending up to 28 high to eliminate shadow and red eye.The Samigon V H Flip Bracket Deluxe has a specially designed platform that folds up neatly when not in use so that it occupies very little space in a camera bag. A sliding camera mount allows the camera to be centered under the flash no matter where the tripod mount is located on the camera. There is also a large rubber handgrip so the photographer can easily carry the camera and flash.
Samigon V-H Flip Bracket System Deluxe Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: V-H Flip Bracket System Deluxe
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 15, 2009
Samigon V-H Flip Bracket System Deluxe Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Almost a good idea
3.0
    Pros
  • Softens Light
  • Strong Construction
    Cons
  • Bulky
  • Poor Interface
  • Unreliable Storage
    Best Uses
  • Fill Flash
  • Lighting
  • Night Photography
  • Photography
  • Photojournalism
  • More »
"The bracket provides many options for mounting a flash. It locks the camera in the portrait position which helps avoid the harsh shadow on the side of the subject you would get with a camera mounted flash.
The bracket does not lock in the landscape position, so the camera tends to tilt to the ri …"  Read Full Review »
Was this Camcorder Accessory review on the Samigon V-H Flip Bracket System Deluxe helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 28 2008
Stas
Central Jersey
I am:
  • Semi-pro Photographer
Reviewed at:
Unstable without lock
3.0
    Pros
  • Improves Performance
    Cons
  • None
    Best Uses
  • Shooting Indoors
  • Shooting Outdoors
"The product works great in the landscape position, but trying to keep it upright in the portrait position is difficult without a lock, so when shooting a wedding for 6 to 8 hours it gets a little bothersome. I don't have a problem working with it for a very short time, but next time i will definat …"  Read Full Review »
Oct 15 2009
Stephanie Dawn
Albuquerque, NM
Reviewed at:
[2 of 2 customers found this review helpful]
Flawed but functional
3.0
"Horizontal rail mount for camera does not lock. This is aproblem because the rail tends to rest at a 30 degree angle.Also you must hold the bracket in the selected position ifyou use a larger camera like the D2X. I added a screw tolock the bracket into position once it is set. Works ok forsmaller or …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
May 16 2007
Undisclosed
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
