Rf Link 5.8 GHz Wireless Audio/Video Sender/Receiver
4.1
based on 108 reviews
from $116.95 - $169.99
Ratings Distribution
5 star
49
4 star
42
3 star
6
2 star
3
1 star
8
Category Average
4.0
More Images
Pros
  • Easy to use (74)
  • Highly compatible (34)
  • Lightweight (25)
  • Improves performance (22)
  • High quality (21)
  • Lots of features (3)
  • Well built / quality construction (3)
  • Consistent performance (2)
  • Easy setup (2)
  • Easy to configure (2)
See less See more
Cons
  • Poor performance (9)
  • Lacks functionality (5)
  • Limited compatibility (5)
  • Difficult to use (2)
  • Ac adapters are junk (1)
  • Alignment sensitive (1)
  • Big and bulky (1)
  • Can not connect to coax (1)
  • Line of sight transmissio (1)
Best Uses
  • Home movies (19)
  • Complex projects (3)
  • Home (3)
  • Independent films (2)
  • Studio (2)
  • Adding a tv without coax (1)
  • As wireless coaxial (1)
  • Audio video transmission (1)
  • Condo (1)
  • Connect tivo and dvd (1)
Provided by Beach Audio
The 5.8GHz wireless video/audio sender consists of one transmitter and one receiver. This device transmits wirelessly vivid video and hi-fi stereo sound from a VCR,TV set, LD, DVD, VCD, Satellite Receiver or cable set top box to any TV or monitor. It can also be used in conjunction with a camcorder or CCD camera and turns into a wireless security monitoring system. As to the transmission capability, the signal can go up to 400 feet clear light-of-sight and even penetrate wall. With the built-in IR remote extender, it allows the user to remotely control the audio/video sources in the other rooms. In addition, four user selectable channels allows multiple transmitters to multiple receivers operation in the same area. All these advanced features will make your home life with amazing convenience and joy.
Specification Description
Model 76540, AVS-5811, AVS5811
UPC 731390012020
Accessory Indicator Yes
Antenna compatible Yes
Benefits Transmit and receive crisp video and hi-fi stereo even through wallsAvoid the interference from crowded 2.4GHz ISM band applications<
Cable box compatible Yes
Capacity UOM mAh
Cordless/Wireless Yes
Country Of Origin China
Description Header Go through walls.
Display Catalog Number 55016513
Features Long transmission range up to 300 feet for clear line of sightSimultaneous viewing of video programs on a 2nd TV/monitor without wire
Included in the Box 5.8GHz transmitter5.8GHz receiverIR mouse2 fasten strips2 power adapters (120V)2 RCA cables (A/V)
Manufacturer Labor Warranty 12
Manufacturer Part Number AVS-5811
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 122 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model AVS-5811
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type Signal sender/receiver
Product Weight UOM pounds
Radio Channel Qty 4 Channels
Radio Frequency Range 30-12000Hz
Satellite compatible Yes
Supported Languages English
Transmission Range 300
Rf Link 5.8 GHz Wireless Audio/Video Sender/Receiver Questions
Questions and Answers
Where to Buy
$116.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$144.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$169.99
Code FALLSAVINGS33 : $5 Off Orders Over $50
Product Reviews
Last update: Oct 22, 2009
Rf Link 5.8 GHz Wireless Audio/Video Sender/Receiver Reviews
Most helpful positive review
Most helpful negative review
5.0
Exceeded My Expectations
"I am being truly honest about this product, as you should know by my only negative comment. I previously had a 2.4 Terk Leapfrog that snapped, crackled, and popped only 45 ft. away. It only had one glass door in it's way. I had to spend a lot of time adjusting the antenna's just to receive mediocre with some noise and interference at best. The microwave would totally destroy the picture with the Terk. This RF-Li..." Read Full Review »
Jun 03, 2009 by Jake The Moonshiner
See more positive Rf Link 5.8 GHz Wireless Audio/Video Sender/Receiver reviews
3.0
solid but short range and common infared
"The audio and video are the only signals that travel over RF. The infared repeater travels over UHF and travels the opposite direction of the A/V. Also when using a "multiple channel" setup with 5 units, all the infared signals are sent to all units....not all that practical when your expecting seperate channels. Would only recomend this in very specific situations and not in professional settings...." Read Full Review »
Aug 12, 2008 by timelight
See more negative Rf Link 5.8 GHz Wireless Audio/Video Sender/Receiver reviews
Displaying 1 - 5 of 108 Reviews
Show
Sort by
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
  • Improves Performance
  • Professional Quality
    Cons
  • AC Adapters are junk
    Best Uses
  • Wireless outside TV
"I am being truly honest about this product, as you should know by my only negative comment. I previously had a 2.4 Terk Leapfrog that snapped, crackled, and popped only 45 ft. away. It only had one glass door in it's way. I had to spend a lot of time adjusting the antenna's just to receive mediocre …"  Read Full Review »
Was this Professional Video Equipment review on the Rf Link 5.8 GHz Wireless Audio/Video Sender/Receiver helpful to you?
Jun 3 2009
Jake The Moonshiner
Harmony Hills, Wi
I am:
  • Hobbyist
Reviewed at:
Price: $144.99
[1 of 1 customers found this review helpful]
Works Ok
4.0
    Pros
  • Compact Design
  • Easy To Use
    Cons
  • Periodic Popping Noise
    Best Uses
  • None
"Hi I got this device because there was no way for me to get a cable jack put on the wall where I wanted the TV. The ceiling in the room is concrete. The floor is concrete with carpet over it and I did not want to run the cable under the carpet.
The current cable jack and box is 15ft across the ro …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 21 2009
Capt. Mike
Panama City Beach, FL
I am:
  • Condo Home Owner
Reviewed at:
Price: $144.99
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Deck TV
"I put a new awning on my deck this year and promised my wife it would also include an outdoor TV. I purchased the RF-Link (AVS-5811) 5.8GHz Wireless A/V Sender system with plans to attach it to a new AOC 22" LCD TV and my indoor cable converter box. [...] the entire installation process took only …"  Read Full Review »
Jul 22 2009
Carl "Living on the Deck"
Pittsburgh, PA
I am:
  • Hobbyist
Reviewed at:
Price: $144.99
Works for me
5.0
    Pros
  • Easy To Use
  • Quality Construction
    Cons
  • None
    Best Uses
  • Home Movies
"I needed to get the DSS/DVR from the living room to another room in the house about 25 yards apart. There is some plumbing in the wall between the rooms. I tried some 2.5 GHZ units a long time ago and took them back because they did not work very well. I had a pair of leapfrog telephone wire repeate …"  Read Full Review »
Aug 31 2008
bobk
Las Vegas NV
I am:
  • Tech Savvy
Reviewed at:
Price: $116.95
This saved me having to buy another Tivo
4.0
    Pros
  • Easy To Use
  • Good Value
    Cons
  • None
    Best Uses
  • Condo
"I was going to buy a second Tivo DVR for my bedroom when I stumbled upon the AVS-5811 on [...] I hooked it up to my bedroom 26" HDTV. Setup took a little adjustment, approximately 15 minutes, of both the transmitter and reciever antennas. Although by no means a true HD picture, it's very good qualit …"  Read Full Review »
Jul 15 2008
Dennis
Baltimore
I am:
  • Gadget Geek
  • Tech Savvy
Reviewed at:
Price: $116.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$116.95
$144.99
$169.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
