RCA Dect 6.0, 2 Line Cordless Phone with Digital Answering System, 1 ea
#284
3.1
based on 5 reviews
Ratings Distribution
5 star
11
4 star
4
3 star
3
2 star
4
1 star
10
Category Average
3.8
Low Price:
$138.95 at Factory Outlet Store
$139.95 at Best Buy
Find it at Amazon
$138.95 - $198.59
from 9 stores
More Images
Pros
  • Comfortable handset (14)
  • Compact design (13)
  • Nice features (13)
  • Easy setup (11)
  • Nice sound (10)
  • Good speakerphone (9)
  • Strong signal (9)
  • Wide range (9)
  • Durable (6)
  • Clear reception (5)
See less See more
Cons
  • Poor sound quality (6)
  • Poor battery life (4)
  • Not durable (3)
  • Confusing / difficult controls (2)
  • Creates static (2)
  • Lacks features (2)
  • Clicking noise (1)
  • Control buttons tiny (1)
  • Drops calls (1)
  • Limited range (1)
Best Uses
  • Everyday (11)
  • Office (9)
  • Home use (5)
  • Multiple lines (5)
  • Conference calls (3)
  • Long talks (2)
  • Application not using dsl (1)
  • High call volume (1)
  • High-volume (1)
  • Home office 2 line (1)
Provided by Beach Audio
  • Dect 6.0
  • 60 minute record time on answering machine
  • Base and handset speakerphone
  • Call waiting/Caller ID
  • 10 programmable one touch speed dials
  • 100 name/number caller ID records
  • Line status visual indicators
  • 2-line conferencing
  • Do not disturb/privacy setting
  • Intercom with handset paging feature
  • Expandable up to 10 cordless handsets per base unit
  • Specification Description
    Model 044319703566, 25250RE1, RCA-25250RE1
    UPC 044319703566
    Call ID / Call Wait Display Capable Capable with service from phone carrier
    Capable of adding additional Handsets Optional
    Cordless Frequency 1.9GHz - DECT
    Flash / Hook-Flash Yes
    Handset Locator Yes
    Handsets Included 1
    Headset Capable Yes - Optional Headset Required
    Intercom (Base and Handset) Yes
    Keypad On Base and Handset
    Maximum Number of Extensions Up to 10 Handset Extension Capable
    Message Indicator Visual
    Multifunction Display Screen On Handset and Phone Body
    Page (Base and Handset) Yes
    Product Details This is a 2-Line DECT 6.0 Cordless Expandable Phone System with Integrated Digital Answering System.  Don?t miss important messages anymore with the 60 Minute Record Time.  Get in touch quickly using the 10 programmable one-touch speel dials and 100 name/number caller ID records.
    Redial Yes
    Remote Access of Messages Yes
    Ringer Adjustable Volume
    Selective Save/Delete of Messages Yes
    Speakerphone Yes
    Speed Dial Phone Memories 10
    Telephone Answering Machine Yes
    Telephone Lines 2
    Voice Mail Boxes 2
    RCA Dect 6.0, 2 Line Cordless Phone with Digital Answering System, 1 ea Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 29, 2009
    RCA Dect 6.0, 2 Line Cordless Phone with Digital Answering System, 1 ea Reviews
    Most helpful positive review
    [1 of 1 customers found this review helpful]
    Most helpful negative review
    [17 of 22 customers found this review helpful]
    5.0
    Getting Another Identical Phone
    "This RCA 2-line phone is used at a fast-paced B&B. We are getting an identical replacement today because Line 1 acts like it won't "hang up" but you need to remember that the hands-free unit has been dropped repeatedly over two years as we are always frantically working around the inn. A few days ago we replaced the hands-free battery after two years of constant, hard use, but "Line 1" still has the problem of w..." Read Full Review »
    Oct 17, 2009 by The B&B Innkeeper
    See more positive RCA Dect 6.0, 2 Line Cordless Phone with Digital Answering System, 1 ea reviews
    1.0
    This phone is actually an RCA product
    "Answering machine cut people off after about 10 seconds. Called support department and was told that answering system was not compatible with DSL. If you are a small business and have DSL on your phone line AND want the answering machine to work -- this is NOT the phone for you. I had customers think they were leaving messages that we never received. This purchase was very bad for customer satisfaction in my..." Read Full Review »
    Jun 06, 2008 by Small Business Owner
    See more negative RCA Dect 6.0, 2 Line Cordless Phone with Digital Answering System, 1 ea reviews
    Displaying 1 - 5 of 5 Reviews
    Show
    Sort by
    A GREATPRODUCT THAT WORKS AS PROMISED
    5.0
      Pros
    • Comfortable Handset
    • Compact design
    • Easy To Set Up
    • Good Sound
    • Nice Features
      Cons
    • None
      Best Uses
    • Everyday Use
    "Excellent high quality phone system that facilitates having a phone in every room in the house. Intercm system is added plus.
    Better quality phone system that is used with the two phone lines in our home. "
    Was this Cordless Telephone review on the RCA Dect 6.0, 2 Line Cordless Phone with Digital Answering System, 1 ea helpful to you?
    Oct 30 2008
    SCGBILL
    Surprise, AZ
    I am:
    • Quality Oriented
    Reviewed at:
    Great quality, great sound
    5.0
      Pros
    • Compact design
    • Easy To Set Up
    • Good Sound
    • Nice Features
    • More »
      Cons
    • None
      Best Uses
    • Everyday Use
    • Mulitple rooms
    "Used for home Business, and Personal line, 1 line is currently used with IP line and works very well "
    Aug 7 2008
    Stan
    Carson, CA
    I am:
    • Quality Oriented
    Reviewed at:
    Does Not Work- Will not charge
    1.0
    "I have purchased two of these phones with the same problem. They do not charge on the base. I have to charge both handsets on my extra charger. So I have to swap the phones every day just to keep them charged. I would not recommend buying this phone. "
    Mar 11 2009
    ttoledan
    Slidell, LA
    Reviewed at:
    Price: $139.95
    Stinks
    1.0
    "Stay away from this phone. While packed with features at one of the lowest prices for a 2 line cordless, the sound quality is so bad that it is virtually useless "
    Sep 5 2009
    ExNJ
    los angeles
    Reviewed at:
    Price: $139.95
    so far so good
    3.0
      Pros
    • Clear Reception
      Cons
    • Stand is micky
      Best Uses
    • Conference Calls
    • Multiple Lines
    • Speaker phone
    "stand should be part of phone "
    Jul 17 2008
    rball
    colorado
    I am:
    • Tech Savvy
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
