Close Login Module
Join
RCA ANT1500 Flat Multi-Directional Indoor HDTV Antenna
#227
3.2
based on 30 reviews
Ratings Distribution
5 star
11
4 star
5
3 star
1
2 star
4
1 star
9
Category Average
3.9
$24.97 - $59.99
from 6 stores
More Images
Pros
  • Fast setup (7)
  • Attractive design (6)
  • Improved audio/video (4)
  • Simple controls (3)
  • Easy setup (1)
  • Easy to mount (1)
  • Simple to install and use (1)
  • Strong signal (1)
See less See more
Cons
  • Does not improve audio/video (2)
  • Cable position critical (1)
  • Needs amplifier (1)
  • Not as described (1)
  • Poor reception (1)
Best Uses
  • Home (7)
  • Bedroom installiation (1)
  • In strong signal areas (1)
  • Living room (1)
  • Office (1)
Where to Buy
$24.97
$30.23
BizRate Rating Outstanding 9.1
$30.99
Show all 6 stores
Product Reviews
Last update: Sep 16, 2009
RCA ANT1500 Flat Multi-Directional Indoor HDTV Antenna Reviews
Most helpful positive review
Most helpful negative review
5.0
Great product[...]
"I'm a seasoned technician with lots of experience in electronic equipment. For that reason I did lots of technical research and found this product to be good and worth trying. I was not disappointed at all. [[...]] I set it up which was really easy and love the way it works. I would certainly buy it again and may buy another one for my other TV...." Read Full Review »
Sep 16, 2009 by Perry the meter guy
See more positive RCA ANT1500 Flat Multi-Directional Indoor HDTV Antenna reviews
2.0
Antenna is not amplified
"It did much better when I added my amplifier, but should have had its own. Even then, the cable for hooking to the tv acts as part of the antenna and must be placed with trial-and-error checks to make sure reception is not compromised on one or more channels. If it had an amplifier at or in the antenna, this shouldn't be a problem...." Read Full Review »
Jun 23, 2009 by Brotherrobin
See more negative RCA ANT1500 Flat Multi-Directional Indoor HDTV Antenna reviews
Displaying 1 - 5 of 30 Reviews
Show
Sort by
Great product[...]
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Improved Audio/Video
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I'm a seasoned technician with lots of experience in electronic equipment. For that reason I did lots of technical research and found this product to be good and worth trying. I was not disappointed at all. [[...]] I set it up which was really easy and love the way it works. I would certainly bu …"  Read Full Review »
Sep 16 2009
Perry the meter guy
Elkhart, IN
I am:
  • Casual User
Reviewed at:
Price: $24.97
2.0
    Pros
  • Attractive Design
  • Easy to mount
  • Fast Setup
    Cons
  • Does Not Improve Audio/Video
  • Needs amplifier
  • Not as described
    Best Uses
  • Home
"It did much better when I added my amplifier, but should have had its own. Even then, the cable for hooking to the tv acts as part of the antenna and must be placed with trial-and-error checks to make sure reception is not compromised on one or more channels. If it had an amplifier at or in the ante …"  Read Full Review »
Jun 23 2009
Brotherrobin
Central Texas
I am:
  • Power User
Reviewed at:
Price: $30.23
[1 of 1 customers found this review helpful]
OKAY BUT NOT GREAT
3.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"BOUGHT THE RCA (FORMERLY WORKED AT THE COMPANY). PLUGGED IN TO THE CONVERTER BOX AND GOT GOOD RESULTS ON CHANNELS 2-4-5-9 AND SOME NEW FOREIGN LANGUAGE STUFF IN THE 40 and 50's. CAN NOT GET CHANNELS 7 and 13. RETURNED ANTENNA TO BEST BUY NOW LOOKING FOR SOMETHING A BIT STRONGER TO TRY AND BRING IN …"  Read Full Review »
Jun 22 2009
SAM
SOOUTH ORANGE,NJ
I am:
  • Casual User
Reviewed at:
Price: $30.23
Great Antenna Works Like a Charm
5.0
"Not sure why this antenna doesn't get better reviews from others but this antenna works absolutely PERFECT on my Sharp Aquos tv. I get all the channels I want (2.1, 4.1-4.4, 5.1, 7.1-7.3, 9.1, 11.1, and 31.1) except for the PBS ones. Not sure why they are hard to get. Now I only use the antenna to a …"  Read Full Review »
Oct 13 2008
LoneRanger1975
Howard Beach, NY
Reviewed at:
Improved TV Reception
4.0
    Pros
  • Attractive Design
  • Fast Setup
    Cons
  • None
    Best Uses
  • Home
"Extremely simple to set up; improves the quality of the HD receive box I purchased for my non-HD television. Reception in our area can be difficult because of the many high towers located around town that seem to generate interference issues. This antenna has helped significantly! And with J&R's …"  Read Full Review »
Jul 28 2009
Clergyman D
Needham, MA
I am:
  • Casual User
Reviewed at:
Price: $24.97
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
