RCA ANT1400 Flat Multidirectional Passive Indoor HDTV Antenna
#238
3.2
based on 58 reviews
Ratings Distribution
5 star
17
4 star
11
3 star
9
2 star
9
1 star
12
Category Average
3.9
Low Price:
$15.64 at Meijer.com
 Trusted:
$18.99 at TigerDirect
$18.99 at CompUSA
see all stores
$15.64 - $29.99
from 16 stores
More Images
Pros
  • Attractive design (4)
  • Fast setup (3)
  • Simple controls (3)
  • Improved audio/video (1)
See less See more
Cons
  • Actually less receptive (1)
  • Does not improve audio/video (1)
  • Terrible when it rained (1)
Best Uses
  • Home (2)
  • As a door stop (1)
Provided by Kmart
. RCA digital, flat, passive home theater antenna is multi-directional and receives free uncompressed digital signals from local HDTV and DTV as well as analog UHF and VHF. More free channels with easy-to-use effective parental controls and enhanced services such as digital closed-captioning. Preview digital reception at www.StayTuned2TV.com. Patented design outperforms traditional antennas with no need for constant adjustments, since signals are received from 360-degrees. Sleek white design can be hung or laid flat to disappear into its surroundings, and is backed by a 1-year limited warranty.
Specification Description
Model ANT1400, RCA1400, RCAANT1400
UPC 044476058868
color null
Country Of Origin China
size null
sku 152125
skuprice 29.9900
style ANT1400
taxable Y
RCA ANT1400 Flat Multidirectional Passive Indoor HDTV Antenna Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 8, 2009
RCA ANT1400 Flat Multidirectional Passive Indoor HDTV Antenna Reviews
Most helpful positive review
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Excellent HD reception!
"First, in order to get HD use out of this antenna, your tv has to have an HD tuner built in. I took this out of the box and connected it to my tv using the coxial cable port. Then used my tv to scan for all channels (if you just type in 5 for channel 5, it may not be the HD channel...our HD channel is 5-1). It is amazing how well the reception is and that it is in HD. I live in the city limits so I am only 15 ..." Read Full Review »
Jun 11, 2009 by theapoplectic1
See more positive RCA ANT1400 Flat Multidirectional Passive Indoor HDTV Antenna reviews
2.0
Not Worth The Money
"I replaced the 'Flat Antenna by RCA' with the Rabbit Ears that I originally had been using. They worked much better during a storm because of it's built-in 'fine tuning knob', and the Rabbit Ears received three additional channels than the RCA unit!..." Read Full Review »
Mar 20, 2009 by Retired and Loving It
See more negative RCA ANT1400 Flat Multidirectional Passive Indoor HDTV Antenna reviews
Displaying 1 - 5 of 58 Reviews
Show
Sort by
Doesn't work for weak signals
3.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"This antenna is good-looking and extremely simple to set up, but it does not improve weak signal reception. I returned it in favor of one that does. "
Was this TV Accessory review on the RCA ANT1400 Flat Multidirectional Passive Indoor HDTV Antenna helpful to you?
Nov 8 2009
Luddite
Brooklyn, NY
I am:
  • Casual User
Reviewed at:
Price: $22.99
Not Worth The Money
2.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • Actually Less Receptive
  • Does Not Improve Audio/Video
  • Terrible When it Rained
    Best Uses
  • As a Door Stop
They worked much better during a storm because of it's built-in 'fine tuning knob', and the Rabbit Ears received three additional channels than the RCA unit! "
 Report Abuse  (2)  (0)  0 comments
Mar 20 2009
Cincinnati, Ohio
I am:
  • Enthusiast
Reviewed at:
Price: $15.64
Problems may be due to HDTV technology!
3.0
"I purchased two flat TV's and don't have cable service. Depending on where I place the TV within my home, the reception varies considerably.
This with either the digital conversion box or a digital television. I did try moving "problematic" televisions to other rooms and again, it seemed to be cons …"  Read Full Review »
Jun 8 2009
kitcatvi
Philadelphia, PA
Reviewed at:
Price: $26.99
Not worth it
2.0
"The setup of this device was very quick and simple. Merely take it out of the box and connect the coaxial line to the back of your TV and you're done; that easy. The antenna itself is made of cheap plastic and wires. Could easily break, but usually antennas are not thrown around. For $30.00 it is no …"  Read Full Review »
Aug 23 2009
Madison, WI
Reviewed at:
Price: $26.99
5.0
I took this out of the box and connected it to my tv using the coxial cable port. Then used my tv to scan for all channels (if you just type in 5 for channel 5, it may not be the HD channel...our HD channel …"  Read Full Review »
Jun 11 2009
theapoplectic1
Nashville, TN
Reviewed at:
Price: $26.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
