Close Login Module
Join
Raynox HD-3032PRO, 37mm, 0.3x, Semi-Fisheye Conversion Lens
#113
4.1
based on 18 reviews
Ratings Distribution
5 star
7
4 star
7
3 star
2
2 star
2
1 star
0
Category Average
4.5
$99.95 - $104.95
from 2 stores
More Images
Pros
  • Great picture quality (8)
  • Easy to use (7)
  • Interfaces well with camcorder (4)
  • Compact design (3)
  • A bit zoomable (1)
  • Affordable (1)
  • Durable (1)
  • Good interface with camcorder (1)
  • Great build quality (1)
  • Great in 4x3 photo too (1)
See less See more
Cons
  • Bulky design (2)
  • No increase in performance (1)
  • Poor clarity (1)
  • Useless for close-up magn (1)
Best Uses
  • Shooting outdoors (8)
  • Shooting indoors (6)
  • Close up filming (4)
  • Panoramic filming (3)
  • Pov point of view (1)
  • Replacement (1)
  • Skydiving (1)
  • Upgrade (1)
Where to Buy
BizRate Rating Outstanding 9.1
$99.95
BizRate Rating Outstanding 9.6
$104.95
No Tax Outside NY
Product Reviews
Last update: Oct 2, 2009
Raynox HD-3032PRO, 37mm, 0.3x, Semi-Fisheye Conversion Lens Reviews
Most helpful positive review
Most helpful negative review
4.0
Great Price Point & Quality
"This is my first video adapter lens that I bought and I am completely happy with it. The build quality is better than I expected. I was expecting a cheap plasticky lens but it is solidly built. I'm not sure what exactly it is made of but it "feels" like heavy duty aluminum without being too heavy. I also like the black finish compared to the silver finish from Canon and other brands so it matches the color of m..." Read Full Review »
Oct 02, 2009 by Nikkorray
See more positive Raynox HD-3032PRO, 37mm, 0.3x, Semi-Fisheye Conversion Lens reviews
3.0
"Sturdy design, all in all fairly good glass optics, there is apparent vignetting on the extreme wide position, not functioning very nicely on zoom. loads of aberration. for its value of money, probably good..." Read Full Review »
Apr 14, 2008 by ermitikos
See more negative Raynox HD-3032PRO, 37mm, 0.3x, Semi-Fisheye Conversion Lens reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
4.0
    Pros
  • Compact Design
  • Easy To Use
    Cons
  • None
    Best Uses
  • Close Up Filming
  • Shooting Indoors
"This is my first video adapter lens that I bought and I am completely happy with it. The build quality is better than I expected. I was expecting a cheap plasticky lens but it is solidly built. I'm not sure what exactly it is made of but it "feels" like heavy duty aluminum without being too heavy. …"  Read Full Review »
Oct 2 2009
Nikkorray
Denver, CO
Reviewed at:
Price: $104.95
[1 of 1 customers found this review helpful]
Great Lens for the price
5.0
    Pros
  • Improves Picture Quality
  • Interfaces Well With Camcorder
  • Looks excellent
  • Minimal Distortion
  • More »
    Cons
  • None
    Best Uses
  • Panoramic Filming
  • Shooting Indoors
  • Shooting Outdoors
"Using this lens on Sony SR-12. I use this as 3rd camera to Sony FX1 and Z1.
Very clear throughout picture. Lens has VERY acceptable distortion on edges. I have used two other lenses in this price range and they are not even close in picture quality.
I'm very very happy with the price to perfor …"  Read Full Review »
Oct 14 2008
Cliff
Hollywood, Florida
I am:
  • Aspiring Film Maker
  • Professional Videographer
  • Tech Savvy
Reviewed at:
Price: $104.95
I really like this lens
4.0
    Pros
  • Easy To Use
    Cons
  • None
    Best Uses
  • Close Up Filming
  • Shooting Indoors
  • Shooting Outdoors
"This would get 5 stars if it didn't have the plastic threads!!
I wanted a wide angle that would be wide enough but not a fisheye. So I tried this lens to have fun with the kids. I really like the semi fisheye effect. I also like that I can zoom the camera in a little and nearly remove the fish …"  Read Full Review »
Aug 19 2008
Pauly Forte
Bucks County, PA
I am:
  • Tech Savvy
Reviewed at:
Price: $104.95
Great Wide Angle Fish-Eye lens for HV30
5.0
    Pros
  • Compact Design
  • Easy To Use
    Cons
  • None
    Best Uses
  • Close Up Filming
  • Panoramic Filming
  • Shooting Indoors
  • Shooting Outdoors
  • Upgrade
"I use this on my Canon HV30 and it fit fine and the camera retains its crisp sharp image quality but now in a fish-eye format. The lens shows no vignetting when zooms all the way out. I can zoom to about 5x out of the 10x before the image quality in effected. Overall a great product, I love it. The …"  Read Full Review »
Oct 15 2008
Chiefredbeard
Fort Wayne, IN
I am:
  • Tech Savvy
Reviewed at:
Price: $104.95
[0 of 1 customers found this review helpful]
This lens is wide and sharp
5.0
    Pros
  • Easy To Use
  • Excellent picture Quality
  • Very WA field of view
    Cons
  • None
    Best Uses
  • Panoramic Filming
  • POV point of view
  • Shooting Indoors
"I bought this lens for my Sanyo VPC-FH1 and so far it has been better than expected. It is very wide and like it's description says it has a semi-fisheye effect. I use it mostly for p.o.v. shots where you don't have much room. So far I would say it has low CA and is very sharp compared to other W/A …"  Read Full Review »
Jul 1 2009
Lucasberg
Garden Grove, CA
I am:
  • Parent
  • Tech Savvy
Reviewed at:
Price: $104.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$99.95
$104.95
No Tax Outside NY
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
