Radio Shack XMODS Custom RC Rechargeable Batteries and Charger
#697
3.6
based on 14 reviews
Ratings Distribution
5 star
7
4 star
2
3 star
1
2 star
1
1 star
3
Category Average
3.9
$19.97 at RadioShack
Find it at Amazon
Find it at Ebay
$19.97
from 1 store
Pros
  • Reliable (5)
  • Good value (4)
  • Charges quickly (3)
  • Easy to use (3)
  • Good performance (3)
  • Charges aa and aaa (1)
  • Compact design (1)
  • Durable (1)
  • High quality (1)
  • Intelligent charger (1)
See less See more
Cons
  • Short life (4)
  • Inconsistent performance (3)
  • Lack of power (3)
  • Charges slowly (2)
  • Battery exploded (1)
  • Pricey (1)
Best Uses
  • Portable electronics (4)
  • Having around the house (2)
  • 12 and up (1)
  • Money saving (1)
  • The garbage (1)
  • Xmods vehicles (1)
Provided by RadioShack
Count on consistent, high-performance power with these eight rechargeable "AAA" Ni-MH batteries. Charge up to four "AA" or "AAA" batteries at once.
Specification Description
Model 350
Accessory Indicator Yes
Battery Finder Indicator Yes
Benefits Will charge four 1850mAh batteries in approximately 4 hoursAutomatically switches to trickle charge mode when batteries are fully cha
Body Material Plastic
Capacity UOM mAh
Country Of Origin China
Description Header Keep plenty of back-up power on hand.
Display Catalog Number 23-350
Enclosure Color Black
Equivalent to RC Vehicle, RC Car, RC Truck, RC Boat, XMODS
Features Includes 8 rechargeable AAA Ni-MH batteriesCharges either AA or AAACharging time approximately 4 hours with up to 4 1850mAh
Included in the Box Rechargeable AAA Ni-MH batteries (8) [23-527]ChargerOwner's manual
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 350
Operating Temperature UOM ° F
Product Type Combo packs
Supported Languages English
Radio Shack XMODS Custom RC Rechargeable Batteries and Charger Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 24, 2009
Radio Shack XMODS Custom RC Rechargeable Batteries and Charger Reviews
Most helpful positive review
Most helpful negative review
4.0
Nice charger
"Nice, no frills product, that is compact and a good value because it comes with 8 "AAA" batteries. Folded up, the charger and included batteries can fit in a coffee cup, so can be taken with you on trips for your portable electronics. It also charges "AA" batteries, so you can buy a few of those for various devices. Consumers should realize that fully charged, these batteries are ~1.35 volts, while alkaline ba..." Read Full Review »
Jan 27, 2009 by Metalcrack
See more positive Radio Shack XMODS Custom RC Rechargeable Batteries and Charger reviews
1.0
Not Happy with this
"I had the Radio Shack Recharge Batteries in the charger and one of the batteries exploded. If this charger is suppose to go to Trickle, then the battery should never explode. Could possibly be a battery. Nonetheless, I am not happy about either. If it hadn't exploded and just sit in the charger getting hot, it might have caught on fire instead. I would not recommend this. Go buy new batteries, Batteries are chea..." Read Full Review »
Aug 24, 2009 by trackermouse
See more negative Radio Shack XMODS Custom RC Rechargeable Batteries and Charger reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
Nice charger
4.0
    Pros
  • Charges Quickly
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Money Saving
  • Portable Electronics
"Nice, no frills product, that is compact and a good value because it comes with 8 "AAA" batteries. Folded up, the charger and included batteries can fit in a coffee cup, so can be taken with you on trips for your portable electronics. It also charges "AA" batteries, so you can buy a few of those for …"  Read Full Review »
Was this Battery review on the Radio Shack XMODS Custom RC Rechargeable Batteries and Charger helpful to you?
Jan 27 2009
Metalcrack
Cleveland, OH
I am:
  • Quality Oriented
Not Happy with this
1.0
    Pros
  • none
    Cons
  • Battery Exploded
    Best Uses
  • None
"I had the Radio Shack Recharge Batteries in the charger and one of the batteries exploded. If this charger is suppose to go to Trickle, then the battery should never explode. Could possibly be a battery. Nonetheless, I am not happy about either. If it hadn't exploded and just sit in the charger gett …"  Read Full Review »
Aug 24 2009
trackermouse
Conway, MO.
I am:
  • Quality Oriented
Great Charger
5.0
    Pros
  • Charges Quickly
  • Long Lasting
    Cons
  • None yet
    Best Uses
"Have had this charger for 5 years now still charges great, the batteries went out a couple of years ago but thats what rechargeable do they only retain good performance for a few years until they start surface charging (which means they wont last long in your device.) Works great for AA Ni-HMs. I us …"  Read Full Review »
Nov 15 2008
Vernon
Tulsa, OK
I am:
  • Value Oriented
[1 of 1 customers found this review helpful]
Definetly if you like ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Definetly if you like xmods and use them alot like me without a dout it is worth the money and it pays for its self within the first week definetly get this product if it werent for these batteries i will have spent probably $500 in batteries. I have had them for about 5 months and they arnt showing …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 17 2006
Shan L
Custer SD
[0 of 1 customers found this review helpful]
Great charger, Weak batteries
3.0
    Pros
  • Charges AA and AAA
    Cons
  • Short Life
    Best Uses
  • XMODs vehicles
"The included AA and AAA charger is very good. Will charge both NiCd and NiMH. The AAA batteries in kit are below average quality...after 20 charges and 6 months they lost more than half their power. "
 Report Abuse  (0)  (1)  0 comments
Jan 4 2008
MikeModder
Boston, MA
I am:
  • Quality Oriented
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
