Radio Shack Wireless Remote Extender
#2255
2.8
based on 78 reviews
Ratings Distribution
5 star
23
4 star
10
3 star
4
2 star
9
1 star
32
Category Average
4.1
$43.99 at RadioShack
Find it at Amazon
Find it at Ebay
$43.99
from 1 store
More Images
Pros
  • Consistent performance (19)
  • Versatile (11)
  • Good length (9)
  • Easy setup (8)
  • Rugged (6)
  • Attractive design (5)
  • Durable (3)
  • Good value (3)
  • High quality (3)
  • Compact (2)
See less See more
Cons
  • Inconsistent signal (16)
  • Incompatible (6)
  • Bulky (5)
  • No performance increase (3)
  • Wears out quickly (3)
  • Poor quality (2)
  • Antenna (1)
  • Bad directions (1)
  • Control only 1 unit (1)
Best Uses
  • High-end equipment (11)
  • Basic systems (4)
  • Entertainment (3)
  • Larger rooms (3)
  • Dorm room (2)
  • Smaller rooms (2)
  • Adjacent rooms (1)
  • Analprobe 4 radio shack (1)
  • Av system (1)
  • Budget buyer (1)
Provided by RadioShack
Don't get a new remote–just extend its power, from up to 100 feet away.
Specification Description
Model 15-1950
Antenna Features Telescoping
Benefits Use your existing remote control to operate audio or video equipment from any room in the house
Body Material Multi
Cable box compatible Yes
Capacity UOM mAh
Cordless/Wireless Yes
Country Of Origin China
Description Header More power to you.
Display Catalog Number 15-1950
Enclosure Color Black
End Product Indicator Yes
Features Installs in minutes-just plug transmitter and receiver into AC outlets at desired locations Even works when you can't easily place
Form Factor Built in
Included in the Box TransmitterReceiver12VDC adapterUser's Guide
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 15-1950
Operating Temperature UOM ° F
Outputs 1 x Phone 3/32"(IR Repeater)
Power Device Transmitter uses the included 12VDC adapter
Product Dimensions UOM INCHES
Product Height 2.625
Product Length 3.063
Product Type Signal sender/receiver
Product Weight 3.53
Product Weight UOM ounces
Product Width 3.875
Protect your investment. Yes
Radio Channel Qty 1 Channels
Radio Frequency Range 418
Satellite compatible Yes
Supported Languages English
Radio Shack Wireless Remote Extender Questions
Questions and Answers
Where to Buy
$43.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 30, 2009
Radio Shack Wireless Remote Extender Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Excellent Product
"The product was set up in my living room in ten minutes, but it wouldn't work with my Canon Vcc-50IR surveillance camera that looks out of my living room window. So I had the transmitter about fifteen feet from the remote and about 15 feet from the receiver. It worked, but only sometimes. Then I placed the little square receiver right on the window in front of the Camera sensor. Now it worked well enough that I ..." Read Full Review »
Jan 08, 2008 by Knowledge
See more positive Radio Shack Wireless Remote Extender reviews
2.0
Does not perform as advertised
".I purchased the remote extender to operate a cable box and a blu ray enclosed within my entertainment center. My initial set up had the repeater to control my cable, and the receiver controlling my blu ray;sensors positioned per manufacture recommendations.The transmitter was positioned on top of the entertainment center 2ft from the receiver. The blu ray did not work and the cable control was inconsistent. Rea..." Read Full Review »
Oct 20, 2009 by clemenite
See more negative Radio Shack Wireless Remote Extender reviews
Displaying 1 - 5 of 78 Reviews
Show
Sort by
2.0
    Pros
  • Price point
    Cons
  • Sensor placement
    Best Uses
  • Budget Buyer
".I purchased the remote extender to operate a cable box and a blu ray enclosed within my entertainment center. My initial set up had the repeater to control my cable, and the receiver controlling my blu ray;sensors positioned per manufacture recommendations.The transmitter was positioned on top of t …"  Read Full Review »
New set up
New set up
  • Made with Product
Transmitter position
  • Made with Product
Was this Audio Visual Cable & Connector review on the Radio Shack Wireless Remote Extender helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 20 2009
clemenite
Michigan
I am:
  • Power User
Reviewed at:
Price: $43.99
Very Tricky!!
3.0
    Pros
  • Very simple to install
    Cons
  • Instructions are unclear
    Best Uses
  • High-End Equipment
  • Home entertainment
"I am using this product to control my DVD and DirecTV Cable Box. I followed the simple but misleading instructions and installed everything very quickly. It worked very inconsistently, sometimes not at all. I looked at the reviews and was disheartened by the news that I was not alone. I felt ripped …"  Read Full Review »
May 11 2008
Hallelujah
Los Angeles, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $43.99
Excellent Product
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
"The product was set up in my living room in ten minutes, but it wouldn't work with my Canon Vcc-50IR surveillance camera that looks out of my living room window. So I had the transmitter about fifteen feet from the remote and about 15 feet from the receiver. It worked, but only sometimes. Then I pla …"  Read Full Review »
Jan 8 2008
Knowledge
USA Pacific Northwest Everett, WA. 9820
I am:
  • Tech Savvy
Reviewed at:
Price: $43.99
So Far, So Good!!
4.0
    Pros
  • Unobtrusive
  • Versatile
    Cons
  • None yet
    Best Uses
  • CBox to 2nd floor
"Took a chance after reading the mixed ratings and verifying RS return policy (30 days). I replaced a 15+ yr. old Radio Shack/Archer Rabbit VCR Multiplying System (#15-1953) that uses 150 ft. of "mini-wire" to transfer audio, video, IR - not too efficient these days). I use it on a Comcast/SA Explore …"  Read Full Review »
Jan 26 2009
Clayman2
New Haven, CT
I am:
  • Enthusiast
Reviewed at:
Price: $43.99
Awesome Product - see comments
5.0
    Pros
  • Good Length
  • Versatile
    Cons
  • None
    Best Uses
  • None
"This device works MUCH better than the RCA version I had previous. I know some people can't seem to get these devices to work so here's the TIP: Be very careful in your placement. I had an electrical breaker box AND a network router in the direct line between the two units. I simply repositioned eac …"  Read Full Review »
Mar 31 2009
Big Jim
Tallahassee, Florida
I am:
  • Casual User
Reviewed at:
Price: $43.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
