Radio Shack Wireless Phone Jack System
2.5
based on 26 reviews
Ratings Distribution
5 star
6
4 star
5
3 star
0
2 star
1
1 star
14
Category Average
3.6
Pros
  • Easy to use (8)
  • Durable (5)
  • Reliable (5)
  • Good performance (4)
  • Simple / intuitive controls (4)
  • Clear reception (3)
  • Good value (1)
  • Rest button (1)
  • Works great, 2.5 years + (1)
See less See more
Cons
  • Poor reception / weak antenna (1)
Best Uses
  • Multiple lines (2)
  • Dish connection (1)
  • House to barn (1)
  • Long talks (1)
  • Telecommuting (1)
Provided by RadioShack
The easy way to install the phone jack required by satellite TV.
Radio Shack Wireless Phone Jack System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Wireless Phone Jack System
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 19, 2008
Radio Shack Wireless Phone Jack System Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Works like a CHARM.
"I've had two for over 7 years. Great addition for expanding connection for Dish communications. Other than having to reset on a couple of occasions due to possible power losses, I'm extremely pleased. A little pricey but it beats the alternatives...." Read Full Review »
Jan 19, 2008 by Joe
See more positive Radio Shack Wireless Phone Jack System reviews
1.0
Easy to install and works ...
"Easy to install and works well in providing a dial tone to another house location without having to run a physical phone wire. What's not documented is that the receiving unit is NOT "Caller ID" capable. This means that if you plan to plug a "Caller ID" capable phone into the receiving unit, it won't work. You'll be able to receve and make calls, but you won't have "Caller ID" on incoming calls. I wouldn't h..." Read Full Review »
Mar 15, 2006 by Ray D
See more negative Radio Shack Wireless Phone Jack System reviews
Displaying 1 - 5 of 26 Reviews
Show
Sort by
Works like a CHARM.
5.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
  • Rest Button
    Cons
  • None that I've found
    Best Uses
  • Dish connection
  • Multiple Lines
  • Telecommuting
"I've had two for over 7 years. Great addition for expanding connection for Dish communications. Other than having to reset on a couple of occasions due to possible power losses, I'm extremely pleased. A little pricey but it beats the alternatives. "
Was this Telephone Accessory review on the Radio Shack Wireless Phone Jack System helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jan 19 2008
Joe
Amarillo, Texas
I am:
  • Technically Challenged
Reviewed at:
1.0
    Pros
  • Easy to use
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Easy to install and works well in providing a dial tone to another house location without having to run a physical phone wire. What's not documented is that the receiving unit is NOT "Caller ID" capable. This means that if you plan to plug a "Caller ID" capable phone into the receiving unit, it wo …"  Read Full Review »
Mar 15 2006
Ray D
Ringoes, NJ
Reviewed at:
Worthless
1.0
"This is a worthless product. It didn't work out of the box and Radio Shack would only give me a store credit. I wanted my money back. I feel ripped off by the product and Radio Shack. If I had seen these reviews first, I never would have bought it. [...] "
Dec 9 2007
KellyAggie
McKinney, TX
I am:
  • Tech Savvy
Reviewed at:
Great item; Caller ID no problem.
5.0
    Pros
  • Clear Reception
  • Durable
  • Easy Controls
  • works great, 2.5 years +
    Cons
  • None
    Best Uses
  • None
"I love this system. Only problem is that I need one more unit for the third phone and it doesn't look as if you make it. I have had no problem with caller ID on the phones - it works fine. "
Sep 26 2007
Deborah
Cambridge, MA
I am:
  • Practical
Reviewed at:
Great Product
4.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • House to barn
"I have used this system to put a phone in my barn
200 feet from the house. It has worked well for three years. Have had to reset it occasionally after a power outage. "
Dec 22 2007
Lefty
Mout Jackson, VA
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
