Radio Shack UHF Outline Bow-Tie Antenna
#28
4.0
based on 20 reviews
Ratings Distribution
5 star
10
4 star
6
3 star
1
2 star
0
1 star
3
Category Average
3.6
$4.19 at RadioShack
Find it at Amazon
Find it at Ebay
$4.19
from 1 store
Pros
  • Easy setup (14)
  • Strong signal (13)
  • Durable (5)
  • Fine-tuning (5)
  • Excellent dtv antenna (1)
  • Good value (1)
  • Least expensive (1)
See less See more
Cons
  • Flimsy (5)
  • Unattractive design (4)
  • Poor reception / weak antenna (2)
  • Basic (1)
  • Cable length (1)
  • Cord way too short (1)
  • Hard to set up (1)
  • Missing rf transformer (1)
  • Multipath signal issues (1)
  • Short wire (1)
Best Uses
  • Living room (8)
  • Small rooms (6)
  • Bedroom (5)
  • Office (4)
  • Portable devices (3)
  • Hdtv (1)
  • Hdtv uhf antenna (1)
  • Patios (1)
  • Roof mount (1)
Provided by RadioShack
Our antennas deliver a better picture on current broadcasts, this Bow-Tie Antenna is super-easy to install and snaps on VHF antenna rod.
Specification Description
Model 15-234
Accessory Indicator Yes
Benefits Easy installationMetal UHF w/nickel -chromate plating
Body Material Multi
Cables Included Built-in twin-lead 300-ohm wire to connect to UHF input
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Reception thats loud and clear.
Display Catalog Number 15-234
Included in the Box UHF antenna
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 15-234
New Date Wed May 09 00:00:00 CDT 2007
Operating Temperature UOM ° F
Outputs 2 x Post Terminal
Product Type UHF only
Supported Languages English
Radio Shack UHF Outline Bow-Tie Antenna Questions
Questions and Answers
Where to Buy
$4.19
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 20, 2009
Radio Shack UHF Outline Bow-Tie Antenna Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Does the job!
"Works better than many "HD antennas" since all of our HD channels are currently UHF only, plus it's significantly cheaper than the antennas that are marketed as "HD antennas"! Ours is incognito since it sits on the table right behind the TV so that you can't even see it. Overall, we're very happy with this little product, and we were able to return a significantly more expensive antenna that didn't work as wel..." Read Full Review »
Dec 02, 2007 by Chrissi
See more positive Radio Shack UHF Outline Bow-Tie Antenna reviews
1.0
Worst antenna ever.
"I just got this antenna today and it is the worst antenna ever. I can barely pull in any NYC stations. All I was able to get strong was some [...] Religious and Spanish station 15 miles away but NYC stations 4 miles away I could barely pull in. First the cord is too short so I could not move it around much then if I point it in a certain direction I can only get fair to poor reception. For those people who s..." Read Full Review »
Feb 13, 2009 by Tony Ramirez
See more negative Radio Shack UHF Outline Bow-Tie Antenna reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
Does the job!
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • none
    Best Uses
  • HDTV UHF antenna
Ours is incognito since it sits on the table right behind the TV so that you can't even see it. Overall, we're very happ …"  Read Full Review »
Was this Antenna review on the Radio Shack UHF Outline Bow-Tie Antenna helpful to you?
 Report Abuse  (5)  (0)  0 comments
Dec 2 2007
Chrissi
San Diego, CA
I am:
  • Know-it-all
Reviewed at:
Price: $4.19
[4 of 5 customers found this review helpful]
The best indoor HDTV antenna
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"I am yet to find another indoor antenna that works as well as this one. I have it hooked up to the Zenith DTT900 "converter box". The antenna is placed on the window - and I get practically all digital channels out of Mt Sutro in San Francisco with above 80 percent signal level(I am 35 miles away). …"  Read Full Review »
 Report Abuse  (4)  (1)  0 comments
May 17 2008
bongo1
Sunnyvale, CA
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
Price: $4.19
Gets the job done!!!
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"A few years back I bought an antenna from Radio Shack that I put on top of the roof. While the antenna would bring in most of the digital channels that I was looking for there was one channel that it would not bring in. I first thought it may be the station not broadcasting in full power. I unhooked …"  Read Full Review »
Feb 3 2008
arholmes
Greeneville, TN
Reviewed at:
Price: $4.19
[3 of 4 customers found this review helpful]
Awesome, extatic, old school antenna
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
  • Small Rooms
"i have had a bowtie antenna for about 15 years. through out the years i have tested a lot of antennas because people say technology has changed or gotten better. for that i strongly dissagree. this antenna picks up great hd channels and stuff that other antennas have a hard time picking up. ampl …"  Read Full Review »
 Report Abuse  (3)  (1)  0 comments
Jan 5 2008
koo
plymouth, IN
I am:
  • Professional
Reviewed at:
Price: $4.19
This antenna is both good and cheap!
5.0
    Pros
  • Strong Signal
    Cons
  • Unattractive Design
    Best Uses
  • Living Room
"I would highly recommend this simple antenna. I am using it to pull in all the digital HD television networks (and more), and it works flawlessly. I lost my job six months ago and I was looking for ways to cut down my expenses. The cable network was an easy choice now that I know I can get over 3 …"  Read Full Review »
Oct 20 2009
Chuck III
Grafton, WI
I am:
  • Enthusiast
Reviewed at:
Price: $4.19
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
