based on 57 reviews
Ratings Distribution
| 5 star |
17 |
| 4 star |
14 |
| 3 star |
3 |
| 2 star |
4 |
| 1 star |
19 |
Category Average
Pros
Cons
Best Uses
Where to Buy
at Amazon.com | ||||
eBay listings for: TV/HDTV/VCR/FM Antenna-Mounted High-Gain Signal Amplifier
See all eBay results |
at eBay.com | |||
Product Reviews
[2 of 2 customers found this review helpful]
[9 of 9 customers found this review helpful]
"We have the 15-1108 which looks to be the same unit as this one. I think the only difference is that ours has twin lead at the antenna unit to hook to the wingnuts on the VHF antenna. Yeah, we should upgrade our system but if it aint broke why fix it. Currently attempting to hook up a UHF antenna to the same coax but want to incorporate the same booster. I have been trying to find the right connectors to make t..." Read Full Review »
Jan 23, 2009 by Hiker1956
See more positive Radio Shack TV/HDTV/VCR/FM Antenna-Mounted High-Gain Signal Amplifier reviews
"Don't buy this one.This item is actually low-end AntennaCraft Model 10G212. Higher-end model 10G202, with 29db VHF/UHF gain, is a better choice. Model 10G201, with 16 db VHF/ 23 db UHF, is usually enough for most needs. [...]still cost less than [$]on-line.Channel Master’s ‘Spartan 3’ line has the same specs as 10G201, but are better constructed than AntennaCraft’s for dollars more. Their ‘Titan 2’ line (777..." Read Full Review »
Sep 26, 2008 by Chuck
See more negative Radio Shack TV/HDTV/VCR/FM Antenna-Mounted High-Gain Signal Amplifier reviews
Displaying 1 - 5 of 57 Reviews
Radio Shack TV/HDTV/VCR/FM Antenna-Mounted High-Gain Signal Amplifier Review
Pros
Cons
Best Uses
"Don't buy this one.This item is actually low-end AntennaCraft Model 10G212. Higher-end model 10G202, with 29db VHF/UHF gain, is a better choice. Model 10G201, with 16 db VHF/ 23 db UHF, is usually enough for most needs. [...]still cost less than [$]on-line.Channel Master’s ‘Spartan 3’ line has th …" Read Full Review »
Pros
Cons
Best Uses
"We have the 15-1108 which looks to be the same unit as this one. I think the only difference is that ours has twin lead at the antenna unit to hook to the wingnuts on the VHF antenna. Yeah, we should upgrade our system but if it aint broke why fix it. Currently attempting to hook up a UHF antenna t …" Read Full Review »
[3 of 3 customers found this review helpful]
Pros
Cons
Best Uses
"I had three of these years ago on my first antenna set-up. One on a turned UHF antenna mounted on top of a tuned VHF antenna which had one attached to it also. They both were mounted on a tower that had a rotor. I also had one attached to a tuned FM antenna mounted on a seperate pole with a rotor al …" Read Full Review »
[4 of 4 customers found this review helpful]
Pros
Cons
Best Uses
"It works for sometimes an hour, sometimes 2 days, then suddenly lines show up on analog stations and digital cut out, then it needs to be reset (shut off then back on). Ive tried everything, new cables, moving away from possible interfence, ect ect ect. Nope. have to shut it off and back on at least …" Read Full Review »
Pros
Cons
Best Uses
"Like others, it worked Great! (until). I tried two. First one worked great for about 2 weeks. Took it back and second one worked less than a week. They just seemed to stop amplifying. Seemed to work the same with the amp removed. Replaced with a Channel Master 7778. The 7778 seems to be a ti …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
at eBay.com | |||
Out Of Stock |
BizRate Rating
Good 8.6
$59.99 |
at
RadioShack
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
