Radio Shack Supermount Tape (4-Pack)
#204
5.0
based on 4 reviews
Ratings Distribution
5 star
4
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$1.99 at RadioShack
Find it at Amazon
Find it at Ebay
$1.99
from 1 store
Pros
  • Consistent performance (3)
  • Good length (3)
  • Versatile (3)
  • Rugged (2)
  • Easy to use (1)
  • Good performance (1)
  • Good value (1)
  • Reliable (1)
See less See more
Best Uses
  • Dorm room (2)
  • High-end equipment (1)
  • Speakers in my work truck (1)
  • Travel (1)
Provided by RadioShack
Easily connect just about anything with this double-sided supermount foam tape with extra sticking power.
Specification Description
Model 64-2361
Benefits Double-sided: perfect for walls or other two-sided applicationsExtra sticking power provides a strong hold
Body Material ABS plastic
Capacity UOM mAh
Country Of Origin United States
Description Header Make it stick.
Display Catalog Number 64-2361
End Product Indicator Yes
Features 1x3" stripsShear strength: 4 lbs. per square inchPack of 4
Included in the Box Tape strips x 4
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 64-2361
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Length 3
Product Type Fasteners
Product Width 1
Supported Languages English
Radio Shack Supermount Tape (4-Pack) Questions
Questions and Answers
Where to Buy
$1.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Jun 19, 2009
Radio Shack Supermount Tape (4-Pack) Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
Best thing since duct tape!!!
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
"I've used this product in all temperatures ranging from below zero to over 100 degrees F To secure speakers in my work truck.
The only problem I have with it is removing the speakers when they upgrade the fleet. "
Was this Audio Visual Cable & Connector review on the Radio Shack Supermount Tape (4-Pack) helpful to you?
 Report Abuse  (3)  (0)  0 comments
Sep 16 2007
Tunafat
Chicago
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $1.99
[1 of 1 customers found this review helpful]
Supermount pwns!
5.0
    Pros
  • Good Length
  • Versatile
    Cons
  • None
    Best Uses
  • Dorm Room
  • High-End Equipment
  • Travel
"I have used Supermount tape for over 15 years, and I hope RadioShack never discontinues this product; I have not been able to find it anywhere else. I have mounted computer speakers to the side of a monitor, a wi-fi receiver to a window, my old MP3 discman on my car's dashboard, and so much more. Yo …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 19 2009
JM
Troy, NY
I am:
  • Power User
Reviewed at:
Price: $1.99
[2 of 2 customers found this review helpful]
Supermount tape is ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Supermount tape is excellent! I have used it to mount a Garmin Street Pilot III GPS navigation unit on top of the dashboard of my car (2001 Olds Aurora) and it holds like a weld! "
 Report Abuse  (2)  (0)  0 comments
Jun 26 2006
Marc S
New Rochelle, NY
Reviewed at:
Price: $1.99
its great
5.0
    Pros
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Dorm Room
"i use it to put my speaker on the wall and its great "
Jul 24 2008
R the tech
Tokio, Japana
I am:
  • Gearhead
Reviewed at:
Price: $1.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
