Radio Shack Stainless Steel Mobile CB Antenna
#12
4.5
based on 21 reviews
Ratings Distribution
5 star
14
4 star
6
3 star
0
2 star
0
1 star
1
Category Average
3.6
$19.99 at RadioShack
Find it at Amazon
Find it at Ebay
$19.99
from 1 store
More Images
Pros
  • Durable (19)
  • Easy setup (13)
  • Strong signal (11)
  • Fine-tuning (10)
  • Easy to use (7)
  • Good reception (7)
  • Good value (7)
  • Attractive design (2)
  • Not too tall (1)
  • Works on 10 11 meters (1)
See less See more
Cons
  • Flimsy (1)
  • Poor reception (1)
Best Uses
  • Portable devices (3)
  • Attic/roof mount (1)
  • Car (1)
  • Jeep (1)
  • Mobile (1)
  • Mobile antenna (1)
  • Mobile applications (1)
  • Mobile on my 4x4 truck (1)
  • Motor home (1)
  • On a vehicle (1)
Provided by RadioShack
This all-terrain steel whip antenna is extra rugged for years of use.
Specification Description
Model 21-988
Accessory Indicator Yes
Benefits Base-loaded for extra rangeHeight: 64"Standard 3/8"-24 bottom fitting
Body Material Metal
Capacity UOM mAh
Country Of Origin United States
Description Header This antenna can take whatever you dish out.
Display Catalog Number 21-988
Enclosure Color Black/Silver
Included in the Box Stainless Steel Mobile CB Antenna
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 21-988
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 64
Product Type CB
Required to function MountCB
Supported Languages English
Radio Shack Stainless Steel Mobile CB Antenna Questions
Questions and Answers
Where to Buy
$19.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 30, 2009
Radio Shack Stainless Steel Mobile CB Antenna Reviews
Most helpful positive review
[4 of 5 customers found this review helpful]
Most helpful negative review
4.0
Give A Fair Review
"Unfortunately some reviewers make statements that cause others to question the quality, or value of a product because they don't understand certain things. The gentleman that made the statement that he's getting poor reception with it mounted on his lawnmower. That's to be expected since there is no decent sized area of ground plane below that antenna. Whether it's this antenna or any antenna I doubt you'll e..." Read Full Review »
Jun 24, 2008 by Wisill
See more positive Radio Shack Stainless Steel Mobile CB Antenna reviews
1.0
Very good reception
"Use the antenna on the outside of the motor home. Very good constsruction. Appreciate the stainless steel...." Read Full Review »
Aug 22, 2009 by ----------
See more negative Radio Shack Stainless Steel Mobile CB Antenna reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
Give A Fair Review
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • On a vehicle
"Unfortunately some reviewers make statements that cause others to question the quality, or value of a product because they don't understand certain things. The gentleman that made the statement that he's getting poor reception with it mounted on his lawnmower. That's to be expected since there is …"  Read Full Review »
Was this Antenna review on the Radio Shack Stainless Steel Mobile CB Antenna helpful to you?
 Report Abuse  (4)  (1)  0 comments
Jun 24 2008
Wisill
IL-WI Stateline
I am:
  • Tech Savvy
Reviewed at:
Price: $19.99
[1 of 1 customers found this review helpful]
Great Antenna!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Pick up Truck
"Used for both CB and 10 Meter Radio "
Truck Installation
Truck Installation
  • Picture of Product
  • Using Product
Realistic HTX100
Realistic HTX100
 Report Abuse  (1)  (0)  0 comments
Jun 22 2009
WE5T
Fort Worth, TX
I am:
  • Enthusiast
Reviewed at:
Price: $19.99
[3 of 3 customers found this review helpful]
Great Whip For Cars!!!!
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Not Too Tall
  • Strong Signal
    Cons
  • Flimsy
    Best Uses
  • Car
  • Mobile Applications
  • Portable Devices
  • Truck
"Being A Ham radio Operator, I rarely use my cb radio, but When I do, I want It to get out! I bought this antenna to use on my bumper mount, and hooked it up, and got out! I have no noise, and great reception. "
 Report Abuse  (3)  (0)  0 comments
Jan 24 2009
KJ4HPV
Knoxville,TN
I am:
  • Casual User
Reviewed at:
Price: $19.99
So far so good
4.0
    Pros
  • Easy To Set Up
  • Fine-Tuning
    Cons
  • None
    Best Uses
  • mobile
"Attached to a good magnetic roof mount. SWR adjusts easily to 1.2 or better. On a good day will receive good signal several hundred miles. Have yet to determine max tx running barefoot @ 4+ watts on the meter. Radio is the cheap Midland 1000Z. I need to use a noise clipper as I get alternator noise, …"  Read Full Review »
Oct 30 2009
Joe Shmoe
Central Florida
I am:
  • Casual User
Reviewed at:
Price: $19.99
[2 of 2 customers found this review helpful]
GREAT ANTENNA VALUE
5.0
    Pros
  • Attractive Design
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
"This is a great antenna. Its long enough to give a good transmit signal and receives well also. It is very well made and it working great on my 4x4 truck. It is my first choice when I depend on being to talk a long distance to other drivers both on and off road. It is sturdy enough built to withstan …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Mar 11 2009
The Stargazer
Wisconsin
I am:
  • Power User
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
