Radio Shack SPST Lighted Rocker Switch
#1687
3.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
1
1 star
0
Category Average
4.1
$3.99 at RadioShack
Find it at Amazon
Find it at Ebay
$3.99
from 1 store
Pros
  • Consistent performance (1)
  • Easy to install (1)
  • Professional looking (1)
  • Rugged (1)
  • Versatile (1)
See less See more
Best Uses
  • Input power switch (1)
Provided by RadioShack
The lighted “on” button lets you know this SPST rocker switch is working. Rated 10 amps at 125VAC and mounts in a 3/4” hole.
Specification Description
Model R-13 135B
Body Material Multi
Capacity UOM mAh
Country Of Origin China
Description Header Time to switch your switch?
Display Catalog Number 275-692
Enclosure Color RED
End Product Indicator Yes
Included in the Box 1 x 10A 125VAC SPST lighted (when "on") rocker switch
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model R-13 135B
Operating Temperature UOM ° F
Product Type SPST
Supported Languages English
Radio Shack SPST Lighted Rocker Switch Questions
Questions and Answers
Where to Buy
$3.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Jan 29, 2009
Radio Shack SPST Lighted Rocker Switch Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
HD power switch
5.0
    Pros
  • Consistent Performance
  • Easy to install
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Input Power Switch
"We use this switch as a master on/off for our
high voltage power supplies. A 0.775 in diameter
body means you need need a bit of hole enlarging with a round file after cutting with a 3/4 hole
saw, but the low profile, custom look is worth
the extra bother. We've used dozens with excellent result …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack SPST Lighted Rocker Switch helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jun 3 2008
Jim T
Newark, NJ
I am:
  • Professional
Reviewed at:
Price: $3.99
[0 of 1 customers found this review helpful]
2.0
"THE LIGHT ON THE SWITCH LASTS A YEAR OR TWO AND THEN BURNS OUT...SOMETIMES IT WILL FLICKER FOR AWHILE FIRST BEFORE DYING. IF YOUR APPLICATION REQUIRES A LIGHTED SWITCH THAT WILL STILL BE WORKING A YEAR OR TWO DOWN THE ROAD, CONSIDER AN LED SWITCH AS THEY HAVE A MUCH LONGER LIFE. "
 Report Abuse  (0)  (1)  0 comments
Jan 29 2009
Carl
Netcong, NJ
I am:
  • Power User
Reviewed at:
Price: $3.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
