#1657
based on 7 reviews
Ratings Distribution
| 5 star |
3 |
| 4 star |
2 |
| 3 star |
0 |
| 2 star |
2 |
| 1 star |
0 |
Category Average
Pros
Cons
Best Uses
Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
Displaying 1 - 5 of 7 Reviews
[1 of 1 customers found this review helpful]
Radio Shack Size M Panel-mount Coaxial Power Jack w/Switch Review
Pros
Cons
Best Uses
"with a bit of alteration to the frame of most HP laptops it makes a replacement that will not break like the flimsy original.
But be aware that you can still break off the PLUG if you insist on moving it around while it is plugged into the P/S. Its just a 10 minute job to replace a plug compared
Read Full Review »
Pros
Cons
Best Uses
"Drilled a hole and mounted jack onto enclosure, wired it in, connected wall wart plug. It fit perfectly and made a good consistant connection without any voltage drop. "
Pros
Cons
Best Uses
"Doesn't take a genius to realize you need to use an Ohm meter to figure out pin sets if you don't have a diagram and if you are using an Ohm meter then you will realize that outer case will ground to metal frame.
Primarily used to replace DC Power Jacks in Laptops with "Plastic" shells and they w
Read Full Review »
"Ohm meter ck indicates shield connection is isolated from body (mounting hardware). This suggests you can use either polarity for tip & shield connections. However, when a plug is inserted this is no longer true. This can result in shorting any positive shield connection when mounting in a metal …" Read Full Review »
Pros
Cons
Best Uses
"Connection diagram is on the back of the package. A bit pricey. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
