Radio Shack Size M Coaxial DC Power Plug
#1993
2.5
based on 2 reviews
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
1
Category Average
4.1
$2.99 at RadioShack
Find it at Amazon
Find it at Ebay
$2.99
from 1 store
Pros
  • Rugged (1)
See less See more
Cons
  • Non-compatible (1)
Best Uses
Provided by RadioShack
Make extensions or quick-disconnect DC power hookups with this inline power connector for 5.5mm O.D.x2.1mm I.D. connections.
Specification Description
Model 274-1577
Accessory Indicator Yes
Benefits Connects DC powerTip size: 5.5mm O.D.x2.1mm I.D.
Body Material Plastic
Cable Length Under 1 ft.
Cable Type Plugs
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Power up at RadioShack.
Display Catalog Number 274-1577
Included in the Box Inline Jack DC Power Connector
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 274-1577
Operating Temperature UOM ° F
Product Type Plugs
Supported Languages English
Radio Shack Size M Coaxial DC Power Plug Questions
Questions and Answers
Where to Buy
$2.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Aug 2, 2009
Radio Shack Size M Coaxial DC Power Plug Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
INCOMPATIBLE WITH #274-1569
1.0
    Pros
  • None
    Cons
  • NON-COMPATIBLE
    Best Uses
  • None
"DOES NOT FULLY ACCEPT #274-1569 ("M" MALE CONNECTOR). APPROX. 1/4" OF THE OUTER SLEEVE IS EXPOSED. APPARENTLY, A COMPATIBLE MALE CORD-MOUNT "M" SIZE CONNECTOR NOT AVAILABLE FROM [...]. NOT USABLE IN COMBIN WITH #274-1569. "
Was this Audio Visual Cable & Connector review on the Radio Shack Size M Coaxial DC Power Plug helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jul 18 2007
N/A
INDIANAPOLIS IN
I am:
  • Professional
Reviewed at:
Price: $2.99
Fine construction
4.0
    Pros
  • Rugged
    Cons
  • None
    Best Uses
  • None
"I bought this to make up an adapter between a specialist 12v battery and my "regular" charging equipment. (that is, in contrast to the first reviewer, I was trying to fit a non-RS 5.5mm x 2.1mm connector and the length turned out fine.) The internal solder tabs and general construction seem decently …"  Read Full Review »
Aug 2 2009
Gopher Baroque
Seattle, WA
I am:
  • Enthusiast
Reviewed at:
Price: $2.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
