Radio Shack Satellite Passive Multi-Switch
#13
2.3
based on 12 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
2
2 star
0
1 star
7
Category Average
3.0
$43.99 at RadioShack
Find it at Amazon
Find it at Ebay
$43.99
from 1 store
More Images
Pros
  • Easy setup (4)
  • Good value (4)
  • Easy to use (3)
  • Good performance (3)
  • Reliable (3)
  • High-quality picture (1)
See less See more
Cons
  • Not durable (3)
  • Bad picture quality (1)
  • Will not work with 3-lnb' (1)
  • Worked once and no more (1)
Best Uses
  • Television (2)
  • Dual lnb directv sys (1)
  • Garbage can (1)
  • Trash can (1)
  • Will work with 2-lnb (1)
Provided by RadioShack
This satellite passive multi-switch combines the signals from your dual-LNB satellite dish and outdoor antenna for transmission on one coaxial cable.
Specification Description
Model 16-2571
Accessory Indicator Yes
Benefits Ideal for homes with a dual-LNB satellite system and outdoor antennaAllows both satellite and outdoor antenna signals to travel down
Body Material Metal
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Put your signals together.
Display Catalog Number 16-2571
Enclosure Color Silver
Features Output frequency: 40-2150MHzInput frequency: 40-806MHz, 950-2150MHz
Included in the Box Satellite Passive Multi-Switch4 screws
Inputs 2 x "F" Plug(Satellite Input), 1 x "F" Plug(Antenna Input)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 15-2571
Model 16-2571
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Outputs 4 x "F" Plug(Receiver Output)
Product Type Switches
Required to function Satellite Input
Supported Languages English
Radio Shack Satellite Passive Multi-Switch Questions
Questions and Answers
Where to Buy
$43.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Aug 25, 2009
Radio Shack Satellite Passive Multi-Switch Reviews
Most helpful positive review
Most helpful negative review
5.0
Simple Solution for Dual LNB
"Used this to connect my old dual LNB to a DVR dual receiver and two older single line receivers.Worked great for two years, just lost it to lightning. I'm here to get another...." Read Full Review »
Jul 23, 2008 by lowtech
See more positive Radio Shack Satellite Passive Multi-Switch reviews
1.0
JUNK BY RADIO SHACK
"THIS SATELITE PASSIVE MULTI-SWITCH WILL NOT WORK WITH THE NEWER 3-LNB SATELLITE DISH,I CALLED RADIOSHACK AND THEY REFERED ME TO DIRECT-TV,THEY REFERED ME BACK TO RADIOSHACK,I BROUGHT IT BACK TO GET A REFUND, THATS THE ONLY GOOD THING RADIOSHACK IS GOOD FOR,..." Read Full Review »
Aug 25, 2009 by SATCOM-A
See more negative Radio Shack Satellite Passive Multi-Switch reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
JUNK BY RADIO SHACK
1.0
    Pros
  • Easy To Set Up
    Cons
  • WILL NOT WORK WITH 3-LNB'
    Best Uses
  • Television
  • WILL WORK WITH 2-LNB
"THIS SATELITE PASSIVE MULTI-SWITCH WILL NOT WORK WITH THE NEWER 3-LNB SATELLITE DISH,I CALLED RADIOSHACK AND THEY REFERED ME TO DIRECT-TV,THEY REFERED ME BACK TO RADIOSHACK,I BROUGHT IT BACK TO GET A REFUND, THATS THE ONLY GOOD THING RADIOSHACK IS GOOD FOR, "
Was this Satellite System Accessory review on the Radio Shack Satellite Passive Multi-Switch helpful to you?
Aug 25 2009
SATCOM-A
LASVEGAS,NV.
I am:
  • Power User
Reviewed at:
Price: $43.99
[2 of 2 customers found this review helpful]
Will not work with Directv triple LNB
3.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Dual lnb DirecTV sys
"Tried this on a DirecTV triple LNB satellite with the built in 4 out multi switch. Kinda worked but intermittently dependent upoun what other recievers were doing. If you are trying to add more recievers than outputs on your triple LNB dish you must use at least a 4x5 or better multiswitch. I used a …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 16 2008
Rich
Puckett, MS
I am:
  • Aircraft mechanic
Reviewed at:
Price: $43.99
[1 of 2 customers found this review helpful]
Assured that it would work with DISH
1.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Garbage can
"After being assured by the [...] salesweasel that this device WOULD work with DISH Network...I went ahead and purchased one to add an additional receiver to my home system.[...]all I could ever receive was either satellite 110 or satellite 119 - strange, because on my other two receivers, I could ge …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Oct 11 2007
Vexorg
Jonesboro, GA
I am:
  • Tech Savvy
Reviewed at:
Price: $43.99
[1 of 1 customers found this review helpful]
GARBAGE
1.0
    Pros
  • None
    Cons
  • Not Durable
  • Poor Picture Quality
    Best Uses
  • Trash can
"worked great the first time and then started to work when it wanted too. It is for DirecTv DVR with a KingDom dish on an RV. Would NOT recomend for this application. "
 Report Abuse  (1)  (0)  0 comments
Jan 27 2008
Brian
Redwood city ca
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
Price: $43.99
5.0
    Pros
  • Easy To Set Up
  • Good Value
  • High-Quality Picture
    Cons
  • None
    Best Uses
  • None
"Used this to connect my old dual LNB to a DVR dual receiver and two older single line receivers.Worked great for two years, just lost it to lightning. I'm here to get another. "
Jul 23 2008
lowtech
NC
I am:
  • Practical
Reviewed at:
Price: $43.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
