Close Login Module
Join
Radio Shack Satellite In-Line Amplifier
#12
2.6
based on 17 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
0
2 star
1
1 star
9
Category Average
3.0
$14.29
from 1 store
Pros
  • Easy setup (7)
  • Good value (7)
  • High-quality picture (3)
  • Simple controls (3)
  • Easy to return (1)
  • Easy to use (1)
  • Good performance (1)
  • I was able to return it (1)
  • Reliable (1)
See less See more
Cons
  • Bad picture quality (4)
  • Blck dgtl and anlg signal (1)
  • Did not help quality (1)
  • Has no positive effect (1)
  • It doesn't work at all (1)
Best Uses
  • Television (4)
  • Home (3)
  • Office (3)
  • Dorm room (2)
  • Movies (2)
  • Back at radio shack (1)
  • In the dust bin (1)
Where to Buy
$14.29
Product Reviews
Last update: Apr 27, 2009
Radio Shack Satellite In-Line Amplifier Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[2 of 5 customers found this review helpful]
5.0
Bought more! - Great Satellite Amps!
"The bad reviews here are from people who bought the wrong thing for their application. I just bought another handful of these because they work so well! These guys that post here about the signal being worse after they install this are using it to amplify signals that are not in the range of the amplifier! Of course the signal gets worse if you put a roadblock in the coax that doesn't pass the frequencies you ar..." Read Full Review »
Mar 21, 2009 by jameskg
See more positive Radio Shack Satellite In-Line Amplifier reviews
1.0
Actually makes things worse
"I installed this hoping to boost my reception as I have a long RG-6 cable run from my attic to my TV (over 100' with a split in the middle.) Not only did it not do anything, it actually made everything worse. I went from some snow and artifact showing up on my screen to almost no picture at all. I have it installed correctly, but now it's going back. Bad product, save your money and time...." Read Full Review »
Feb 06, 2008 by Joe from Chicago
See more negative Radio Shack Satellite In-Line Amplifier reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
5.0
    Pros
  • Easy Controls
  • Easy To Set Up
  • Good Value
  • High-Quality Picture
    Cons
  • None
    Best Uses
  • Dorm Room
  • Home
  • Movies
  • Office
  • Television
These guys that post here about the signal being worse after they install this are using it to amplify signals that are not in the range of the am …"  Read Full Review »
Mar 21 2009
jameskg
GA
I am:
  • Power User
Reviewed at:
Price: $14.29
Good product, outperforms specs
5.0
    Pros
  • Easy To Set Up
  • Good Value
    Cons
  • None
    Best Uses
  • None
"To those using this for OTA TV, please read the specs!! This is only for satellite I.F. frequencies 950-2050Mhz NOT broadcast TV 54-800Mhz. I swept mine with a HP spectrum analyzer and got 18 dB gain with a +/- 1 dB slope. That exceeds the advertised 14 dB by a good margin. Users should know that yo …"  Read Full Review »
Feb 3 2009
RF Aspie
Crown Point, IN
I am:
  • Power User
Reviewed at:
Price: $14.29
[1 of 1 customers found this review helpful]
GREAT for Satellite communication
5.0
    Pros
  • Easy Controls
  • Easy To Set Up
  • Good Value
    Cons
  • None
    Best Uses
  • Dorm Room
  • Home
  • Movies
  • Office
  • Television
"The people who dog this amp bought it without checking the freq range. This is a C-Band amplifier and works GREAT for that. I use them all the time and the price couldn't be better. Runs off the LNB voltage, so you just stick it inline. Could NOT be easier. Provides a nice RF boost for long coax run …"  Read Full Review »
Mar 11 2009
jameskg
GA
I am:
  • Power User
Reviewed at:
Price: $14.29
1.0
    Pros
    Cons
  • Poor Picture Quality
    Best Uses
  • Back at Radio Shack
"I installed this hoping to boost my reception as I have a long RG-6 cable run from my attic to my TV (over 100' with a split in the middle.) Not only did it not do anything, it actually made everything worse. I went from some snow and artifact showing up on my screen to almost no picture at all. …"  Read Full Review »
Feb 6 2008
Joe from Chicago
Chicago, IL
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
Price: $14.29
[0 of 1 customers found this review helpful]
THIS WORKS JUST FINE
5.0
    Pros
  • Easy Controls
  • Easy To Set Up
  • Good Value
  • STOPPED MY INTERFERANCE
    Cons
  • None
    Best Uses
  • Television
"JUST GOT CABLE INSTALLED 3 DAYS OF INTERFERANCE DUE TO MY RF MODULATOR I NEEDED FOR MY DVD-VCR CALLED RADIO SHACK SALES PERSON KNEW WHAT I NEEDED I BOUGHT THIS ITEM MY PICTURE HAS NEVER LOOKED BETTER NOW I CAN RECORD WITH OUT THE INTERFERANCE THIS ITME WORKS IF USED PROPERLY FOR THE RIGHT APPLACTION …"  Read Full Review »
Sep 18 2008
ANGELO SAVED BY THE GAGET
CHICAGO ILL
I am:
  • Casual User
Reviewed at:
Price: $14.29
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$14.29
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
