Radio Shack Red/Yellow LED with Holder
#1499
4.0
based on 1 review
from $2.59
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$2.59 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Bright (1)
  • Works fine at 5v (1)
See less See more
Best Uses
  • Custom hardware (1)
Provided by RadioShack
Use with electronic devices. Typical MCD is 80. This Red/Yellow LED w/Holder has a typical wavelength of 625nm.
Specification Description
Model 276-011
Benefits Lens size is 5mmRed diffused lens colorViewing angle is 60°30mA (max)Typical Voltage is 12, with a max
Body Material Multi
Capacity UOM mAh
Country Of Origin China
Description Header The tools and components your project requires.
Display Catalog Number 276-011
Enclosure Color RED
End Product Indicator Yes
Included in the Box LED
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 276-011
Operating Temperature UOM ° F
Product Type 4-7 mm lens
Supported Languages English
Radio Shack Red/Yellow LED with Holder Questions
Questions and Answers
Where to Buy
$2.59
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Mar 16, 2008
Radio Shack Red/Yellow LED with Holder Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Red LED
4.0
    Pros
  • Bright
  • Works fine at 5V
    Cons
  • None
    Best Uses
  • Custom hardware
"Rated for 12V, but using it at 5V, so apparent wide voltage range.
Bright and visible from wide angles.
Clips into 5/16" hole.
Hope it is reliable! "
Was this Audio Visual Cable & Connector review on the Radio Shack Red/Yellow LED with Holder helpful to you?
 Report Abuse  (2)  (0)  0 comments
Mar 16 2008
RFID guy
Cary, NC
I am:
  • Software guy
  • Technically Challenged
Reviewed at:
Price: $2.59
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
