Close Login Module
Join
Radio Shack RadioShack 85" Long Dual Boom, 31-Element Antenna
4.0
based on 18 reviews
Ratings Distribution
5 star
9
4 star
4
3 star
2
2 star
2
1 star
1
Category Average
3.6
Pros
  • Easy setup (17)
  • Strong signal (12)
  • Durable (5)
  • Fine-tuning (3)
  • Attractive design (2)
See less See more
Cons
  • Poor reception (3)
  • Flimsy (2)
  • Bulky (1)
  • Hard to set up (1)
  • Unattractive design (1)
Best Uses
  • Attic/roof mount (12)
  • Living room (3)
  • Bedroom (2)
  • Deck mount (1)
  • Pole (1)
  • Small rooms (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: RadioShack 85" Long Dual Boom, 31-Element Antenna
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 5, 2009
Radio Shack RadioShack 85" Long Dual Boom, 31-Element Antenna Reviews
Most helpful positive review
Most helpful negative review
[5 of 6 customers found this review helpful]
5.0
Great Antenna for HD Reception
"I live in the Washington, D.C. suburbs and needed an antenna that could pick up both high VHF and UHF digital broadcast signals. I tried another high-tech antenna from another company that pulled in strong, clear UHF but spotty VHF. I purchased this antenna just to compare the two. I have my antenna mounted in a crawl space above my garage and I was able to get this antenna into the space, mount it and aim ..." Read Full Review »
Jun 29, 2009 by herr_howard
See more positive Radio Shack RadioShack 85" Long Dual Boom, 31-Element Antenna reviews
3.0
ok but not great
"I put this antenna on top of house I live about 45 miles from waka cbs tower and i have had to go outside several times and turn it and lock it back down it will scan different channels at different times of the day in early morning it will pickup more channels than mid morning or evening not the best antenna and it is very bulky hard to get it up on pole or roof..." Read Full Review »
Mar 25, 2009 by cin
See more negative Radio Shack RadioShack 85" Long Dual Boom, 31-Element Antenna reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
ok but not great
3.0
    Pros
  • None
    Cons
  • Hard To Set Up
  • Poor Reception
    Best Uses
  • Living Room
"I put this antenna on top of house I live about 45 miles from waka cbs tower and i have had to go outside several times and turn it and lock it back down it will scan different channels at different times of the day in early morning it will pickup more channels than mid morning or evening not the be …"  Read Full Review »
Was this Antenna review on the Radio Shack helpful to you?
 Report Abuse  (5)  (1)  0 comments
Mar 25 2009
cin
deatsville alabama
I am:
  • Power User
Reviewed at:
Well thought out but, poor execution
3.0
    Pros
  • Easy To Set Up
    Cons
  • Flimsy
    Best Uses
  • Attic/Roof Mount
"Use it in an attic and you should be fine for years to come. However if signal at your location is too weak (could be general area problem or your specific location influenced by trees and other obstructions) and you must go above the roof you might want to consider more sturdy models. They're wor …"  Read Full Review »
Jul 5 2009
user from NY Tri-State
NY/CT border
I am:
  • Casual User
Reviewed at:
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • Bulky
    Best Uses
  • Attic/Roof Mount
I have my …"  Read Full Review »
Jun 29 2009
herr_howard
Leesburg, VA
I am:
  • Power User
Reviewed at:
[1 of 1 customers found this review helpful]
Worked better than expected
4.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
"Installed this antenna on the in-laws house. Located 47 miles from stations. Even with a splitter and driving two TVs we picked up both of the high VHF stations and all of the UHF stations. In a former life I installed antennas and the mechanical construction of this antenna matched the best of t …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 23 2009
Eye-Knee
Montgomery, Mn
I am:
  • Enthusiast
Reviewed at:
[0 of 1 customers found this review helpful]
Works great in attic
5.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
"I live 22 miles East of KC. All major broadcast towers are in a 33 degree span anywhere from 15-19 miles away. I put this in my attic just laying in the insulation and ran a temp patch cord down to my TV. I am picking up everything in KC and a couple of channels from St. Joe as well.
I chose t …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jun 9 2009
shortbus2
Kansas City, MO
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
$79.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
