Radio Shack Picture Frame/Indoor TV Antenna
3.8
based on 16 reviews
Ratings Distribution
5 star
3
4 star
9
3 star
2
2 star
2
1 star
0
Category Average
3.6
Pros
  • Easy setup (9)
  • Easy to use (6)
  • Good value (6)
  • Durable (5)
  • Good performance (5)
  • Reliable (5)
  • Strong signal (4)
  • Attractive design (2)
  • Fine-tuning (2)
  • Great hd reception (1)
See less See more
Cons
  • Cheap cbl push on conn (1)
  • Flimsy (1)
  • Flimsy cablecheapush on (1)
  • Hard to set up (1)
  • No negaatives (1)
  • Poor reception / weak antenna (1)
Best Uses
  • Living room (7)
  • Bedroom (4)
  • Office (2)
  • Small rooms (1)
Provided by RadioShack
The UHF loop on this classy antenna is built into the silver frame that holds a 4x6” photo.
Specification Description
Model 150-1866
Benefits 12-position fine-tuning control allows you to aim the picture for best viewingCable included for easy hook-up
Body Material Multi
Built-in Devices Picture Frame
Cables Included 3 ' coaxial cable with F connectors
Capacity UOM mAh
Country Of Origin China
Description Header Picture this
Display Catalog Number 15-1866
Enclosure Color SILVER
End Product Indicator Yes
Features Holds a 4x6 photo Gold connector allows for an improved connection and picture 3-ft. hookup cable
Included in the Box Antenna3 ' Coaxial CableUser's Guide
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 150-1866
Operating Temperature UOM ° F
Outputs 1 x "F" Plug(TV)
Product Type UHF/VHF
Protect your investment. Yes
Supported Languages English
Radio Shack Picture Frame/Indoor TV Antenna Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Picture Frame/Indoor TV Antenna
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 15, 2009
Radio Shack Picture Frame/Indoor TV Antenna Reviews
Most helpful positive review
Most helpful negative review
5.0
Works great in NYC to pick up HDTV
"Bought a new HDTV from [...] last week, but had no plans to get cable. Was going to invest in an expensive antenna online, but saw that this antenna had VHF and UHF, everything I'd need to pick up the over the air (OTA) digital HDTV broadcasts in Brooklyn, New York. It's surprisingly well built but simple to use: two thick and sturdy "rabbit ears," a steady rotating base, a firm-clicking adjustment knob, and a g..." Read Full Review »
Jan 13, 2009 by MasseyHall
See more positive Radio Shack Picture Frame/Indoor TV Antenna reviews
2.0
TOO BAD
"This is a nice product that worked fairly well after some modification and purchase of needed matching transformer. Cable is flimsy and cheap. The push on connector is as well. It is too bad they could not use a typical screw on connector and provide a matching transformer with the product. It looks very nice. Does not work very well. I would not buy again nor reccommend...." Read Full Review »
Feb 14, 2009 by TM
See more negative Radio Shack Picture Frame/Indoor TV Antenna reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
"Bought a new HDTV from [...] last week, but had no plans to get cable. Was going to invest in an expensive antenna online, but saw that this antenna had VHF and UHF, everything I'd need to pick up the over the air (OTA) digital HDTV broadcasts in Brooklyn, New York. It's surprisingly well built but …"  Read Full Review »
Was this Antenna review on the Radio Shack Picture Frame/Indoor TV Antenna helpful to you?
Jan 13 2009
MasseyHall
Brooklyn, NY
I am:
  • Casual User
Reviewed at:
[1 of 1 customers found this review helpful]
Wow 30-40 miles away w/HD Reception!!
4.0
    Pros
  • Easy To Set Up
  • Great HD Reception
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
"I bought this to use while staying at a relatives and needing reception for the bedroom tv I brought. Living 15 miles (line of sight) from Chicago the television got decent enough reception to watch. Nothing exceptional though I paid [$]. When I took it home to set it up to my HDTV it was amazing …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Nov 14 2007
Ruth
Plainfield, IL
I am:
  • Practical
Reviewed at:
TOO BAD
2.0
    Pros
  • Good looking
  • Nice concept
    Cons
  • Hard To Set Up
    Best Uses
  • Living Room
  • Office
"This is a nice product that worked fairly well after some modification and purchase of needed matching transformer. Cable is flimsy and cheap. The push on connector is as well. It is too bad they could not use a typical screw on connector and provide a matching transformer with the product. It looks …"  Read Full Review »
Feb 14 2009
TM
Zanesville,OH
I am:
  • Enthusiast
Reviewed at:
[0 of 1 customers found this review helpful]
Doesn't work for us
2.0
    Pros
  • Durable
  • Easy To Set Up
    Cons
  • Poor Reception
    Best Uses
  • Living Room
"I bought this antenna less then 2 years ago and have used it in 2 different homes on a 15 year old television and I have never been able to get decent reception except for on our Channel 10 (FOX). All of the other channels, its like watching TV cross eyed. I recently upgraded to a brand new Sony Br …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Dec 30 2008
Deirdre
Phoenix
I am:
  • Casual User
Reviewed at:
Great value for unamplified antenna
4.0
    Pros
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"This product works great for what it is - an indoor, unamplified antenna. I got 90% of my local channels with it, and live ~20 miles from the broadcast towers. However, the picture would break up whenever anyone moved around inside our apartment, and a few channels would not come in at all. I lat …"  Read Full Review »
Jul 28 2008
danep
Houston, TX
I am:
  • Gearhead
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
