Radio Shack Panel Meter 0-15VDC
#539
4.6
based on 9 reviews
Ratings Distribution
5 star
6
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.1
$12.99 at RadioShack
Find it at Amazon
Find it at Ebay
$12.99
from 1 store
More Images
Pros
  • Easy to use (4)
  • Good performance (4)
  • Good value (4)
  • Reliable (4)
  • Consistent performance (2)
  • Cheap (1)
  • Simple (1)
  • Versatile (1)
See less See more
Best Uses
  • Travel (1)
Provided by RadioShack
This panel meter is ideal for monitoring a power supply, battery charging system or car electrical system. Large analog display is easy to read.
Specification Description
Model 22-410
Benefits Use to monitor power supply, battery charging system or car electrical systemLarge analog display is easy to readFits in you
Body Material Plastic
Capacity UOM mAh
Country Of Origin China
Description Header Make your volts visible.
Display Catalog Number 22-410
Enclosure Color Black/Gray
End Product Indicator Yes
Features 15VDC ±2.5% (Full Scale Value)Internal resistance: 85 ohms ±10%Insulation resistance: 10M ohms at 500VDC<
Included in the Box Panel MeterOwner's manual
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Operating Temperature 122 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 22-410
Offer Disclaimer Pricing and availability may vary outside the contiguous 48 United States.
Operating Temperature UOM ° F
Outputs 1 x CLA(DC Socket)
Product Dimensions UOM inches
Product Height 1.875
Product Length 2.75
Product Type Analog
Product Width 2.25
Protect your investment. Yes
Supported Languages English
Radio Shack Panel Meter 0-15VDC Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 28, 2009
Radio Shack Panel Meter 0-15VDC Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Panel Meter Monitors Power Supply
5.0
    Pros
  • Consistent Performance
    Cons
  • None
    Best Uses
  • None
"My 30 inch Cabin Cruiser model requires available power monitoring as both propulsion motor and RC receiver use same supply. Low power allows for loss of control, and thus physical loss of model. "
Model Cabin Cruiser, originally built 1938
  • Using Product
meter visible for monitoring of power supply
  • Made with Product
Was this Audio Visual Cable & Connector review on the Radio Shack Panel Meter 0-15VDC helpful to you?
Apr 11 2009
cautious Cal
Salisbury; Midlothian, Va.
I am:
  • Casual User
[1 of 1 customers found this review helpful]
Versatile meter
3.0
"This is a 1 ma DC meter movement with an external 15Kohm precision resistor and dial calibrations for 0-15V. The information provided says the internal resistance is 85 ohm, so I used one as intended and, by making a shunt from 26 ga wire, use another as a 0-15A ammeter. "
Voltmeter and ammeter
  • Using Product
 Report Abuse  (1)  (0)  0 comments
Mar 9 2009
Bob
Duluth, MN
Great for a variety of 12V aplications
5.0
    Pros
  • Versatile
    Cons
  • None
    Best Uses
  • None
"Works great in a variety of 12V aplications. I have one istalled to monitor the back-up battery for my customised car alarm system. The meter display tells me if the 12V sealed lead acid battery is holding a charge. This has helped imensly when upgrading and servicing the alarm system.
This me …"  Read Full Review »
Apr 26 2009
Dave
I am:
  • Power User
[2 of 2 customers found this review helpful]
Pannel meters like this ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Pannel meters like this are the cornerstone of the home project. This one can be used also as an ammeter. THey work great in my solar energy management systems and ham projects, and i hope RS continues to make them. "
 Report Abuse  (2)  (0)  0 comments
Aug 9 2006
Mark A
Haltom City
[3 of 3 customers found this review helpful]
I bought one of these ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"I bought one of these meters back in 1984 for a project, and it is still going strong!!!! Excellent product. "
 Report Abuse  (3)  (0)  0 comments
Jan 23 2007
Todd P
Augusta, GA
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
