Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna
#3
4.6
based on 79 reviews
from $26.99
Ratings Distribution
5 star
56
4 star
17
3 star
0
2 star
2
1 star
3
Category Average
3.6
$26.99 at RadioShack
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Durable (49)
  • Easy setup (49)
  • Strong signal (41)
  • Good reception (22)
  • Good value (22)
  • Easy to use (21)
  • Fine-tuning (11)
  • Attractive design (5)
  • 2m440 transmit (1)
  • Better than oem (1)
See less See more
Cons
  • Flimsy (8)
  • Poor reception / weak antenna (4)
  • Unattractive design (4)
  • Could use a bigger mount (1)
  • Hard to set up (1)
  • Not very sturdy (1)
  • Poor 800 mhz reception (1)
  • Poor 800mhz reception (1)
  • Will bend easily (1)
Best Uses
  • Attic/roof mount (15)
  • Portable devices (13)
  • Living room (11)
  • Bedroom (7)
  • Office (7)
  • Small rooms (7)
  • Hobby monitoring (1)
  • House (1)
  • Mobile home (1)
  • On outside antenna array (1)
Provided by RadioShack
Covers 108-1300MHz with peak performance occurring in the 152-470MHz range.
Specification Description
Model 20-176
Accessory Indicator Yes
Benefits Approximately 20" in height
Body Material Multi
Capacity UOM mAh
Country Of Origin United States
Description Header Find what you need to come in loud and clear.
Display Catalog Number 20-176
Enclosure Color Silver
Included in the Box Radiator assembly - 1U bolt - 1Hex nut - 2Radial rod - 3Jam nut - 3Rod cap - 6Lock washe
Inputs 1 x SO239(Antenna)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 20-176
Model No model information available
Operating Temperature UOM ° F
Outputs 1 x SO239(Antenna)
Product Dimensions UOM inches
Product Length 20
Product Type Scanner/HAM
Supported Languages English
Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna Questions
Questions and Answers
Where to Buy
$26.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 2, 2009
Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Above Average
"Bought this Antenna this Afternoon. Easy install. Had to widen the bracket a little bit for my pole. Increase my listening range over 50 miles. Gonna run this dual with a CB/HAM antenna for total band coverage. Using RB-58 20 ft cable using a BNC/SO239 connector and getting a T Adapter to connect the 2 antennas tomorrow. I highly recommend this product. Using this setup to host a Worldwide Feed on Radio Referenc..." Read Full Review »
Jul 17, 2009 by bvfrd1 / nofdexplorer406
See more positive Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna reviews
2.0
Not as good as I was hoping
"I bought this antenna to increase the range of my Pro 2052 over a home made 5/8 indoor antenna that sits on my bookshelf. I put the antenna on a 11' mast just outside my office window using about 45' of coax. The reception was on par with the antenna that came in the box with the scanner...." Read Full Review »
Jun 23, 2009 by nicadflyer
See more negative Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna reviews
Displaying 1 - 5 of 79 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
Above Average
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • Unattractive Design
    Best Uses
  • Patio Pole
"Bought this Antenna this Afternoon. Easy install. Had to widen the bracket a little bit for my pole. Increase my listening range over 50 miles. Gonna run this dual with a CB/HAM antenna for total band coverage. Using RB-58 20 ft cable using a BNC/SO239 connector and getting a T Adapter to connect th …"  Read Full Review »
Mounted Antenna Setup
  • Picture of Product
Was this Antenna review on the Radio Shack Outdoor VHF-Hi/UHF Scanner Antenna helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jul 17 2009
LaGrange, KY 40031
I am:
  • Power User
Reviewed at:
Price: $26.99
Great antenna for the price
4.0
    Pros
  • Easy To Set Up
  • Small Size
  • Strong Signal
  • Works well below 500mhz
    Cons
    Best Uses
  • Attic/Roof Mount
  • Portable Devices
  • Small Rooms
"I bought this antenna to boost my reception in the public service and 2-meter amateur bands on my Pro-97 handheld scanner. I am very happy with the results. I'm getting county police from 30-50 miles away, whereas my range with the standard Pro-97 antenna was about 15 to 20 miles. I'm also pickin …"  Read Full Review »
Antenna mounted on a microphone stand indoors
  • Small size
  • Indoor use
  • Using Product
May 1 2009
Bill
Williamsburg, VA
I am:
  • Enthusiast
Reviewed at:
Price: $26.99
Well-Built Easy-to-Assemble Antenna
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Portable Devices
"Purchased this antenna today and it only took about 10 minutes to assemble. Component quality is superb and screw-on radials were great idea. Coax to antenna adapter was available at Radio Shack too. Very pleased with over all antenna quality and performance. "
Antenna atop Our Weather Station Pole
  • Using Product
Oct 20 2008
gsownsby
Chattanooga, TN
I am:
  • Enthusiast
Reviewed at:
Price: $26.99
[1 of 1 customers found this review helpful]
Twin "Sputniks" @ 28 ft
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Shack
"My "Sputniks" feed a Uniden BCT-15 and a RS Pro 2006. Performance is outstanding for their class. "
 Report Abuse  (1)  (0)  0 comments
Nov 30 2008
TalonIILM
NW FL
I am:
  • Enthusiast
Reviewed at:
Price: $26.99
Great Antenna - Works Well Indoors
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
  • Bedroom
  • Living Room
  • Portable Devices
  • Small Rooms
"After 30 years of being a communications engineer I knew I would need a wideband antenna for the new Uniden 996XT scanner I just bought. As the telescopic whip antennas that are included with scanners are just not adequate except for strong local signals.I live in a condo (top floor of a 3 floor b …"  Read Full Review »
Aug 29 2009
Triscut
Alaska
I am:
  • Power User
Reviewed at:
Price: $26.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
