Radio Shack Mini SPST 0.5-Amp Momentary Switch (4-Pack)
#2250
2.8
based on 18 reviews
Ratings Distribution
5 star
5
4 star
2
3 star
2
2 star
2
1 star
7
Category Average
4.1
$3.49 at RadioShack
Find it at Amazon
Find it at Ebay
$3.49
from 1 store
Pros
  • Consistent performance (6)
  • Good length (6)
  • Versatile (5)
  • Rugged (3)
  • Good for xbox 360 mods (1)
  • Minimally acceptable (1)
  • Very small size (1)
See less See more
Cons
  • Inconsistent signal (5)
  • Wears out quickly (5)
  • Can stick (1)
  • Not a consistent signal (1)
  • Not rugged (1)
  • Plastic body melts (1)
Best Uses
  • High-end equipment (2)
  • Xbox controllers (2)
  • 360 modding maybe (1)
  • Garbage (1)
  • Hobbies (1)
  • Model train controls (1)
  • Xbox 360 (1)
  • Xbox 360 controller (1)
Provided by RadioShack
Stock up on switches with this package of four SPST momentary switches. Normally open, each switch is rated 0.5 amps at 125VAC and mounts in a 1/4” hole.
Specification Description
Model 275-1547
Accessory Indicator Yes
Body Material Multi
Capacity UOM mAh
Country Of Origin China
Description Header Get caught up in our momentary switches.
Display Catalog Number 275-1547
Enclosure Color Multi
Included in the Box Mini SPST 0.5-Amp Momentary Switch (4)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 275-1547
Operating Temperature UOM ° F
Product Type SPST
Supported Languages English
Radio Shack Mini SPST 0.5-Amp Momentary Switch (4-Pack) Questions
Questions and Answers
Where to Buy
$3.49
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 21, 2009
Radio Shack Mini SPST 0.5-Amp Momentary Switch (4-Pack) Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
controllers
"i used this button for a rapid fire button on the back of my 360 controller!!!!..." Read Full Review »
Oct 27, 2008 by john jacobs
See more positive Radio Shack Mini SPST 0.5-Amp Momentary Switch (4-Pack) reviews
2.0
Poor Quality
"I have purchased almost identical switches from two other vendors that were a bit more reliable and rugged. This particular switch is easily damaged by excessive heat during soldering. The key to successfully soldering these switches is to use a reduced wattage iron (15 watts), use a heat sink clip, pre-tin the wires and only apply heat for about 5 seconds. Or use .110" female disconnect terminals and avoid t..." Read Full Review »
Apr 09, 2009 by Mike
See more negative Radio Shack Mini SPST 0.5-Amp Momentary Switch (4-Pack) reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Poor Quality
2.0
    Pros
  • None
    Cons
  • Inconsistent Signal
  • Wears Easily
    Best Uses
  • None
"I have purchased almost identical switches from two other vendors that were a bit more reliable and rugged. This particular switch is easily damaged by excessive heat during soldering. The key to successfully soldering these switches is to use a reduced wattage iron (15 watts), use a heat sink cli …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack Mini SPST 0.5-Amp Momentary Switch (4-Pack) helpful to you?
Apr 9 2009
Mike
Corona, CA
I am:
  • Power User
Reviewed at:
Price: $3.49
controllers
5.0
    Pros
  • Consistent Performance
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Xbox controllers
"i used this button for a rapid fire button on the back of my 360 controller!!!! "
 Report Abuse  (3)  (0)  0 comments
Oct 27 2008
john jacobs
san jose, california
I am:
  • Casual User
Reviewed at:
Price: $3.49
Not a rugged switch
1.0
    Pros
  • Good Length
    Cons
  • Not rugged
  • Wears Easily
    Best Uses
  • None
"I have used 8 of these switches for a door entry control panel, which receives 20 - 40 operations per day. I have had three of these switches break in a 6 month period. "
Oct 14 2009
bigwheel
Indianapolis
I am:
  • Enthusiast
Reviewed at:
Price: $3.49
[1 of 1 customers found this review helpful]
Junk
1.0
    Pros
  • None
    Cons
  • Wears Easily
    Best Uses
  • None
"Piece of junk. Tried using it for a Cub Scout project making flashlights. Out of 8 switches, 2 didn't work out of the package and by the end of the project only 2 worked as they should. 2 stopped functioning at all and the other 2 turned into monentary "off" switches. "
 Report Abuse  (1)  (0)  0 comments
Jun 26 2008
Cub Master
Chicago, IL
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $3.49
Great size
4.0
    Pros
  • Good Length
    Cons
    Best Uses
  • None
"I used this on my modded xbox 360 controller. great size for the controller. its not very heavy duty so obviously it would break easy.be careful when soldering to this because its easy to melt the plastic. "
Apr 18 2009
Like A Ninja
TX
I am:
  • Casual User
Reviewed at:
Price: $3.49
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
