#159
based on 90 reviews
Ratings Distribution
| 5 star |
31 |
| 4 star |
16 |
| 3 star |
14 |
| 2 star |
16 |
| 1 star |
13 |
Category Average
$29.99
from 1 storePros
Cons
Best Uses
Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
"Works great to move between our cars, can be mounted on either the roof or trunklid. Over time the "coils" have developed a slight backward bend but it still works perfectly. Extremely durable, I've put it on the roof and forget to remove it - the base allowed it to tip over when it hit the roof of the garage with no damage; yet it doesn't release even driving 65mph into strong head-wind over 50mph. That's ho..." Read Full Review »
Oct 17, 2009 by Matt
See more positive Radio Shack Magnet-mount mobile scanner antenna reviews
"This antenna should only be used in a stationary setting. Do NOT use as a mobile antenna on the roads or highways as the magnet is NOT going to withstand a lot of speed. The antenna itself will bend and whip and will eventually break the coils rendering all but the lowest section non-functional as a receiver. If you are, however, using this antenna indoors or say at a rest stop or camp grounds then you will prob..." Read Full Review »
Mar 12, 2009 by KC0CSB Zach
See more negative Radio Shack Magnet-mount mobile scanner antenna reviews
Displaying 1 - 5 of 90 Reviews
Radio Shack Magnet-mount mobile scanner antenna Review
Pros
Cons
Best Uses
"Works great to move between our cars, can be mounted on either the roof or trunklid. Over time the "coils" have developed a slight backward bend but it still works perfectly. Extremely durable, I've put it on the roof and forget to remove it - the base allowed it to tip over when it hit the roof o …" Read Full Review »
Pros
Cons
Best Uses
"This antenna should only be used in a stationary setting. Do NOT use as a mobile antenna on the roads or highways as the magnet is NOT going to withstand a lot of speed. The antenna itself will bend and whip and will eventually break the coils rendering all but the lowest section non-functional as a …" Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"I have been using these antennas since the early 90's. I have used them for both scanner reception and 2m/70cm transmission. These antennas hold up great under pressure as a mobile unit, but as mentioned by others, it REQUIRES and iron or steel mounting surface. Never had a problem with these antenn …" Read Full Review »
Pros
Cons
Best Uses
"I've had this antenna for about 2 1/2 years, and have gotten some good use out of it. It's used with my Uniden BCD996T scanner when I go on long trips. The worst thing about this antenna is that it will fly off the vehicle if you are traveling against strong headwinds at 65+ MPH. I had it fall of …" Read Full Review »
Pros
Cons
Best Uses
"Antenna improved reception as it should. Can't complain about it falling off at 75mph, the auto manufacturer should have used steel. Haven't bent it yet and it still looks like new. To Radio Shack marketing tech's...I'd like to see a non magnetic version of this antenna with a ground plane kit for …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
