#162
based on 23 reviews
Ratings Distribution
| 5 star |
1 |
| 4 star |
5 |
| 3 star |
2 |
| 2 star |
7 |
| 1 star |
8 |
Category Average
$34.99
from 1 storePros
Cons
Best Uses
Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
"Using this antenna with an older 40 channel and it works fine. Have crystal clear reception with weatherband.Just the other day I hit just about 7 miles(wasnt the clearest but range i think isnt bad). I use this on my pickup and it does look awkward on the roof. Some more streamlining work would be nice...." Read Full Review »
Mar 20, 2009 by Twan
See more positive Radio Shack Magnet-Mount CB Antenna with WX (Weather) Band reviews
"I have owned this antenna for a a few years and have struggled with it the entire time. The first thing that started to happen was the plastic that keeps your paint safe started peeling off. Then the magnet started failing, letting the antenna topple over, necessitating a stop on the side of the highway periodically to put it back up. I would not even say this antenna is worth the money because I replaced with a..." Read Full Review »
Feb 05, 2008 by www.ClayTech.org
See more negative Radio Shack Magnet-Mount CB Antenna with WX (Weather) Band reviews
Displaying 1 - 5 of 23 Reviews
Radio Shack Magnet-Mount CB Antenna with WX (Weather) Band Review
Pros
Cons
Best Uses
"I have owned this antenna for a a few years and have struggled with it the entire time. The first thing that started to happen was the plastic that keeps your paint safe started peeling off. Then the magnet started failing, letting the antenna topple over, necessitating a stop on the side of the hig …" Read Full Review »
Pros
Cons
Best Uses
"To start with, you could not get the antenna tight on the mount.The swrs was off the scale. The conductor and shield wires where loose in the mount.I had to take the mount apart and tighten the bolt and wiring.The swrs did came down to 3.Now the mount doesn't have the protect cover on the magnet.The …" Read Full Review »
Pros
Cons
Best Uses
"Using this antenna with an older 40 channel and it works fine. Have crystal clear reception with weatherband.Just the other day I hit just about 7 miles(wasnt the clearest but range i think isnt bad). I use this on my pickup and it does look awkward on the roof. Some more streamlining work would be …" Read Full Review »
Pros
Cons
Best Uses
"Not a good antenna. I used this with the RS [$] hanheld and the reception was only marginally better than the rubber ducky that came with the unit. It does whistle loudly at 50MPH and is not flexible and hits the garage door hard due to the inflexibility. RX/TX was less than a handheld GMRS RS mo …" Read Full Review »
Pros
Cons
Best Uses
"great antenna but the cover on the bottom that holds the magnet in place comes undone and when you tighten the main part of the antenna don't tighten it all the way because then it will make the connection inside the magnet area will all move around and make it very difficult to unscrew. But all and …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
