Radio Shack Lighted SPST Rocker Switch
#2176
3.9
based on 14 reviews
Ratings Distribution
5 star
6
4 star
5
3 star
1
2 star
0
1 star
2
Category Average
4.1
$3.99 at RadioShack
Find it at Amazon
Find it at Ebay
$3.99
from 1 store
Pros
  • Consistent performance (8)
  • Rugged (7)
  • Versatile (4)
  • Easy to use (2)
  • Good performance (2)
  • Good value (2)
  • Reliable (2)
  • Good length (1)
  • Hole mount (1)
  • Lighted (1)
See less See more
Cons
  • Heavy / bulky (3)
  • A litttle long (1)
  • Gets hot an stays on (1)
  • Needs schematic example (1)
  • Unreliable (1)
  • Very bright (1)
  • Wears out quickly (1)
Best Uses
  • In the car (2)
  • Automotive (1)
  • Portable devices (1)
  • Rugged (1)
  • Switch for power supply (1)
Provided by RadioShack
This illuminating SPST automobile switch is just the switch your project needs. Rated 30 amps at 12VDC and mounts in a 7/16" hole.
Specification Description
Model 275-712
Body Material Multi
Capacity UOM mAh
Country Of Origin China
Description Header Enough switches to make you flip!
Display Catalog Number 275-712
End Product Indicator Yes
Included in the Box 1 x 30A 12VDC SPST lighted general purpose rocker switch
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 275-712
Operating Temperature UOM ° F
Product Type SPST
Supported Languages English
Radio Shack Lighted SPST Rocker Switch Questions
Questions and Answers
Where to Buy
$3.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 13, 2009
Radio Shack Lighted SPST Rocker Switch Reviews
Most helpful positive review
Most helpful negative review
[1 of 2 customers found this review helpful]
4.0
Awesome Switch
"Have to agree with MadMechanic... Switch works very well. I do not see how anyone using a Relay could be pulling more than 2... maybe 3 Amps tops. Unless they aren't paying attention to their wiring. Check the ratings on the relays you are using. Running a Load directly through a switch is ok for small items and must be properly fused or you WILL get heat damage and almost any switch will eventually fail... or ..." Read Full Review »
Oct 13, 2009 by Machinehead
See more positive Radio Shack Lighted SPST Rocker Switch reviews
1.0
don't buy
"Bought these to make a simple switch box. I liked the fact that they are illuminated and rated at 30 Amps. The problem is that the load terminal is shorted to the ground terminal. The load terminal should pass through an LED and a resistor so that the switch is illuminated when power is switch to the load. I measured no resistance between the load and ground terminals...they are shorted! I immediately blew ..." Read Full Review »
Aug 09, 2007 by hazzard
See more negative Radio Shack Lighted SPST Rocker Switch reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
Awesome Switch
4.0
    Pros
  • Consistent Performance
  • Good Length
  • Good Warranty
  • Rugged
  • Versatile
    Cons
  • Bulky
  • Very Bright
    Best Uses
  • Automotive
"Have to agree with MadMechanic... Switch works very well. I do not see how anyone using a Relay could be pulling more than 2... maybe 3 Amps tops. Unless they aren't paying attention to their wiring. Check the ratings on the relays you are using. Running a Load directly through a switch is ok for s …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack Lighted SPST Rocker Switch helpful to you?
Oct 13 2009
Machinehead
New Britain, CT
I am:
  • Power User
Reviewed at:
Price: $3.99
[1 of 1 customers found this review helpful]
Have 3 and counting
5.0
    Pros
  • Rugged
  • Versatile
    Cons
  • Bulky
    Best Uses
  • None
"I have used 3 of these or similar now and have had no problems with any of them (when I had the packaging to hook them up right). I primarily use these to control the remote power wire from stereo headunits to car audio subwoofer amplifiers. The reason I gave it the con of being bulky is that I li …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Apr 14 2009
The Mad Mechanic
Rochester, NY
I am:
  • Power User
Reviewed at:
Price: $3.99
don't buy
1.0
    Pros
  • None
    Cons
  • Unreliable
  • Wear Easily
    Best Uses
  • In The Car
  • Portable Devices
"Bought these to make a simple switch box. I liked the fact that they are illuminated and rated at 30 Amps. The problem is that the load terminal is shorted to the ground terminal. The load terminal should pass through an LED and a resistor so that the switch is illuminated when power is switch to …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Aug 9 2007
hazzard
St Paul, MN
I am:
  • Professional
Reviewed at:
Price: $3.99
Fails at 8.6 amps and 12-14vdc!
1.0
    Pros
  • Versatile
    Cons
    Best Uses
  • None
"I use the switch to control a relay for fog lamps. The first switch was well made, lasting 2 years. Recently, the bulb vibrated downward, close to the spring-loaded center pin mounted in the translucent plastic rocker, which softened and stretched when I attempted to shut the switch off(I could not) …"  Read Full Review »
Nov 1 2007
Avionic Pro
KATL
I am:
  • Professional
Reviewed at:
Price: $3.99
Not bad
5.0
    Pros
  • Rugged
  • Versatile
    Cons
  • Bulky
    Best Uses
  • None
"Works good. Don't know how those other guys are hooking it up, but if you hook up the power to the power tab and ground to the ground tab, and the load to the load tab, everything works amazingly. It's too bright for interior use though. I used it to make an independent A/C switch for my Contour. Al …"  Read Full Review »
Apr 28 2009
MOSEngineer
Detroit
I am:
  • Enthusiast
Reviewed at:
Price: $3.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
