Radio Shack Indoor VHF/UHF/HDTV Antenna with RF Remote Control
#49
3.7
based on 336 reviews
from $49.99
Ratings Distribution
5 star
146
4 star
93
3 star
19
2 star
17
1 star
61
Category Average
3.6
$49.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Easy setup (197)
  • Strong signal (159)
  • Fine-tuning (123)
  • Durable (80)
  • Good value (44)
  • Reliable (44)
  • Easy to use (43)
  • Good performance (43)
  • Attractive design (29)
  • Looks great (2)
See less See more
Cons
  • Poor reception / weak antenna (65)
  • Unattractive design (42)
  • Heavy / bulky (25)
  • Flimsy (19)
  • Hard to set up (11)
  • Confusing / bad remote control (3)
  • Noisy (3)
  • Pricey (3)
  • Big (2)
Best Uses
  • Living room (152)
  • Bedroom (100)
  • Small rooms (49)
  • Office (32)
  • Portable devices (9)
  • Anywhere (3)
  • Basement (3)
  • Apartment (2)
  • All indoor rooms (1)
  • Anywhere indoors (1)
Provided by RadioShack
This indoor antenna allows you to enjoy the best possible HDTV programming.
Specification Description
Model 15-1892
Accessory Indicator Yes
Battery Type Product
Benefits 3 amplifier gain levels330° rotation and 12 reception directionsRemote control range of 50 feet, indoors and outdoors
Body Material Metal
Cables Included 1 x 6' 75 Ohm cable with gold plated connectors.
Capacity UOM mAh
Country Of Origin China
Description Header Tune in to a better picture.
Display Catalog Number 15-1892
Included in the Box Amplified antennaPower adapter 12V 350mA6 feet 75ohm coaxial cable with Gold-plated connectorCR2032 Li-ion battery
Inputs 1 x Barrel(12VDC), 1 x "F" Plug(Game/TV)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 15-1892
New Date Tue Nov 22 00:00:00 CST 2005
Operating Temperature UOM ° F
Outputs 1 x "F" Plug(To TV)
Power Device 12VDC 350 mA adapter included
Product Dimensions UOM inches
Product Height 8.1
Product Length 12.6
Product Type HDTV
Product Width 12.6
Remote Control Features 0 - 9 numerical keys Store button Left/Right - swivel angle of the ant Up/Down - amp gain +/-
Remote Control Type Product
Supported Languages English
Technology IR
Radio Shack Indoor VHF/UHF/HDTV Antenna with RF Remote Control Questions
Questions and Answers
Where to Buy
$49.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 19, 2009
Radio Shack Indoor VHF/UHF/HDTV Antenna with RF Remote Control Reviews
Most helpful positive review
[6 of 6 customers found this review helpful]
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
AWESOME antenna! Great for DTV and HD.
"This antenna is fantastic. When I first bought it, I used it to pick up over-the-air HD signals in San Jose, CA. Despite the fact that the vast majority of stations in the Bay Area are based out of San Francisco (and over 40 miles from where we lived), all the major stations came in great, other than NBC being finicky from time-to-time. We just moved to the Washington DC area in Ashburn, VA (probably around 2..." Read Full Review »
Jun 07, 2009 by No more cable
See more positive Radio Shack Indoor VHF/UHF/HDTV Antenna with RF Remote Control reviews
3.0
Don't expect a miracle
"I have a digital converter box on the downstairs TV and an upstairs bedrroom TV. I live in a residential area (in NJ) with a lot of trees, 7-13 miles from all signal sources. Getting a good signal downstairs is a pain. It takes a good 5 minutes to get CBS(channel 2) or NBC (ch. 4) if I get it at all. Can't get ABC (ch. 7) Upstairs is better, but still sporatic 25% of the time. Bought this amplified antenna h..." Read Full Review »
Sep 14, 2008 by Tired of it all
See more negative Radio Shack Indoor VHF/UHF/HDTV Antenna with RF Remote Control reviews
Displaying 1 - 5 of 336 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Small Rooms
"This antenna is fantastic. When I first bought it, I used it to pick up over-the-air HD signals in San Jose, CA. Despite the fact that the vast majority of stations in the Bay Area are based out of San Francisco (and over 40 miles from where we lived), all the major stations came in great, other t …"  Read Full Review »
Was this Antenna review on the Radio Shack Indoor VHF/UHF/HDTV Antenna with RF Remote Control helpful to you?
 Report Abuse  (6)  (0)  0 comments
Jun 7 2009
No more cable
Broadlands, VA
I am:
  • Power User
Reviewed at:
Price: $49.99
[7 of 7 customers found this review helpful]
Know how to set it up!
4.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
"OK folks...When you take it out of the box and place it on/near the TV, hook it up, extend the ears, and turn it and the TV/converter on, DO NOT just let your converter box or TV do a scan for available channels. Why? Because the antenna is at its default setting (direction, intensity, channel). …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Jun 20 2009
Larry
Fresno, CA.
I am:
  • Casual User
Reviewed at:
Price: $49.99
[5 of 5 customers found this review helpful]
THE ONLY INDOOR ANTENNA THAT WORKS!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Small Rooms
"I will never pay for cable TV and all their commercials -- I get my entertainment over-the-air for free. I live in Phoenix 19.7 miles from all relevant digital and analog transmitters. There are two small mountains in the way, which doesn't help. As of 4/09, most signals are in the blue or viole …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Apr 27 2009
MovieLover 2934
Phoenix, AZ
I am:
  • Power User
Reviewed at:
Price: $49.99
Fantastic
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
  • Office
  • Small Rooms
"I have read all of the negative reviews here of this antenna. Having just re-located one of our two Olevia screens to another room, we wanted to have the option of OTA HD in that room (we currently have a non-HD box there). I had purchased a Terk HDTVa a few years ago and was constantly frustrated …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Jan 4 2009
dxace1
Potomac MD
I am:
  • Power User
Reviewed at:
Price: $49.99
[3 of 3 customers found this review helpful]
23 Channels - Arlington, Virginia !!
5.0
    Pros
  • Easy To Set Up
  • Fine-Tuning
  • No Signal Break up
  • One Setting - 23 channels
  • Simple to use
  • More »
    Cons
  • Not at default setting
  • Store sold used as new
    Best Uses
  • Bedroom
  • Living Room
  • Office
"After trying the apartment roof antenna (1 channel), passive rabbit ears (4 channels and signal wobble), the Radio Shack 15-1878 (8 channels but signal would not stay focused and heck to try and tune), i bought this one - right out of the box at setting 0 12 3 - it brought in 23 channels with excell …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jul 22 2008
jswcpm[@]
Arlington, Virginia
I am:
  • Gearhead
  • Professional
  • Telecomm Prof
Reviewed at:
Price: $49.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
