#163
based on 52 reviews
Ratings Distribution
| 5 star |
9 |
| 4 star |
18 |
| 3 star |
3 |
| 2 star |
5 |
| 1 star |
17 |
Category Average
$40.69
from 1 storePros
Cons
Best Uses
Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
[4 of 4 customers found this review helpful]
[3 of 3 customers found this review helpful]
"To address some of the complaints from others: This unit cannot cover the satellite frequencies, and therefore will prevent satellite signal from reaching your tuner/decoder. The covered frequencies stop at around 1 GHz, so don't buy it if you need satellite coverage, or have satellite signals on the same cable. People need to understand the basics of how receivers work before buying this. Because it is a br..." Read Full Review »
Mar 22, 2008 by Adam Wade
See more positive Radio Shack In-Line Signal Amplifier reviews
"I currently have an antenna in my attic (one of those diy antennas). Testing it with a converter box, I was getting good signal on all of my channels. However, when I hooked it up to my house wiring, the split caused FOX to drop extremely low. This was do to a 100' run from the antenna to the splitter, as well as the runs to the outlet. I was still able to get a signal, just not a strong one. I bought this ..." Read Full Review »
Feb 16, 2009 by Crewski
See more negative Radio Shack In-Line Signal Amplifier reviews
Displaying 1 - 5 of 52 Reviews
Radio Shack In-Line Signal Amplifier Review
Pros
Cons
Best Uses
"To address some of the complaints from others: This unit cannot cover the satellite frequencies, and therefore will prevent satellite signal from reaching your tuner/decoder. The covered frequencies stop at around 1 GHz, so don't buy it if you need satellite coverage, or have satellite signals on …" Read Full Review »
[5 of 6 customers found this review helpful]
Pros
Cons
Best Uses
"Always install a lightning/static protector AHEAD of the amplifier right at the antenna. It doesn't say this in the printed instructions, but this may prevent your amp from being blown by nearby lightning strikes. Nothing will protect the amp from a direct strike!
Always install the amp at the a
Read Full Review »
Pros
Cons
Best Uses
"I have read all the reviews of this product. In spite of the negatives I read, I purchased anyway. Installed in less than 5 minutes and the results are as good as it gets for the price. My digital tv signals went from "NORMAL" to just below "GOOD" (which is the highest signal) on all of my local …" Read Full Review »
Pros
Cons
Best Uses
"I currently have an antenna in my attic (one of those diy antennas). Testing it with a converter box, I was getting good signal on all of my channels. However, when I hooked it up to my house wiring, the split caused FOX to drop extremely low. This was do to a 100' run from the antenna to the spl …" Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Water in the connectors is the worst enemy of this device. If you can keep the water out it should last for years.Reading over a lot of the reviews I have the feeling manufacturing quality control is not good for these devices. All the ones I've bought have worked as speced out of the box, but I rea …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
