Close Login Module
Join
Radio Shack High-Brightness 7-Color 5mm Blinking LED
#2215
3.2
based on 30 reviews
Ratings Distribution
5 star
7
4 star
11
3 star
2
2 star
2
1 star
8
Category Average
4.1
$2.49
from 1 store
More Images
Pros
  • Versatile (9)
  • Consistent performance (7)
  • Good length (5)
  • Rugged (4)
  • Novel (2)
  • Bright (1)
  • Brilliant (1)
  • Cheap (1)
  • Cool effect (1)
  • Different (1)
See less See more
Cons
  • No data sheet (3)
  • No instructions (2)
  • 3 leads no info (1)
  • Doesn't work as described (1)
  • Has no data sheet (1)
  • Inconsistent signal (1)
  • Lacks documentation (1)
  • No datasheet bad rs (1)
  • No info (1)
  • No schematics (1)
Best Uses
  • Projects (3)
  • Anything (2)
  • Dorm room (2)
  • High-end equipment (2)
  • Novelty (2)
  • Attention getting display (1)
  • Attention-getting display (1)
  • Backlight illumination (1)
  • Catching attention (1)
  • Data sheet lighting (1)
Where to Buy
$2.49
Product Reviews
Last update: Oct 7, 2009
Radio Shack High-Brightness 7-Color 5mm Blinking LED Reviews
Most helpful positive review
[15 of 15 customers found this review helpful]
Most helpful negative review
4.0
Novelty, but no real value
"It is pretty neat except for it comes with no instructions. The flat side is -, and the center is +. The remaining lead is for control, and is pulled high via a weak internal pull-up. Connect this lead though a momentary closed pushbutton to ground. When power is applied the LED will cycle though all the colors at about 250mS each color, then will cycle though them four more times but much faster, then it w..." Read Full Review »
May 01, 2008 by Phredog
See more positive Radio Shack High-Brightness 7-Color 5mm Blinking LED reviews
1.0
It's cool, but, how do you make it work?
"I have been trying to use this LED as a meter light upgrade for CB radios, however, there is no information provided for this product, as everyone else agrees, at a few bucks each, it's not a very inexpensive item to keep to blowing without proper data sheets and powering information that should be provided with a technical item such as this. I was able to finally make the thing light up and do it's thing,BUT, i..." Read Full Review »
Apr 26, 2008 by Dodgem
See more negative Radio Shack High-Brightness 7-Color 5mm Blinking LED reviews
Displaying 1 - 5 of 30 Reviews
Show
Sort by
1.0
    Pros
  • It's Interesting
    Cons
  • No Instructions
    Best Uses
  • Hard To Figure Just Yet
"I have been trying to use this LED as a meter light upgrade for CB radios, however, there is no information provided for this product, as everyone else agrees, at a few bucks each, it's not a very inexpensive item to keep to blowing without proper data sheets and powering information that should be …"  Read Full Review »
7 color LED caught in blue mode in a Cobra 29 LTD
  • Using Product
  • Made with Product
Apr 26 2008
Dodgem
Maryland
I am:
  • Electronics Repair Tech
Reviewed at:
Price: $2.49
[4 of 4 customers found this review helpful]
Video demonstration
3.0
    Pros
  • Versatile
    Cons
  • Lacks Documentation
    Best Uses
  • Rave
"Got it working by using the info from the other review. Video shows the cycles it will go through. I cannot figure out how to get it to blink in a steady color continuously. "
Status LED for Scooter
  • DIY
  • Radio
  • LED
  • 276-016
  • Electronics
  • Shack
  • Catalog
Apr 14 2008
Lloyd
Boise, ID
I am:
  • Tech Savvy
Reviewed at:
Price: $2.49
4.0
    Pros
  • Novel
    Cons
  • No Instructions
    Best Uses
  • projects
The flat side is -, and the center is +. The remaining lead is for control, and is pulled high via a weak internal pull-up. Connect this lead though a momentary closed pushbutton to ground. When power is applied the LED will cycle th …"  Read Full Review »
May 1 2008
Phredog
Phoenix, AZ
I am:
  • Professional
Reviewed at:
Price: $2.49
Color organ circuit for this LED
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Anything
"Here's a new color organ circuit I designed around this LED. Frequency and volume cause color changes and intensity [...]. "
Color organ for Radio Shack 7 color LED
  • Using Product
  • Fabulous
  • Sound
  • Orchids
  • Picture of Product
  • LED
  • Music
  • Made with Product
Jul 6 2009
Brea CA USA
I am:
  • Power User
Reviewed at:
Price: $2.49
My favorite LED. Was easy!
5.0
    Pros
    Cons
  • None
    Best Uses
  • None
"Amazing LED, and now my favorite.
Here's my video showing these in action.
Make sure you read the info to the right of the video. "
LED: MASTERING THE RADIO SHACK 7 COLOR LED
  • Made with Product
  • Flashing
  • Using Product
  • Bi-color
  • LED
  • Lights
  • Flasher
  • UFO's
  • Cool
  • 555
  • Tri-color
Jun 27 2009
Roccaforte Amps
Brea, CA
I am:
  • Power User
Reviewed at:
Price: $2.49
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$2.49
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
