Radio Shack HDTV Indoor/Outdoor Directional Antenna
3.9
based on 165 reviews
from
Ratings Distribution
5 star
89
4 star
31
3 star
10
2 star
6
1 star
29
Category Average
3.6
More Images
Pros
  • Easy setup (111)
  • Strong signal (93)
  • Durable (49)
  • Fine-tuning (40)
  • Easy to use (24)
  • Good performance (21)
  • Good value (21)
  • Reliable (21)
  • Attractive design (8)
  • Lightweight (2)
See less See more
Cons
  • Poor reception / weak antenna (18)
  • Flimsy (17)
  • Unattractive design (10)
  • Heavy / bulky (2)
  • Short life span (2)
  • Apartment mounting (1)
  • Bad at vhf reception (1)
  • Best inside (1)
  • Bigger than i though (1)
Best Uses
  • Living room (43)
  • Attic/roof mount (17)
  • Bedroom (17)
  • Office (9)
  • Small rooms (9)
  • Outdoors (6)
  • Attic (4)
  • Attic antenna (3)
  • Anywhere (2)
  • Portable devices (2)
Provided by RadioShack
Stylish HD antenna is easily mounted and delivers great local HDTV reception.
Specification Description
Model 15-2187
Accessory Indicator Yes
Benefits Great HD reception from almost anywhere20" width so its ideal for most mounting locations such as a roof, sidewall or atticR
Capacity UOM mAh
Country Of Origin United States
Description Header Get the best reception.
Display Catalog Number 15-2187
Features VHF frequency (channels 2-6) receives DTV signal up to 20 miles and analog signal up to 15 milesVHF frequency (channels 7-13) receive
Included in the Box HD antennaStandard mast-type mounting bracketDC power injectorAC/DC power supplyPackaging - 3-color offset
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 15-2187
New Date Sun Aug 06 00:00:00 CDT 2006
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 4
Product Length 20
Product Type HDTV
Product Width 18
Supported Languages English
Radio Shack HDTV Indoor/Outdoor Directional Antenna Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: HDTV Indoor/Outdoor Directional Antenna
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 23, 2009
Radio Shack HDTV Indoor/Outdoor Directional Antenna Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[11 of 11 customers found this review helpful]
4.0
On A Budget For DTV 2009 Change Over
"OK!! I'm on a budget. It's does the job, but the 10db gain amp does seems weak pulling some of TV channels. I'm getting signal strength from 50-71 on a 0-100 scale. The plastic casing is ok but flimsy around the back mount but good enough mount to mounting base. Over it does do a descent job using it indoors, since I can't mount it outside of my rental place. Over all that's why i gave it a 4 out 5 stars..." Read Full Review »
Mar 12, 2008 by Dizzytaz00
See more positive Radio Shack HDTV Indoor/Outdoor Directional Antenna reviews
3.0
Works great, if breaks - easy fix
"I have almost as many channels (Digital and Analog) as I had with basic cable. I mounted it outside for better reception (10' mast), however after 3.5 months it stopped working for all but 2 channels. It was past warranty so I dug into it. I found the interior antenna connectors had broken loose from the circuit board. A few simple solder connections and I was back in business. I connected the antenna to my exte..." Read Full Review »
Oct 30, 2008 by Sprocket
See more negative Radio Shack HDTV Indoor/Outdoor Directional Antenna reviews
Displaying 1 - 5 of 165 Reviews
Show
Sort by
3.0
    Pros
  • Easy To Set Up
  • Light weight
    Cons
  • Weak Solder Points
    Best Uses
  • Whole House
"I have almost as many channels (Digital and Analog) as I had with basic cable. I mounted it outside for better reception (10' mast), however after 3.5 months it stopped working for all but 2 channels. It was past warranty so I dug into it. I found the interior antenna connectors had broken loose fro …"  Read Full Review »
Loose connections
Loose connections
  • Interior repair
Solder connections
Solder connections
  • Fix your antenna
Was this Antenna review on the Radio Shack HDTV Indoor/Outdoor Directional Antenna helpful to you?
 Report Abuse  (11)  (0)  0 comments
Oct 30 2008
Sprocket
Champaign, IL
I am:
  • Enthusiast
Reviewed at:
4.0
    Pros
  • Easy To Set Up
    Cons
  • Flimsy
    Best Uses
  • Indoors
Over it does do a descent job usi …"  Read Full Review »
Front
Front
  • Using Product
  • Picture of Product
 Report Abuse  (1)  (0)  0 comments
Mar 12 2008
Dizzytaz00
Berwick , PA
I am:
  • Gearhead
  • Practical
  • Tech Savvy
Reviewed at:
[13 of 13 customers found this review helpful]
Worked great, broke, working great again
5.0
    Pros
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"I limit myself to low profile antennas due to space and location when mounted on the roof. I purchased and installed this antenna seven months ago and it has worked better than all previous antennas I've tried. For seven months it was flawless with perfect clarity and many channels. Then we noticed …"  Read Full Review »
 Report Abuse  (13)  (0)  0 comments
May 5 2008
BackinBusiness
Fort Worth, Texas
I am:
  • Professional
Reviewed at:
[5 of 5 customers found this review helpful]
Works well in Michigan weather (one TV)
5.0
    Pros
  • Attractive design
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None that I can find
    Best Uses
  • Only one TV
  • UHF Digital
"I upgraded to this antenna from model # DA-5200 after moving out of that one's range. I have had it on my roof for 8 months with NO problems despite temps ranging from 0 - 95 degrees, rain, snow, ice and winds over 60 MPH.
After reading other comments about problems with wires breaking internall …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Dec 28 2008
HD sTeVe
Waterford, MI
I am:
  • Power User
Reviewed at:
[8 of 8 customers found this review helpful]
This is a UHF only antenna!!!
2.0
    Pros
  • Small design
    Cons
  • Bad at VHF reception
    Best Uses
  • UHF only reception
"I'm the chief engineer at a TV station and after reading the product description, I figured I'd point out that the note about 95% of stations being UHF is NOT ACCURATE. 25 to 30 % of the stations out there now in DTV are indeed VHF (channels 2-13), meaning that you probably have at least one in you …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Jun 15 2009
4lids
Waterloo, IA
I am:
  • Power User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
