Radio Shack Distribution Amplifier
#94
3.5
based on 19 reviews
Ratings Distribution
5 star
5
4 star
5
3 star
6
2 star
1
1 star
2
Category Average
4.1
$49.99 at RadioShack
Find it at Amazon
Find it at Ebay
$49.99
from 1 store
Pros
  • Easy to use (17)
  • Highly compatible (7)
  • Improves performance (5)
  • Compact design (4)
  • High quality (4)
  • Good performance (3)
  • Good value (3)
  • Reliable (3)
See less See more
Cons
  • Poor performance (3)
  • Died in less than a year (1)
  • Limited compatibility (1)
  • No power indicator light (1)
  • Poor design (1)
  • Ports quit working (1)
Best Uses
  • Home movies (5)
  • Complex projects (3)
  • Independent films (3)
  • Studio (2)
  • For running 2-4 tv's (1)
  • Personal use (1)
Provided by RadioShack
Great for multi-VCR dubbing setups. This amplifier provides one S-video input and four S-video outputs. It also converts composite video input to S-video outputs.
Specification Description
Model 15-1172
Accessory Indicator Yes
Benefits Distribute the signal to up to 4 different devices/locationsChanges composite (yellow) video signal to higher quality S-video signal<
Body Material Multi
Capacity UOM mAh
Country Of Origin United States
Description Header Four-way distrubtion.
Display Catalog Number 15-1172
Enclosure Color Black
Exclusive Indicator Yes
Features Connects up to 4 VCRs S-video input to 4 S-video outputs Color-coded phono jacksConverts composite video input to an S-video output
Included in the Box 4 Way Distribution amplifierAC adapterMounting screws (2)Owner's manual
Inputs 1 x RCA(Video input), 1 x S-Video(S-Video input), 2 x RCA(Audio input)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 15-1172
Operating Temperature UOM ° F
Outputs 4 x RCA(Composite video output), 4 x S-Video(S-Video output), 8 x RCA(Audio output)
Power Device AC adapter (110V AC)
Product Type Amplifiers
Product Weight 1
Product Weight UOM pounds
Protect your investment. Yes
Supported Languages English
Radio Shack Distribution Amplifier Questions
Questions and Answers
Where to Buy
$49.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 3, 2009
Radio Shack Distribution Amplifier Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
In Use for 2+ Years
"I've had 2 of these running in several incarnations of a Video Control Room at my church. One is pre-titles, the other is post-titles. They've been in use for years, though never for more than 36 hours at a stretch. They get the job done, but I've since discovered D/A's that allow control of Luminance and Chrominance! Overall, these Radio Shack units work great - Never had a problem with them!..." Read Full Review »
Sep 27, 2007 by Milk And Chase
See more positive Radio Shack Distribution Amplifier reviews
3.0
Decent for the price
"It worked great for several months. Then just stopped. The biggest flaw I found was you couldn't tell when it was plugged in and "on". Time was often wasted looking at video cable connections only to find the power cable came loose (not totally unplugged...just loose enough it wasn't getting power)...." Read Full Review »
Aug 07, 2007 by DJ AAA
See more negative Radio Shack Distribution Amplifier reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
Did the job for me
4.0
    Pros
  • Compact Design
  • Good value
    Cons
  • None
    Best Uses
  • None
"I just needed something to drive a couple of plasma TVs from one video feed in our cafeteria. Each is on a 50' s-video cable from this distribution amp on opposite sides of the room. I saw another reviewer complain that the outputs weren't isolated, but that made no difference to me in this straig …"  Read Full Review »
Was this Video Amplifier, Splitter, & Modulator review on the Radio Shack Distribution Amplifier helpful to you?
Nov 3 2009
MH
Newtown, CT
I am:
  • Engineer
Reviewed at:
Price: $49.99
In Use for 2+ Years
4.0
    Pros
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Complex Projects
  • In The Studio
  • Independent Films
"I've had 2 of these running in several incarnations of a Video Control Room at my church. One is pre-titles, the other is post-titles. They've been in use for years, though never for more than 36 hours at a stretch. They get the job done, but I've since discovered D/A's that allow control of Lumi …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 27 2007
Milk And Chase
Long Island, NY
I am:
  • Hobbyist
Reviewed at:
Price: $49.99
Radio Shack inc. had the ...
4.0
    Pros
  • Easy to use
  • Good performance
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Radio Shack inc. had the original product that was an A/C device with only three outputs and those worked great, but then they just had to change from a good thing to "okay lets start over again". This one has been okay, I do like the DC powering (easy to back up incase of power outtage) however I …"  Read Full Review »
Feb 25 2007
Mike S
Atlanta
Reviewed at:
Price: $49.99
Does what it's supposed to
4.0
    Pros
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home Movies
"I've been using this product for a few years to solve my cable TV woes. I like to use both the analog and digital cable signals so I use this distribution amp to send the signal from my digital cable box to the TV, VCR, and Computer (for video capture). This way I can watch or record one show from …"  Read Full Review »
Jun 25 2008
Jordan
Chicago, IL
Reviewed at:
Price: $49.99
3.0
    Pros
  • Easy To Use
  • Highly Compatible
    Cons
    Best Uses
  • Home Movies
  • Personal use
"It worked great for several months. Then just stopped. The biggest flaw I found was you couldn't tell when it was plugged in and "on". Time was often wasted looking at video cable connections only to find the power cable came loose (not totally unplugged...just loose enough it wasn't getting powe …"  Read Full Review »
Aug 7 2007
DJ AAA
Columbus, OH
I am:
  • Business Owner
Reviewed at:
Price: $49.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
