Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
Displaying 1 - 5 of 8 Reviews
Radio Shack Crimp-On Gold-Plated Banana plugs (2-Pack) Review
Pros
Cons
Best Uses
"It is very obvious that the previous users likely made two mistakes.
1) Did not use a proper crimping tool
2) Attempted to crimp or in the wrong place.
You must have a proper crimping tool, and the crimp is to be located precisely 5/16" from the rear end of the plug. (The half circle of metal
Read Full Review »
Pros
Cons
Best Uses
"I've used dozens of these gold plated banana plugs. If there is a problem it is that these previous reviewers are confused about what a proper crimp is and where it should be placed. Using of the correct type and size of crimping tool WILL result in bad results. Radio Shack should supply technica …" Read Full Review »
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"These are not crimp-on as labeled; they are solder-on. And the insulating jackets do not stay in place (easily slide over the plug or off when you try to un-plug it). Avoid these and go for another. "
Pros
Cons
Best Uses
"These are solder on only; NOT crimp as stated on the package. The material is brittle and just cracks. Crimp? Solder? must have gotten lost in translation from Chinese to English. "
Pros
Cons
Best Uses
"These things are made out of a brittle material and will not crimp, but will crack. I bought 7 sets, and everyone cracked when I tried to crimp them. They do not solder well either, they need to be re-designed out of a crimpable material. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
