Radio Shack Chimney Ratchet Mount
#167
2.0
based on 48 reviews
Ratings Distribution
5 star
3
4 star
5
3 star
9
2 star
3
1 star
28
Category Average
3.6
$24.99 at RadioShack
Find it at Amazon
Find it at Ebay
$24.99
from 1 store
Pros
  • Easy setup (7)
  • Durable (5)
  • Does the trick (1)
  • Easy enough to use (1)
  • Fits all chimneys (1)
  • Gets job done (1)
  • Good performance (1)
  • Great product (1)
  • In stock (1)
  • Looks good in the box (1)
See less See more
Cons
  • Flimsy (22)
  • Hard to set up (5)
  • A piece of junk (1)
  • Bad ratchet design (1)
  • Cheap metal (1)
  • Clunky (1)
  • Couldn't tighten down (1)
  • Dangerous to your roof (1)
  • Don't overtighten (1)
  • Easily broken (1)
Best Uses
  • Chimney (4)
  • Attic/roof mount (2)
  • Trash can (2)
  • Chimney mount (1)
  • Chimny (1)
  • Don't know of any (1)
  • Living room (1)
  • On a chimney (1)
  • Paper weight (1)
  • Scrap metal recycling (1)
Provided by RadioShack
This mast mount provides secure mounting to chimney, simply tighten it with a screwdriver. Two 5/8” by 18 foot stainless steel straps ensure a more sturdy mount.
Specification Description
Model 15-0839
Accessory Indicator Yes
Benefits Tightens with screwdriverIncludes 2 stainless steel straps, each 5/8"x18 feetAccepts antenna mast 1" to 1-3/4" diameter
Body Material Metal
Capacity UOM mAh
Country Of Origin United States
Description Header Accessories to help you mount your antenna with ease.
Display Catalog Number 15-839
Enclosure Color SILVER
Features Secures antenna mast to chimneyRust-resistant galvanized steelFits most chimney sizesAccepts antenna mast 1" to 1.2
Included in the Box Chimney Ratchet Mounts (2)stainless steel straps (each 5/8"x18 feet) (2)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 15-0839
Operating Temperature UOM ° F
Product Type Mounting hardware
Supported Languages English
Radio Shack Chimney Ratchet Mount Questions
Questions and Answers
Where to Buy
$24.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 1, 2009
Radio Shack Chimney Ratchet Mount Reviews
Most helpful positive review
Most helpful negative review
4.0
Decent product with long life
"I mounted my DirecTV dish on the chimney around 1997 using one of these, and it is still in place and holding a (now much larger) dish in place during high wind storms. Easy to set up. I've used a second one for a small vertical antenna on a different chimney for the last six years and again, no problems. Decent product...." Read Full Review »
Feb 20, 2009 by Jim
See more positive Radio Shack Chimney Ratchet Mount reviews
2.0
Not great, but all I could find.
"The best thing you can say about this mount is it is in stock and availabe at Radio Shack. I called all over town looking for an alternative but no one stocks antenna mounts locally, so this was my only choice. The first one I bought had to be returned because it was defective. It is misleading when it says that is has to be tightened with a screwdriver. You are not tightening a screw, you are using the scre..." Read Full Review »
Oct 16, 2009 by AshevilleNorthCarolina
See more negative Radio Shack Chimney Ratchet Mount reviews
Displaying 1 - 5 of 48 Reviews
Show
Sort by
2.0
    Pros
  • In stock
    Cons
  • Flimsy
    Best Uses
  • Chimney mount
"The best thing you can say about this mount is it is in stock and availabe at Radio Shack. I called all over town looking for an alternative but no one stocks antenna mounts locally, so this was my only choice. The first one I bought had to be returned because it was defective. It is misleading w …"  Read Full Review »
Was this Antenna review on the Radio Shack Chimney Ratchet Mount helpful to you?
Oct 16 2009
Asheville, NC
I am:
  • Enthusiast
Reviewed at:
Price: $24.99
Works okay but not great
3.0
    Pros
  • Gets job done
    Cons
  • Don't overtighten
    Best Uses
  • Chimney
"That thing is okay, not great but not as terrible as what a lot of reviews say. I had mixed feelings about buying this and made sure I kept receipt. I needed a chimney mount because I have hip-roof, which means no gable and have two foot roof overhangs. If you can use regular mounts, I would go with …"  Read Full Review »
Jul 14 2008
Mr. Spock
Benton, AR,
I am:
  • DIY
  • Practical
  • Tech Savvy
Reviewed at:
Price: $24.99
You Can Do This!
3.0
    Pros
  • Durable
  • Easy Enough To Use
    Cons
  • Clunky
    Best Uses
  • Chimney
"I set it up by myself in under one hour. Two people would make it a little easier but it really was OK. It would be nice if RS included a small bar to crank it with instead of saying "all you need is a screw driver". It's a little misleading. "
Nov 1 2009
Up On The Roof
Portland, OR
I am:
  • Casual User
Reviewed at:
Price: $24.99
[1 of 1 customers found this review helpful]
This product should be recalled!
1.0
    Pros
  • Makes salesmen commision
    Cons
  • Flimsy
  • Hard To Set Up
  • Will make you curse
    Best Uses
  • Don't know of any
"This product seems like a good idea. And it might be. But, the design and manufacturing of it failed miserably!
The ratchet mechanism is loose and will allow the sprocket to jump over the lock.
The metal it is made of is cheap and will bend while tightening.
If it was made to actually work there …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 15 2008
Chuck
Southeast Texas
I am:
  • Enthusiast
Reviewed at:
Price: $24.99
No problems
3.0
    Pros
  • Easy To Set Up
    Cons
  • Not enough ratchet teeth
    Best Uses
  • Living Room
"After reading several of the other reviews on this product I was skeptical. I bought it because it was handy available and I didn't want to drive around on a late Sunday afternoon only to find places closed.
My neighbor helped me get the mount attached to the chimney and the antenna up and tuned. I …"  Read Full Review »
Aug 11 2008
George
Ramona, Ca
I am:
  • Practical
Reviewed at:
Price: $24.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
