#31
based on 45 reviews
Ratings Distribution
| 5 star |
14 |
| 4 star |
16 |
| 3 star |
6 |
| 2 star |
5 |
| 1 star |
4 |
Category Average
$15.99
from 1 storePros
Cons
Best Uses
Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
[1 of 1 customers found this review helpful]
"I bought this antenna when my Pro 97 began to have reception problems which I thought may have been related to the stock duck. While the problems turned out to be a loose connector inside the radio, once it was fixed I began to use this antenna and I can say it works very well! The stock rubber duck had trouble picking up the low band fire/EMS dispatch frequency for my county for most transmissions broadcasted..." Read Full Review »
Oct 13, 2008 by Septa3371CSX1
See more positive Radio Shack Center-Loaded Telescoping Whip Antenna reviews
"I used this antenna to increase my pick up range and listen to the nearby airports. It definitely increased range and picked up signals better, but from the first time I connected it to my scanner it was not tight-fitting and the electro-magnet section would rattle. For the most part the scanner and antenna just sat on a window sill and I've taken it outside 4 or 5 times to do some aircraft spotting. Today when ..." Read Full Review »
Dec 30, 2008 by Randy
See more negative Radio Shack Center-Loaded Telescoping Whip Antenna reviews
Displaying 1 - 5 of 45 Reviews
Radio Shack Center-Loaded Telescoping Whip Antenna Review
Pros
Cons
Best Uses
"I bought this antenna when my Pro 97 began to have reception problems which I thought may have been related to the stock duck. While the problems turned out to be a loose connector inside the radio, once it was fixed I began to use this antenna and I can say it works very well! The stock rubber du …" Read Full Review »
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"This is a very good receiving antenna. I use it on my PSR-100 and my Pro-82 handheld scanners and when fully extended it pulls in signals 50+ miles away very clear. 10 times better than the stock rubber duck antenna. It is more fragile as it is telescoping, but this thing pulls in signals like crazy …" Read Full Review »
Pros
Cons
Best Uses
"Though a tad large and cumbersome, this antenna has really improved my searching of the air traffic band. I've received Ground control transmissions from airports as far as 25 miles away. Even faint airport TIS transmissions are heard clearer. I've also picked up transmissions from fire, police, pub …" Read Full Review »
Pros
Cons
Best Uses
"i bought this antenna specifically for the distant 42mhz freqs in my area, it proved to be completely useless for that purpose, the nearby low band channels i strugged with before are now crystal clear, and the scratchy sounding vhf channels are perfect now as well, i couldnt really test the uhf …" Read Full Review »
Pros
Cons
Best Uses
"Gets a much better signal than the stock rubber duck antennas that come with scanners. I like that it can be tuned to specific frequencies. The buying point for me was that it could also be used to transmit. It is a bit fragile, though. It's not an action antenna, but it should be fine for gentle us …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
