Radio Shack Center-Loaded Magnet-Mount Antenna
#143
3.6
based on 17 reviews
Ratings Distribution
5 star
7
4 star
4
3 star
2
2 star
1
1 star
3
Category Average
3.6
$29.97 at RadioShack
Find it at Amazon
Find it at Ebay
$29.97
from 1 store
More Images
Pros
  • Durable (10)
  • Easy setup (9)
  • Easy to use (5)
  • Good value (5)
  • Strong signal (5)
  • Good reception (4)
  • Attractive design (3)
  • Fine-tuning (3)
  • For the price it is good (1)
  • Has potential (1)
See less See more
Cons
  • Poor reception / weak antenna (3)
  • Flimsy (2)
  • Nothing wrong with it (1)
  • Pathetic swr (1)
  • Unattractive design (1)
Best Uses
  • Attic/roof mount (1)
  • Bedroom (1)
  • Cb listening (1)
  • Paper weight (1)
  • Portable devices (1)
  • Roof of truck (1)
  • Scanneramfm radio (1)
  • Truck (1)
Provided by RadioShack
Magnet-mount antenna features a center-loaded coil for increased efficiency.
Specification Description
Model 21-994
Accessory Indicator Yes
Benefits 26-1/2" high, stainless steel whipCenter-loaded coil offers increased efficiency in a shorter antennaInstalls easily with no
Body Material Multi
Cables Included 16 Foot hookup cable
Capacity UOM mAh
Country Of Origin China
Description Header Get shorty.
Display Catalog Number 21-994
Enclosure Color Black/Silver
Included in the Box Center Loaded, Magnet Mount CB Antenna with 16-ft. Cable
Inputs 1 x PL259(CB Antenna)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 21-994
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Outputs 1 x PL259(CB Antenna)
Product Dimensions UOM inches
Product Disclaimer Not recommended for use on vinyl roofs
Product Height 27.5
Product Type CB
Recommended Use Ideal for highway use.
Required to function Hookup cableCB radio
Supported Languages English
Radio Shack Center-Loaded Magnet-Mount Antenna Questions
Questions and Answers
Where to Buy
$29.97
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 5, 2009
Radio Shack Center-Loaded Magnet-Mount Antenna Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Good antenna
"This was my first-ever CB antenna. It's center-loaded, which means the coil is in the middle at the antenna instead of the base. Inch-for-inch, center loaded antennas typically outperform base loaded antennas. I found this antenna a very good compromise between signal strength and antenna height. To tune this antenna... if the SWR is too high on channel 1, your antenna is too short and needs to be longer. I..." Read Full Review »
Sep 28, 2007 by Dan
See more positive Radio Shack Center-Loaded Magnet-Mount Antenna reviews
1.0
JUNK
"Set screw stripped when making initial adjustments. I never had consistent performance from it. I found that I had to take it apart several times to clean the corrosion from the contacts in the center load coil. Yesterday, after just two years, I was taking the antenna off for a car wash and the magnet stayed attached to my truck. It was covered with rust. I was actually happy to cut the wire. I will not b..." Read Full Review »
Jul 04, 2009 by Tankdawg
See more negative Radio Shack Center-Loaded Magnet-Mount Antenna reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
JUNK
1.0
    Pros
  • Attractive Design
  • Easy To Set Up
    Cons
  • Flimsy
  • Poor Reception
    Best Uses
  • None
"Set screw stripped when making initial adjustments. I never had consistent performance from it. I found that I had to take it apart several times to clean the corrosion from the contacts in the center load coil. Yesterday, after just two years, I was taking the antenna off for a car wash and the …"  Read Full Review »
Cheap materials and construction
  • Picture of Product
corrosion on coil
corrosion on coil
Was this Antenna review on the Radio Shack Center-Loaded Magnet-Mount Antenna helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jul 4 2009
Tankdawg
St. Louis, MO
I am:
  • Casual User
Reviewed at:
Price: $29.97
Good antenna
5.0
Super Informative
Super Informative
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"This was my first-ever CB antenna. It's center-loaded, which means the coil is in the middle at the antenna instead of the base. Inch-for-inch, center loaded antennas typically outperform base loaded antennas. I found this antenna a very good compromise between signal strength and antenna height. …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
Sep 28 2007
Dan
Marshall, MN
Reviewed at:
Price: $29.97
[1 of 1 customers found this review helpful]
Hey, a paperweight for radios!
1.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Good reception
    Cons
  • Flimsy
  • Pathetic SWR
    Best Uses
  • CB listening
  • Paperweight
"There are about 3 companies off the top of my head who put their label on this antenna and it is not the wexclusive design of radio shack nor is it made only for radio shack. [@] sells it as the SoundFX antenna, others as the Midland compact antenna. Its garbage. Your lucky if you can get the SWR to …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 15 2009
Blue Buster
Atlanta, GA
I am:
  • Enthusiast
Reviewed at:
Price: $29.97
Scanner ant/ not cb
1.0
    Pros
  • If youe in a pinch
    Cons
  • Poor Reception
    Best Uses
  • Scanneramfm radio
"i bought this ant for ease of use seeing my F-150 could'nt hold a trucker,and it was the only mag mt they had in the shack store i went to. The antenna rusted within 2 weeks,and was bent over in less than 1 week. But it makes a great flag holder on the roof. "
Nov 5 2009
jack the jake
New Bedford ma
I am:
  • Enthusiast
Reviewed at:
Price: $29.97
Needs Improvement
3.0
    Pros
  • Has Potential
    Cons
  • None
    Best Uses
  • None
"Mounted in the center of the roof on a Ford Crown Vic LX, connected to the Shacks 21-534 Power SWR Meter and a 21-1679 Handheld CB radio, straight out of the package, the antenna was pegging in the red on the SWR meter!!! NO GOOD!!! Extending the tip rod out as far as it would go and still have the …"  Read Full Review »
May 2 2009
KIW-1489
Wilmington, N.C.
I am:
  • Power User
Reviewed at:
Price: $29.97
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
