Close Login Module
Join
Radio Shack BNC to PL-259 Adapter
#345
5.0
based on 3 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$4.99
from 1 store
Pros
  • Consistent performance (2)
  • Rugged (2)
  • Versatile (1)
See less See more
Best Uses
  • Travel (1)
Where to Buy
$4.99
Product Reviews
Last update: Jul 3, 2009
Radio Shack BNC to PL-259 Adapter Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Great for using handheld CB in a vehicle
5.0
    Pros
  • Consistent Performance
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Travel
"Great for using a handheld CB radio in a vehicle. Saves you from having to open up or modify the dash of a vehicle and from having to run power leads to the battery or fuse box like you would with a permanently installed mobile CB radio. "
Apr 14 2009
Dave
I am:
  • Power User
Reviewed at:
Price: $4.99
Good piece
5.0
    Pros
  • Rugged
    Cons
  • None
    Best Uses
  • None
"Consistent quality and availability at local stores makes this an attractive product. Price is reasonable. We use a bunch of them on our two way com gear. "
Jul 3 2009
DGI Eng.
Big Rapids, MI
I am:
  • Power User
Reviewed at:
Price: $4.99
Best! Do it, fast and ...
5.0
"Best! Do it, fast and easy. I have several rooftop antennas I wanted to use and connect my HHeld scanners and other radios. The HH with BNC Antenna connectors can be a problems as they have to lean over due to strength (RG8) of cable. I used this with the angle adapters and I can use the HH to co …"  Read Full Review »
Mar 31 2007
Jeffrey M
Austin, TX
Reviewed at:
Price: $4.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
$4.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
