Close Login Module
Join
Radio Shack Amplified VHF/UHF/FM Indoor Antenna
2.2
based on 147 reviews
Ratings Distribution
5 star
10
4 star
29
3 star
12
2 star
20
1 star
76
Category Average
3.6
Pros
  • Easy setup (83)
  • Strong signal (23)
  • Durable (13)
  • Fine-tuning (13)
  • Attractive design (10)
  • Easy to use (8)
  • Good performance (5)
  • Reliable (5)
  • Good value (4)
  • Great with fm radio (1)
See less See more
Cons
  • Poor reception (75)
  • Flimsy (13)
  • Unattractive design (13)
  • Bulky (7)
  • Hard to set up (2)
  • Always have to adjust (1)
  • Antenna bends easily (1)
  • Awful reception (1)
  • Bad w converter (1)
  • Broken (1)
Best Uses
  • Living room (36)
  • Bedroom (23)
  • Small rooms (14)
  • Portable devices (8)
  • Office (6)
  • Attic/roof mount (2)
  • 35 paper weight (1)
  • Anywhere (1)
  • Basketball (1)
  • Boat anchor (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Amplified VHF/UHF/FM Indoor Antenna
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 3, 2009
Radio Shack Amplified VHF/UHF/FM Indoor Antenna Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[8 of 8 customers found this review helpful]
4.0
So far, so good - except....
"Like most people, I bought this unit along with a converter box to use with my old analog TV. (I haven't tried it with the digital TV yet) I found the antenna very simple to set up and use. I live in traffic-infested, noisy, crowded Anaheim, CA. surrounded by high-density appartment buildings (I know - I oughta move instead of buying a new antenna, but that's another story) and this antenna brought in local sta..." Read Full Review »
Jan 24, 2009 by Kipper Kid
See more positive Radio Shack Amplified VHF/UHF/FM Indoor Antenna reviews
2.0
Bad or Defective Amplifier Design
"I concur with the many others who give this antenna a bad review...though I'll backup my opinion with some quantitative numbers. I tested this antenna two ways. First I compared it with and w/o amplification. I've found that the amplifier doesn't work right. Even though it has a knob to tune the gain, this switch is effectively useless. There's basically only ONE narrow setting (turn the knob about 90 deg..." Read Full Review »
Jul 12, 2008 by Y. Wong
See more negative Radio Shack Amplified VHF/UHF/FM Indoor Antenna reviews
Displaying 1 - 5 of 147 Reviews
Show
Sort by
2.0
    Pros
  • None
    Cons
  • Poor Reception
    Best Uses
  • None
First I compared it with and w/o amplification. I've found that the amplifier doesn't work right. Even though it has a knob to tune …"  Read Full Review »
Was this Antenna review on the Radio Shack helpful to you?
 Report Abuse  (8)  (0)  0 comments
Jul 12 2008
Y. Wong
San Francisco, CA
I am:
  • Professional
Reviewed at:
4.0
    Pros
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Living Room
I live in traffic-infested, noisy, crowded Anaheim, CA. surrounded by high-density appartment buildings (I …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 24 2009
Kipper Kid
Anaheim, CA.
I am:
  • Enthusiast
Reviewed at:
This antenna is BETTER than it's reviews
4.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Office
"This amplified antenna has received some pretty bad reviews. First of all, there are many reasons for poor or no reception. I purchased this from my local RS store knowing that it is returnable if I was not happy with it. Before purchase, I came to this website and read reviews of all of the amplifi …"  Read Full Review »
Apr 8 2009
Jaguar
Jacksonville, FL
I am:
  • Power User
Reviewed at:
[3 of 3 customers found this review helpful]
Worth it for DTV
4.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"It is unfortunate to see the emotional responses to a product that is expected to be perfect in every application. I purchased this antenna to receive digital broadcast, not analog. This antenna is not perfect, but then no indoor antenna is. Almost every aspect of reception depends on location lo …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Apr 18 2008
Service with a smile :-)
Mpls, MN
I am:
  • PC Technician
  • Professional
Reviewed at:
Works well with DTV converter
4.0
    Pros
  • Easy To Set Up
    Cons
  • Flimsy
    Best Uses
  • Bedroom
  • Living Room
  • Office
"I've never had much luck with receiving analog signals where I live in Metro Atlanta. I'm in the middle unit of a three story apt in a valley surrounded by tall trees; my outside wall and windows face away from the tv towers. I asked the Radio Shack rep for a recommendation to use with my new Tiva …"  Read Full Review »
Oct 1 2008
Satisfied
Atlanta
I am:
  • Casual User
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
BizRate Rating Outstanding 9.0
Click for price
$20 Off Orders Over $125
$34.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
